Old January 24, 2014, 09:29 AM
lkramer's Avatar
Default i7-4770 and Dual R9 290X with Liquid Cooling in a Corsair 750D
i7-4770 and Dual R9 290X with Liquid Cooling in a Corsair 750D Build Log
First off, I would like to thank in advance for any and all feedback and support.
In this build, I will attempt to tame a hot running Haswell CPU and 2 fire breathing AMD Radeon R9 290X GPUs in Crossfire with a custom liquid cooling loop. This will be my first attempt at setting up one. I sure do hope this goes well!
I intend to use it as a workstation and for 4K gaming eventually (looking at getting the Dell 24" UP2414Q 4K monitor). I also want to achieve cool and quiet operation.
The Main Components
  • Intel Core i7-4770
    • I chose this processor because I need hardware virtualization support, and, as a developer, I may want to try out the transactional memory instructions.
  • MSI Z87-GD65 Gaming
  • 16 GB Kingston HyperX Black DDR3 1600 MHz RAM (KHX16C10B1BK2/16X)
  • 2 x AMD Radeon R9 290X Reference video cards
  • ASUS Xonar Essence STX sound card
  • Intel PCIe NIC (EXPI9031CTBLK)
  • 256 GB Samsung 840 Pro SSD (MZ-7PD256BW)
  • 1 TB HGST Travelstar 7K1000 (0S03563)
  • Seasonic X Series 850W PSU (SS-850KM3)
  • Corsair Obsidian 750D
Liquid Cooling Components
  • EK Supremacy CPU Block - Clean Acetal
  • EK Radeon R9 290X GPU Blocks with backplates
  • EK FC Terminal Dual Parallel 3-Slot
  • Swiftech MCP655 PWM pump
  • Koolance pump top with 60 x 120 mm reservoir
  • Alphacool NexXxoS XT45 Full Copper Triple 120mm radiator
  • Alphacool NexXxoS UT60 Full Copper Dual 120mm radiator
  • Phobya G1/4" Thread 3/8" ID x 1/2" OD compression fittings
  • Tygon A-60-G Norprene 3/8" ID x 1/2" OD (AFL00027)
Build Status
  • 2014-01-24: Picked up main components.
  • 2014-01-25: Picked up most of the liquid cooling parts.
  • 2014-01-26: Ordered remaining liquid cooling parts, fans and connectors.
  • 2014-01-26: Assembled and tested the main components.
  • 2014-01-27: Ordered fasteners.
  • 2014-01-29: Remaining liquid cooling parts arrive
  • 2014-01-30: Fasteners, fans and connectors arrive.
Last edited by lkramer; January 30, 2014 at 10:14 PM. Reason: Updated Build Status
Old January 24, 2014, 08:46 PM
lkramer's Avatar
Default UPDATE: The Main Components
I plan to drive to FrozenCPU tomorrow, in order to pick up most of the liquid cooling parts. I also look forward to ordering the remaining liquid cooling parts along with the fans, connectors and fasteners.
Old January 24, 2014, 09:01 PM
ZZLEE's Avatar
Build your toys up.
Build your system check that everything is working on air.
Use the motherboard box ( board on the cardboard top)
If somethings dodgy out of the box you want to find it now not when its under water.
Edit: 4770 not 4770K ??
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 24, 2014, 09:04 PM
lkramer's Avatar
Originally Posted by ZZLEE View Post
Build your toys up.
That was my plan for Sunday. I have a big brown cardboard box sitting on my desktop right now that I got from work today.
Old January 24, 2014, 09:06 PM
ZZLEE's Avatar
smart minds think alike.
Old January 25, 2014, 07:02 PM
lkramer's Avatar
Default UPDATE: Liquid Cooling Parts Part 1
More liquid cooling parts to come...
Old January 26, 2014, 10:23 AM
lkramer's Avatar
Yes, a 4770.
I would like to use the VT-d extension for my Linux VM but it is not a requirement. I also want to try writing software that uses the hardware transactional memory instructions. The 4770K does not have that extension or instruction set.
I did not plan to overclock this system anyway but I may try to undervolt the CPU for cooler and quieter operation.
Why does Intel always cripple their highest mid-range overclockable processor (asking rhetorically)?
I would pay an additional $20 or $30, maybe even $50, more than a 4770K for a processor that all of the features enabled and is overclockable.
Old January 26, 2014, 12:30 PM
ZZLEE's Avatar
I was not aware of Intel's Games
OK check :)
Old January 26, 2014, 01:15 PM
Bond007's Avatar
Great component selection. Keep us posted as everything unfolds. Should be a beauty!
Old January 26, 2014, 01:20 PM
lkramer's Avatar
Thank you.
It is currently sitting on a big brown cardboard box on my desk now. So far, everything works and it is installing Windows 8.1 right now. I will post some photos of it tonight.
Nzxt Phantom 530 or Corsair Obsidian 750D? Rest Cases 4 November 27, 2013 11:49 PM
Corsair 750D spare??? SAS Cases 5 November 26, 2013 11:56 AM
CES 2011: Corsair Chooses CoolIT to Produce Upcoming Liquid Cooling Products SKYMTL Press Releases & Tech News 13 January 9, 2011 12:21 AM
