Old November 6, 2015, 11:14 AM
Trial Member
Default Inox M10, custom case made from scratch
Pictures: Inox M10 v0.8 - Album on Imgur
Specs: 4790k Gigabyte z97x sli 2x8 GB panram 2400mhz ddr3 noctua nh-c14 (only running lower fan, ultra low noise adapter) xfx r9 290 dd black edition (at 1100mhz atm) 256 GB crucial mx100 3TB WD green white bitfenix alchemy cables nzxt hale82 850W windows 8.1 pro
Thanks to all the positive support I received the first time I posted my case, I have decided to try and sell my design. For the initial funding, I have launched an indiegogo campaign:
https://www.indiegogo.com/projects/inox-m10-pc-case#/
If you are interested, please take a look. All support is greatly appreciated.
Old November 6, 2015, 11:45 AM
Lysrin's Avatar
Wow that is very creative and a little dangerous looking with video card fans exposed! That case would definitely have to stay out of reach of small children and pets. Pretty neat though, well done.
Old November 6, 2015, 12:21 PM
pretty slick case, but with a $600 CAD after taxes price tag, you won't be able to sell that case
Old November 6, 2015, 06:41 PM
CTA's Avatar
CTA CTA is offline
why too many same pictures... no detail pictures? my suggest you to redo to how to advertise your customize case properly... i just got a rough idea how your customize case really look like... but i want to see your customize case without my imagine... ;]
The open design allows for maximum cooling performance thanks to the high airflow and low intake temperature of the cooling air.
sorry to say... its not true...
-graphics card length: unlimited
nothing is unlimited or it would be looking so ugly...
darklord... the materials and etc are not cheap... dont forget about lian li or other manufacturer...
Old November 6, 2015, 10:37 PM
WolfBane's Avatar
Wow that's diff.
but I like it , again not for pets or children :)
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Old November 7, 2015, 12:08 AM
CTA's Avatar
CTA CTA is offline
why? did your kids scratch your casebox?
Old November 7, 2015, 03:22 PM
WolfBane's Avatar
not mine lol but this case has open vid card and kids or small pets could get hurt :)
I USE EMT ONLY
Old November 7, 2015, 05:53 PM
CTA's Avatar
CTA CTA is offline
get your own computer room... and a key... the problem is solved...
i usually put my computer on my coffee table behind/beside the computer table... or on the computer table... depend on my prefer....
Old November 7, 2015, 06:41 PM
It reminds my of the inwin s-frame lol, but this one is even more exposed. Whatch out because that video card is going to cut your fingers if you get too close ;)
Old November 7, 2015, 06:47 PM
sswilson's Avatar
Different, and certainly unique enough that there might be a market at that price point for a few units. As far as the open GFX fans go.... guess you folks never ran a FAH GPU farm on an open bench???? ;)
WIP Lan Case From Scratch Draex Case Mods, Worklog & Gallery 3 May 7, 2012 05:28 AM
Custom Made for Gaming High End Z68 - GIGABYTE G1.Sniper2 Complete Review windwithme CPU's and Motherboards 7 September 22, 2011 08:14 AM
Custom Made for Games G1-Killer X58 MB - GIGABYTE G1.Assassin Complete Guide windwithme CPU's and Motherboards 6 May 13, 2011 02:41 AM
Custom-made waterblock DRYJESUS Water Cooling 9 December 11, 2010 07:34 AM
my custom made phase units ruffus Water Cooling 28 October 28, 2009 08:51 PM
