Old April 18, 2014, 01:39 PM
rjbarker's Avatar
Default Procyon Going Liquid
Just waiting on some Corsair SP Fans to install the upper 360 Rad (push / pull), lower 360 Rad is sort of push / pull, went with 5 of 6 Noctua NF F Series.....left one out on the end to make it a little easier with my plumbing.
The short length between my lower Rad and GPU Bridge was a bit of a bugger as they didnt line up perfectly....hopefully not too much side pull on those Rotary 90's.
So, get my 6 Noctuas, install upper Rad (now re-thinking whether I really need the additional 140mm Rad top / back), figure 2 x 360's push / pull should be adequate for CPU and SLi 780Ti's ?
Really like the EK Full Blocks....very simple to take apart the stock air cooler from the PCB and yes, I put all the original screws back in the air cooler ....the SLi Terminal Bridge makes them very rigid....friggin tiny O Rings in there...potential to over-tighten is huge I would think.
Anyhow....once I get the Rad up top installed, a couple of more tube runs and ready to leak test it....not till next week though
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old April 18, 2014, 02:06 PM
KaptCrunch's Avatar
UV light to kill bugs in liquid I like it
Old April 18, 2014, 02:37 PM
rjbarker's Avatar
Couple of regrets.....was so intent and purchasing and getting going I should have researched Rad types before purchasing the Swiftech XP's....lower FPI is what I'd rather have fr lower speed High Pressure Fans..too late now, not buying anymore gear!!!
Do you guys think it would make a big difference using 6 SP Corsairs up top vs 6 AF Corsairs up top....the SP's are there both the same RPM, but I think I'll be ale to run the SP's at a lower speed in push / pull vs the AF's in push / pull.....hence quieter.....I'm hoping to run all the Fans in my Rig at around 50%....I know this will be extremely quiet.
I do have 6 AF Corsair Fans I could use but expecting 6 SP's to be delivered on Tuesday....
What are your thoughts on adding another 140mm Rad to the back / upper....necessary or no ?!....At this point I'd rather not....
Timespy: 18.613K
MARK 11: 40.185K
Old April 26, 2014, 02:34 PM
hero1's Avatar
You are fine with what you have. You can keep the rads too. I wouldn't use the Corsair fans if you want a quiet environment.
Also, no need for another rad since 2 x 360 is more than enough.
Gallery Procyon II w Evga GTX 780Ti SLi rjbarker Case Mods, Worklog & Gallery 2 November 18, 2013 02:48 PM
Procyon II @ 5Ghz Tri 680 OC'd - Benchmarks rjbarker Overclocking, Tweaking and Benchmarking 3 October 27, 2013 09:36 AM
Procyon II - Last Upgrades 2013 rjbarker New Builds 3 September 10, 2013 10:29 PM
Procyon Is ALL Classy ;) rjbarker Video Cards 7 January 29, 2012 10:26 PM
Video: |Liquid Heaven| - |1090T X6 & 555 X2 Under Liquid Nitrogen| - |6.6GHz+| Slappa Overclocking, Tweaking and Benchmarking 3 June 18, 2011 01:23 PM
