Old September 10, 2014, 09:42 AM
Skippman's Avatar
Default Project Monolith
Since my last gaming rig was killed by lightening much like someone living in a flood plain I'm going to rebuild! I thought you might all like to come along with me while I do this. I'm calling this Project Monolith. Much like the iconic prop from 2001: A Space Odyssey my Corsair 700D is a giant black slab so I felt the name fit.
Here's the parts list I've come up with. The whole rig has set me back about $2200 USD. Since the insurance is covering most of it I've decided to make the best use of the money I could.
CORE COMPONENTS
Case Corsair 700D w/ Side Window
PSU EVGA SuperNOVA 1000 G2
Motheboard Gigabyte GA-Z97X-Gaming 7
CPU Intel i7-4790K Haswell Quad-Core 4.0GHz
RAM G.SKILL Trident X 16GB (2 x 8GB) DDR3 SDRAM DDR3 2400
GPU ASUS ROG POSEIDON-GTX780-P-3GD5 GeForce GTX 780
SSD Samsung 840 EVO 1TB SSD
Optical LG Internal 16x Super-Multi Blu-ray Writer
USB Panel Corsair Corsair Obsidian Series 700D Front Panel USB 3.0 Upgrade Kit
COOLING COMPONENTS
Pump Swiftech MCP-655-PW Pump
Reservoir Monsoon Series Two Premium D5 / MCP655 Dual Bay Reservoir - Matte Black w/ Black Trim
Radiator Swiftech MCR320-QP 3x120mm Quiet Power Radiator
Radiator Shroud XSPC 2x XSPC 3 x 120mm Radiator Gasket - 3mm
CPU Cooler Swiftech Apogee XL CPU Waterblock - Custom ROG Version
Compression Fittings Monsoon Red Carbon Fiber Enhanced Compression Fittings, 1/2" x 3/4" Six Pack - Matte Black
Compression Fittings Monsoon 2x Red Carbon Fiber Enhanced Compression Fittings, 1/2" x 3/4" Single - Matte Black
Compression Fittings Monsoon 2x Monsoon 90 Rotary Angle Adapter - 1/2" OD - Matte Black
Compression Fittings Monsoon 2x Monsoon 45 Rotary Angle Adapter - 1/2" OD - Matte Black
Coolent PrimoChill 2x Non-Conductive Liquid Cooling Fluid (32 oz.)
Quick Disconnect Koolance QD4 Quick Disconnect No-Spill Coupling, Female QD4-FS13X19-BK
Quick Disconnect Koolance 2x QD4 Quick Disconnect No-Spill Coupling, Male QD4-MS13X19-BK
Tubing XSPC XSPC FLX Premium Grade PVC Tubing - 1/2" ID (3/4"OD) - 2 Meter - UV Red
Fan PWM Splitter Swiftech 2x Swiftech 8-Way PWM Cable Splitter - SATA Power (8W-PWM-SPL-ST)
120mm Case Fans Corsair 4x Air Series CO-9050029-WW SP120 120mm Red Fans
140mm Case Fans Corsair 2x Air Series AF140 CO-9050017-RLED 140mm Red LED
140mm Case Fan Corsair 1x Air Series AF140 CO-9050009-WW 140mm Quiet Edition
WIRE MANAGEMENT
Grommet Kit Corsair Corsair 350D Grommet Kit $5.99 Performance PCS
Wire Management N/A 4x Spiral Wrap Polyethylene Black UVB 0.25 O.D.
Wire Management N/A 4x Spiral Wrap Polyethylene Black UVB 0.50 O.D.
Wire Management N/A 5x Mod/Smart 1/2in. Wire Saddle - Snap Style - Black
Wire Management N/A 3x Mod/Smart SATA Snap Style Hold Down - Black
PWM Connector Frozen CPU 2x 4-pin Female PWM Fan Connector - Black
Wire Loom Bitspower 10x 1' section Bitspower Super Tight Weave 1/4" - Black
Wire Loom Bitspower 10x 1' section Bitspower Super Tight Weave 1/8" - Black
Wire Loom Bitspower 5x 1' section Bitspower Super Tight Weave 1/2" - Black
Here's how I planned to install the cooling components.
Here's how I plan to wire the fans up. Since there is a design flaw with the Corsair fans I can only run 4 to a PWM splitter before they loose the ability to be PWM controlled due to signal attenuation.
Last edited by Skippman; September 10, 2014 at 09:46 AM. Reason: Formatting Issues
Old September 11, 2014, 05:47 PM
Skippman's Avatar
Look what came in the mail today!
Old September 12, 2014, 02:47 AM
Good!
Corsair 650D, Asus Rampage IV Formula, Intel I7 4930k, Arctic Cooling MX-4 Thermal paste
Corsair H100i, Lamptron FC5V2 Fans controller
Asus GTX 770 OC DCII, Corsair AX850 PSU
Kingston HyperX T1 4x4go
Bitfenix Cables
Old September 17, 2014, 02:01 PM
Skippman's Avatar
So, minor glitch. The fans from Corsair are not in fact PWM fans, they're 3 pin jobs. So that means my plans to use the Swiftech PWM splitters won't work. So I've ordered a NZXT GRID+ fan controller. I have a spare USB 2.0 header on my motherboard so that shouldn't be a problem. Also, Corsair in it's infinate wisdom decided the best way to implement a USB 3.0 front panel upgrade was to put standard Type A connectors on the back and have you run the cables into your rear motherboard USB 3.0 jacks by routing the cables through the rear water cooling grommets on the case. That's not going to work either so I've also ordered a USB 3.0 motherboard header to USB Type A female adapter so I can keep all the wiring in my case, where it belongs.
Here's a couple images of what I've gotten done so far. I've assembled the radiator/gaskets/fans and mounted it, spiral wrapped much of the wiring, mounted the SSD, and installed the motherboard.
WIP Dual Rigs - Project "Calico" & Project "Apollo" Birk Case Mods, Worklog & Gallery 28 January 22, 2014 02:03 PM
Help with a project bissa Off Topic 7 May 17, 2012 08:12 PM
Project: i7 Lpfan4ever Case Mods, Worklog & Gallery 31 October 6, 2009 09:47 PM
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
