Old August 18, 2014, 01:07 PM
Default Project Oceanus
Hello to all Hardwarecanuncks users,today im here to present to you my most recent watercooling project. First the choice of the case was a personal choice,due to the case having lots of modding potencial and pf course of the dimension of it also helped ,it also alowed the instalation of a different radiator setup, that´s rigth im going to use four radiators in this project,im glad the case has wheels or it wouldnt move.
The case choosen for the project is a Phobya WaCoolT UltraBig case,the case is basicly a beast,and it´s very easy to work with due to the screws system.
The name of the project is due to the massive amount of water it will have in the watercooling system.
Oceanus (/oʊˈsiːənəs/; Greek: Ὠκεανός Ōkeanós,[2] pronounced [ɔːkeanós]) was a pseudo-geographical feature in classical antiquity, believed by the ancient Greeks and Romans to be the divine personification of the World Ocean, an enormous river encircling the world.
Strictly speaking, Oceanus was the ocean-stream at the Equator in which floated the habitable hemisphere (οἰκουμένη, oikoumene).[3] In Greek mythology, this world-ocean was personified as a Titan, a son of Uranus and Gaea. In Hellenistic and Roman mosaics, this Titan was often depicted as having the upper body of a muscular man with a long beard and horns (often represented as the claws of a crab) and the lower body of a serpent (cf. Typhon). On a fragmentary archaic vessel of circa 580 BC (British Museum 1971.11-1.1), among the gods arriving at the wedding of Peleus and the sea-nymph Thetis, is a fish-tailed Oceanus, with a fish in one hand and a serpent in the other, gifts of bounty and prophecy. In Roman mosaics, such as that from Bardo he might carry a steering-oar and cradle a ship.
Some scholars believe that Oceanus originally represented all bodies of salt water, including the Mediterranean Sea and the Atlantic Ocean, the two largest bodies known to the ancient Greeks. However, as geography became more accurate, Oceanus came to represent the stranger, more unknown waters of the Atlantic Ocean (also called the "Ocean Sea"), while the newcomer of a later generation, Poseidon, ruled over the Mediterranean.
Hardware: Will be revelaed later.
Watercooling: The list is a little big but i will post it here later as well.
Now the part that you like of course...the PHOTOS:D:rock:
Unboxing of the case:
As i said previously it has lots of space to work with and for all the hardware i want to use in it.
Watercooling :
Just a little preview of some of the watercooling material and cabling i will use in the project,still missing a few details on the material as well,for it to be perfect and to route the watercooling loops as i desire
Now the most important,the sexy case photos :
Just look how small the mini-itx motherboard looks inside the case hahaha:D,and of course i think i migth rent some space of the case as a hostel if anyone is interested in speding some holidays in Portugal just ring me:D
The Diluvium project wouldnt be possible withouth the help of Aquatuning.de,many thanks to them,if you look for watercooling material for a build dont hesitate to drop by at their website!!
Supported by:
Regarding the case you can expect a facelift,start to the case paint,altougth i love black,i must change the color of it,the case is now at the paint shop:D
Got some fresh news for you!
Small preview of the case painting :
Frontal panel already painted
motherboard tray and side panel.
The painting is not finished yet! Hope you like it..;D
Hello,
Quick update before holidays:
Waterblock of a Gtx 770 and backplate,pushbuttons for the front panel,look how shiny the block is:D:rock:
Gaming:
Some headsets i own,wich should or will i use in this build???:D
And...the colour of the sleeving:
Wich of this colors should or will i use? can you guess?:D
Old August 18, 2014, 07:05 PM
ZZLEE's Avatar
I like red sleeving.
That many Rads will be overkill fore most set ups. :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old August 19, 2014, 07:27 AM
Yes i know that,i got many rads because i am an extreme watercooling user
Old August 19, 2014, 09:27 PM
Which of this colors should or will i use? can you guess?:D
Probably red and white....because CANADA
Old August 24, 2014, 03:56 AM
Bad Fenny's Avatar
Hey there,
Like the build so far . . .colour of sleeving? Well, given the theme, I would stick with blue, white and grey (ocean like colours). However, I do note your mobo tray is red so you could incorporate some red sleeving but I think it would be too much red IMHO.
Cheers
Fen
"Sic transit mundus" Thus the world passes
Old September 3, 2014, 12:15 PM
Yeah i like Canada too,im from Portugal but it would be great to live in Canada
Originally Posted by Bad Fenny View Post
Hey there,
Cheers
Fen
Yeah i guess you have a magic ball hahhaah
Maybe those will be the colors,blue or white or grey,who knows...but soon you will know what my choice was
Old September 3, 2014, 12:16 PM
A teaser of the case painting:
Front and the interior of the case:
Front panel of the case:
Interior and back panel of the case:
Front and interior of the case:
Side panel in wich there will be a Phobya 1080 rad.
So what do you think of the painting?
Still missing the tray and other minor parts of the case.
Old September 3, 2014, 06:17 PM
Father Fuzzy's Avatar
Paint looks good
Diggin the 1080 in there
keep up the good work
Old September 8, 2014, 05:35 PM
Front panel.
Interior blue and white as i desired!:D
Today the wheater was bad to take photos,but maybe in a few days i will have some better photos of the work that has been done
Old September 22, 2014, 01:57 PM
Update:
The Phobya case showing off the finished painting, exterior and interior was chosen the white color,and to highlight some parts of its interior was used the blue color, all four radiators were mounted withtheir fans, in this project i am using seventeen fans in order to achieve maximum performance of the water cooling system.
Sleeving color sample.
In this three photos you can see the quality of the painting and the future cable management.
Begining of the sleeving in a 21 pin white extension.
WIP Dual Rigs - Project "Calico" & Project "Apollo" Birk Case Mods, Worklog & Gallery 28 January 22, 2014 03:03 PM
Project: i7³ Lpfan4ever Case Mods, Worklog & Gallery 31 October 6, 2009 09:47 PM
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
