Old October 19, 2014, 06:39 PM
Default [Build Log] The Yellow Minotaur (C70 - Water cooled - Painted)
Hey Folks,
It's been a loooooooooong time since I've built a rig that requires more than a weekend worth of work, finally it's time to get back on track before the snow hits.
so Color Scheme is going to be Yellow and black, of course matching the motherboard/case, sleeving and water-cooling equipment
Hope you'll enjoy it.
Case
Corsair C70 Gunmetal (Going to be modded to match the theme)
Components
- CPU: Intel i5 - 4670K
- Motherboard: BIOSTAR Hi-Fi Z97WE
- Ram: un-decided
- HDD: Seagate Pipeline 2TB (might run two of them in RAID 0)
- PSU: EVGA 600W B
- GPU: Zotac GTX 680 4GB edition
Cooling
- XSPC Raystorm waterblock (People's favorite)
- Black Ice GT 360 Radiator + Alphacool NexXxoS ST30 (subject to change)
- XSPC X2O 750 Dual Bay Res/Pump
- Bitspower 1/2ID 3/4OD silver fittings
- Primochill 1/2ID 3/4OD clear tubing
- Distilled water with Mayhems yellow dye
Sleeving
- MDP-X Black
- Axon banana yellow
Everything is subject to change. I'll update along the way.
Reserved
Old October 19, 2014, 06:43 PM
Some initial pics of the case, more coming soon
Old October 19, 2014, 06:45 PM
Fans and bays are out!
I love how these bays are easily taken out
First of all, measurements measurements measurements and guess what, something won't let my 360 go in!
Problem easily fixed
Sure enough, 2 minutes later
Piece is gone!
Time to put the rad inside and guess what happened
[IMG ALT=""]http://www.overclock.net/content/type/61/id/2215745/width/500/height/1000[/IMG]
Here, I'll zoom in, yes I'm f***ing pissed
Motherboard
A shot of the CPU
PSU
HDD
The GPU
4GB ;)
Can't have a 4GB card with no block
Cuz colored tubing is too mainstream
The most common block out there
Now for the most expensive items of this build
Old October 19, 2014, 06:46 PM
Got the stuff ready for painting
Painted the parts over two days and threw them in the case, couldn't take pics of the process as it was freaken 4 degrees!!
Oh yeah, the board is mounted
A proper pic of the CPU
Dat chipset
did I mention that I got the Bay res/rad
This case doesn't like water cooling!! Can't fit the res unless I get the appliers
Seems like it will have to remain like this till tomorrow ...
Old October 22, 2014, 08:33 PM
A small update, got home today and guess what, I could feel the sun!! No clouds!!
looked at that pc and well, it was time to pimp it up
Looked at that PSU
yea, that has to be fixed, How can I fix that? Here's a hint.
Yeah, the front is too plain, don't you think?
well, if I'm painting, I might as well make it more than one item
Not taking the camera outside, so let's forward to 40 mins later
Front goes in and awesome comes out
Did I mention that I bent some metal, fit that res and attached that front?
How about we throw that modified PSU in there
Crappy picture, I know, It's 11:30pm and I've been awake since 7am, just wanted to share that last piece done today
Here's a close up
Old October 24, 2014, 02:12 PM
mello_newf's Avatar
Looking good, dig the yellow/gold color want to have that as one of my main colors in my next build.
I think that XSPC block would look better if you connected the yellow at the top. Unless your sponsored by them I don't see the need to show off the brand..
Old October 25, 2014, 01:56 PM
Thanks
Just looks better if XSPC is showing, thinking about it, I got the res/pump/rad/CPU block all XSPC, they should sponsor me lol
Old November 27, 2014, 04:17 PM
A small update from last weekend, had (still have) car problems so progress on the pc is a bit slow, anyways, here are some pics.
Got the replacement rads (decided to go with dual 240mm instead of that broken 360)
Some really bad close up pics (i'm not gonna even bother with multiple angles)
Both rads good to go (Go where you might ask)
Here, I'll give you a hint
Well, if you're going to do that, might as well invite everybody
Now this pic turned out to be really crappy :mad:
30 minutes later and the fans were.............................................. disassembled
Stuff happened outside and this was the result
Re-apply some oil to make those fans spin and assemble them
What about the rads you might ask, have no fear, some crappy pics are here
A small fight with the case and this was the end result
Will start polishing that GPU block and running those tubes next weekend (hopefully)
Old November 27, 2014, 04:19 PM
well, sickness faded (by faded, I really mean that those 50 pills I took finally kicked in lol) away and I got some work done, unfortunately, my friend borrowed my camera so it's cell phone pics for now.
First of all, I got the GPU block, now this is a used GPU block as you can tell from the pictures but never the less, I wanted to try something
So I grabbed that GPU block and followed low fat's tutorial, MAKE A TUTORIAL ON HOW YOU TAKE YOUR PICS!!
Took apart the block and did the same to the back
What did I do you might ask, well here's a picture of the block before and after (I filled it with water to clean it and blurred the inside... but anyways)
Old
New
Since that's done, time to take apart that GPU
Threw everything together
Time to clean some fittings
A couple of crappy pics of the card and block
Time to measure and hook up some tubes
Some clean bends with enough space to move the res to the front
I took option one
Some Protection
Filled it with some water
How it looked before i went to sleep
After I woke up
$1750 Wants to build a water cooled system howdid New Builds 14 July 12, 2013 07:59 AM
Water-Cooled 4P Opterons (build log) dandelioneater Water Cooling 16 June 20, 2012 09:10 PM
Brothers to help me build a water-cooled brand name silaoye47 Water Cooling 5 June 5, 2012 03:10 PM
650d water cooled build tips bigbaseballguy13 LinusTechTips Q&A 12 March 21, 2012 09:06 AM
Water cooled tech station build switch33 Case Mods, Worklog & Gallery 21 January 14, 2010 07:06 PM
