Old April 3, 2015, 04:14 PM
mello_newf's Avatar
Talking Lian Li PC-V359 W/C Build
Been working on this off and on with a limited budget for months now. I think I have made enough progress to start posting my work log.
Hardware
Case
- Lian Li PC-V359
Motherboard - Asus Maximus VI Gene
CPU - i7 4770 / 4790 (sourcing)
RAM - 4x4GB Mushkin Redline 2133 DDR3
GPUs - SLI Evga GTX 680 SC
HDD - 4TB (sourcing)
SSD - PNY PRO 240GB
PSU - XFX 850W Pro (might change)
Cooling Components
CPU Block - EK Supremacy Nickel / Plexi
GPU Blocks - EK FC-680 + Nickel Plexi / Acetal w/ Plexi parallel sli bridge
RAM Block - EK-RAM Monarch Nickle Plexi 4 Slot w/ EK RAM Modules
Mobo Block - EK M6G Nickle Plexi
Radiators - 2X 240mm X 60mm (1X AlphaCool UT60 - 1X XSPC RX240)
Fans - 3X Noctua NF-F12 3000RPM - 2X ProLima Vortex 12 400-1300RPM
Fittings - Bitspower Shining Silver 7/16 X 5/8 Compression, Extenders, Rotary Adapters, Ball Valve, Air Release
Tube - Promochill White
Pump - D5 W/ Koolance pump base / res combo
Reservoir - Bitspower Z Multi 150
Notes
Dual 120mm Side Panel Fan Mounts
-Can support a slim (30mm thick) style 240 rad with 2x 20-25mm thick fans (both sides)
*exceeding a total thickness of 55mm per rad will cause clearance issues with the back mounted 120mm fan, cpu block, and GPU (depending on board and PCI-E slot spacing having a card on the bottom PCI-E slot with cause clearance issues with the rad, might get away with 25-30mm rad & 15mm fans on that side)*
Flipping the side panels to mount rad under mobo tray requires the following
-Remove mobo risers from tray (space with very thin nylon washers)
-Relocate mobo tray supports from front of case towards the center of the tray (add 10mm spacers)
-Drill holes at back side of case 10mm up to attach back side of mobo tray
-Grind/cut 3-4mm up the IO cutout in the back of case
-Remove HDD & Front mounted 120mm fan
-Remove PSU mount, HDD cage magnet, side panel stabilizer x2
-Remove front mount USB / Audio *slightly slimmer rad would avoid this :(
-Extend (cut) back existing PSU cutout to far side of back panel
-Mount PSU in back middle
-Mount HHD/SSD under mobo tray
-Mount pump/Res onto right side panel
Case Layout
Marking The Case For Cutting
Hardware And Water Components
Cut Pieces Of Side & Back Panel (Mobo Tray Still Needs Work)
Old April 19, 2015, 08:58 AM
DTI DTI is offline
How's the build coming. its a nice looking case wish I would of purchased this one
Old April 26, 2015, 06:21 PM
mello_newf's Avatar
It's coming along, waiting on some stuff from china that's holding up a few things. Just popped in to post a small update
And yeah I dug this case when I first saw it, was hoping it would require a little less modding to get the rads under the mobo tray, but other than that it's been solid and comes apart like a champ.
First up I cleaned the frosting off the GPU, SLI, CPU blocks. CPU was done when I purchased just gave it a polish. Wanted consistency with the clean CSQ RAM & MOBO blocks
Shout out to Lowfat for the awesome guide
LINK
Second, I got the fan controller mounted on the side panel and a quick shot of the back of the case (PSU cables will be a pain, but it's all going to be hiden under the mobo tray)... Ill see what I can do.
Lian Li PC-V359 mello_newf Cases 9 November 14, 2014 09:56 PM
WIP The Next Lian-Li PC build project GreenPC Case Mods, Worklog & Gallery 6 March 23, 2012 10:37 AM
Gallery My Lian Li Q11 build Paul88 Case Mods, Worklog & Gallery 3 April 5, 2011 04:28 PM
Gallery Lian-Li PC-8N + Spare Parts Build Socrates_Johnston Case Mods, Worklog & Gallery 0 September 7, 2010 02:04 PM
Lian Li PC-7FW build saif Case Mods, Worklog & Gallery 26 March 22, 2010 02:32 AM
