Old May 29, 2016, 10:44 AM
BlackAcid's Avatar
Default Project Royale: Modded S-Frame, 5930k, 3-Way SLI
Helloooooo Internet! Thank you so much for checking out my new case mod, Project Royale!
This will be my second major case mod, this one inside of the In-Win S-Frame, consisting of mods which I have not performed on an S-Frame before. I am looking forward to getting started! The color scheme will be Black, Blue and Gold, as I will be showcasing the original finish of the S-Frame, which is the best finish I have ever seen on a case.
Now, let's start off with some specs:
CPU - Intel Core i7-5930k (Received)
Motherboard - Asus Rampage V Extreme (Received)
RAM - 64gb of Corsair Dominator Platinums @ 2400mhz (Received)
GPU - 3x Asus Geforce GTX 980ti Strix OC (Received)
PSU - EVGA 1000G 1000W (Received)
Case - In-Win S-Frame (Received)
Cooling: TBD
Control: Aquacomputer Aquaero 6 XT
Lighting: Aquacomputer Farbwerk
I will be liquid cooling this monster, but I am not sure what products I will be using. Stay Tuned!
Mods:
- Relocate Power Supply to main compartment by creating custom plate
- Install 480mm Radiator in original PSU compartment
- Create Mount Plate for Dual D5 pumps, which will run in serial.
- Create cover plate for HDD Bay Slots, then mount Aquaero to this plate
- Cut hole for cable routing
- Custom wiring for all wires
- Create cover plate for front I/O (I am not too sure whether or not this will happen, depends on how easily I will be able to sleeve the USB 3.0 wires)
- Drill passthrough holes for pipes
- Find something to create more space between the rear glass panel and the back panel of the case, so that I will be able to place pipes back there
Now that all of that is out of the way, let's get to some photos!
Some renders of the project: (These were based on EK Blocks and Blue Bitspower Fittings, but these are not final)
Product Photo Bomb, Incoming!!!!!
A couple pics of the 5930k. I purchased it used, so it still has a bit of TIM on it.
All six cores of awesomeness are visible in this photo! ;P
Some RAM from the Gods right here.
It's watching you....
Aaaand now for the most beastly motherboard I have ever seen, period!
Loaded up.
There's something about 8 DIMM slots filled with Dom Plats that gives me an immeasurable amount of satisfaction.
A crap ton of accessories are included with this board, it's insane!
Oh, and one more
PCB Traces!
Now I realize these aren't 1080's but I got them at a killer deal, so I GUESS these will have to do...
The backplates on these cards look killer!
And now, the main event!
This shot is to really show off the beautiful finish of the case, with Brushed/flat black and gold accents. I love it so much I am going to keep it!
Here are a few shots with the hardware loaded up...
Well, that is all for now, the next update should consist of starting the modifications.
Thanks for looking!
Dawson
Old May 29, 2016, 11:21 AM
lowfat's Avatar
None of your pictures are loading.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 5, 2016, 10:25 AM
Looks sick. :)
heat
rfd
hofo
Old June 5, 2016, 12:37 PM
Nice build. Looking forward to when you install the water cooling.
Old June 5, 2016, 01:11 PM
Lysrin's Avatar
Awesome jaw dropping power! :) That case is certainly different. Very unique.
Old August 6, 2016, 05:26 PM
BlackAcid's Avatar
Hello again internet!
I have done some thinking, and I have decided to change the color scheme, as well as the water cooling loop, as I was not happy with either. I am happy with these new renders, please let me know what you think! Also, I need a new name for this build, any suggestions?
I will hopefully start mods and aluminum work by the end of the month, and then liquid cooling by mid-September.
-D
Old September 18, 2016, 05:41 AM
nasrott's Avatar
Waiting to see what you do with this cool case, cooling would imagine is the big challenge here.
Case name was thinking maybe, Sssence
Old September 18, 2016, 01:57 PM
BlackAcid's Avatar
Thanks! Cooling is a big deal, and a triple rad just isn't enough. Time for a 480...
[WTB] 5930k / 5820k BabylonDown Buy/Sell & Trade 18 February 25, 2016 07:52 AM
[FS] old Roger Franklin Buy/Sell & Trade 2 February 3, 2016 08:12 PM
[WTB] i7 5930k and Z97 motherboard marc_0053 Buy/Sell & Trade 17 February 17, 2015 05:34 PM
Battle Royale Ottawa Lan odis172 Canadian LAN Parties & Events 2 October 29, 2012 10:29 PM
Ottawa Lan Battle Royale odis172 Canadian LAN Parties & Events 2 October 26, 2010 10:59 PM
