Old June 9, 2016, 10:28 AM
Duality92's Avatar
Cool [The Duality] [Dual System, Godavari & Skylake in a Frozen-Q Apex mATX]
❚❚ Diginate.com ❚❚
❚❚ bequiet.com ❚❚
❚❚ FrozenQPCMods.com ❚❚
❚❚ Gigabyte.com ❚❚
❚❚ CableMod.com ❚❚
❚❚ Phanteks.com ❚❚
❚❚ ModMyMods.com ❚❚
du·al·i·ty
d(y)o͞oˈalədē/
noun
1.
the quality or condition of being dual.
"the novel's deep duality about human motive"
2.
an instance of opposition or contrast between two concepts or two aspects of something; a dualism.
"the photographs capitalize on the dualities of light and dark, stillness and movement"
Gaming
  • Intel i5 6600K - Delidded - 4.7 GHz @ 1.488v load
  • Gigabyte GA-Z170N-Gaming 5
  • G.Skill Ripjaws V 3200/16, 2*4GB
  • Gigabyte GTX 1070 G1 Gaming
  • ADATA SP900 m.2 256GB
  • OCZ Vector 128GB
  • Antec EDG750 80+Gold Modular PSU with CableMod ModFlex custom cable set and combs
HTPC
  • AMD 7870K
  • Gigabyte GA-F2A88XN-WIFI
  • Kingston HyperX Fury 1866/10, 2*8GB
  • Samsung 840 EVO 256GB
  • Antec VP450 PSU
Common Hardware and water cooling
  • Custom Frozen-Q Apex mATX case
  • Frozen-Q resevoir
  • 4 * Be Quiet! Pure Wings 2 80mm
  • 4 * Phanteks PH-F140MP
  • 1 * Phanteks PH-F120MP
  • 2 * Phanteks PWM Hub (new revision)
  • CableMod RGB 60cm LED
  • CableMod light blue sleeved SATA cables
  • Darkside White LED strips
  • Phanteks Extensions, 24-pin and 8-pin (red/black)
  • 2 * Alphacool NexXxoS XP³ Light - Acetal - Intel/AMD
  • Alphacool NexXxoS ST30 240mm
  • Alphacool NexXxoS XT45 280mm
  • Alphacool NexXxoS GPX - Nvidia Geforce GTX 1070 M01
  • Alphacool VPP755 EisPumpe
  • Alphacool Eisdecke D5 Top - Plexi G1/4 - V.3
  • 4 * Alphacool G1/4 Passthrough Connector - Black
  • 4 * Alphacool Eiszapfen 3/8" ID x 5/8" OD Compression Fitting - Black 6-pack
  • 10 * Alphacool Eiszapfen 45° Angled Rotatable Adapter Fitting - Black
  • 10 * Alphacool Eiszapfen 90° Angled Rotatable Adapter Fitting - Black
  • 4 * Phobya LEDready Twin 5mm Ultra-bright white 30cm - Black
  • 20 feet of Mayhems 3/8"-5/8" (10/16mm) Ultra Clear Tubing
  • Mayhems X1 UV Blue Concentrate 250ML
Old June 14, 2016, 09:06 AM
Duality92's Avatar
I want to say a really big thank you to CableMod! You have to try out their Configurator!
Old June 14, 2016, 12:24 PM
Duality92's Avatar
So I just put in a big order at MNPCTech stay tuned! :D
two vandal switches in black along
with 2-pin connectors and one switch plate in black
12x24 round modders mesh
Black pop rivets for the case
PC Chassis pop rivet tool
2* 12x12 red colored acrylic sheets
6/32 – ¼ red anodized screws
2 white 12 inch LED strip and one red 12 inch LED strip
The ATX pin removal tool
It's all fun and games 'til someone pulls the pin on a live grenade!
Old June 15, 2016, 07:34 PM
Duality92's Avatar
So this is what a Case Labs XL-ATX motherboard tray looks ready to be mounted to another case and transformed into ITX :) One more of these to come possibly!
Old June 19, 2016, 04:18 PM
Duality92's Avatar
The top has a tab with a spot for two rivets initially, but I had to chop that down. Along with this, I brought the whole bottom of the tray and expansion slots up to the last expansion slots height. This, technically puts me at 214mm. Once I'm done the second one, this case will be dual ITX with both a removable tray. I'm keeping the trays up to the size of the CPU cutout on these trays for cable management. I'm also still debating of the orientation of both of these. I have the choice between both regular, both reverse or one of both and have windowed side panels on both sides.
The trays them selves are done, just a tiny bit of sanding left and the paint will come later on. The turquoise paint was only put on for drawing purposes on this part :)
Old June 21, 2016, 05:26 AM
Mnpctech's Avatar
lookin good, and the Turquoise paint was cool
Old June 21, 2016, 06:17 AM
Duality92's Avatar
Just for this part, I forgot to specify :P
Old June 21, 2016, 01:06 PM
Duality92's Avatar
Alright guys, I need help deciding what layout I'll be using. I have my mind set on one, but I want to know what you guys think!
Old June 22, 2016, 05:01 AM
Duality92's Avatar
With the second ITX tray done, I've decided on this layout!
Old June 22, 2016, 06:18 AM
Rison's Avatar
"It's all fun and games 'til someone pulls the pin on a live grenade!"
Then it's a sport. :)
I'm wondering how you have the airflow for cooling. I'm completely OCD when it comes to system cooling, so much that I spent a solid 3 hours last night figuring out my new system build with a Corsair H60 (cheap from NCIX).
Are you putting two ITX in one case, or two ITX and your main system? I'm all for "outside the box" thinking, but wonder if there was an easier way to setup what you need using virtualisation versus multiple PCs in one computer. Personally at work, I just run a virtualized PC inside my main workstation full screen on a second monitor. Lock the processor affinity down and i'm good.
I've run this at home to a TV too - I just ran a hdmi to ethernet panel in the wall from my PC to TV in another room, ran it full screen as a second monitor and was able to game on the main system. Just run a second video card for the other monitor and it's good to go. Hell, I wonder if you could use the onboard video card for the TV, and external GPU for gaming..
6 threads for gaming, two for the TV.
I'll learn to manage my anger, when people learn to manage their stupid.
High-end Skylake System Beastylemon Price Check 3 August 11, 2016 12:37 PM
i5 4460 matx system - price check Caldezar Price Check 4 June 16, 2016 09:48 AM
Skylake System Build - RAM speed and 8GB or 16GB OttawaMaritimer New Builds 11 January 24, 2016 11:04 AM
mATX system perfecto New Builds 8 May 24, 2011 03:08 PM
[WTB] Complete BUDGET mATX gaming system Jamz Buy/Sell & Trade 1 December 16, 2008 08:29 PM
