Old January 6, 2014, 09:17 PM
sbohdan's Avatar
Default Case mod and WC build
So, I had an idea of building a nice watercooled rig for a long time now. Something that would have great cooling but was also quiet and pleasent to look at. I was postponing this project for about 3 years now and when I finally decided I will get on it - there was an unpleasent surprise of not being able to get the case I wanted. Danger Den a company well known among watercooling enthusiasts, that in my opinion had the most beautiful case I wanted, went out of business and by the time I noticed what happened, they were sold out and I couldn't find any of their cases - not even on eBay! This was the case I wanted to have for this project originally:
So, I just bought my second choice - a case that is also good looking but not at all in the same league with the DD - I got myself a NZXT Phantom white:
There was one problem though: The Phantom was never really meant for watercooling, even though a 240 rad is supported but was never meant for a 360 to be installed inside! The other problem was, that I have already bought a Denger Deen Black Ice GTX 360 on eBay, that was meant to be installled in the DD case's front:
Now I had a choice of eighter selling the Rad and getting 2x 240's to place one on the top and one on the bottom or... try to fit the GTX360 somehow. I have seen a mod in the past, where a 360 was installed on the top of a Phantom, but that rad was less than 3cm thick and mine was 54mm. That made it look impossible to fit with the fans on it, because the RAM and some motherboard heatsinks were interfering. On the other hand I did not want to cut the case. I still wanted to see if I could fit the RAd somehow because I did not want to give up the cooling performance of the GTX 360 if possible:
As you can see it did fit but only in a certain angle. There was no way it could go in straight and in the middle. I checked how the Rad would look like from the side and actually it is not too bad - you can't really see, that it is not straight.
So I decided to give it a shot. First I had to make some kind of a bracket to be able to install the Rad, since the 2x 200mm cutouts are not meant for 120mm fans. I simply got myself a white, thin piece of an aluminum sheet and started to do the measuring and cutting:
First I cut out the two asymetrical strips and made the holes to attach the radiator:
Next I had to do some additional adjustments and mark the holes to attach the brackets to the case:
Here you can better see, how the whole assembly is placed in an angle:
Next, I wanted to see if I could also install fans on top, to have a push-pull configuration, having 3 fans blowing from underneath and 3 other ones sucking the air from the radiator. The ones on the bottom came with the GTX360, that I bought used on eBay for $60 and I think it wasn't a bad deal, since the 3 Aerocool SILENT TURBINE FANS are silent, look good and have LED lighting in them and cost almost as much as I paid for them with the rad, so it's like having the Rad as a bonus :finga:
Next, I had to do some more cutting and drilling on the brackets, to have them match the Rad and include all the necessary holes:
Here is the whole assembly installed, just without the 3rd fan:
The 3rd fan can't fit, so I will install a 9cm fan there. It should be OK, since there is 1 fan pushing air from underneath anyway. I know this is a bit of a getto mod but if you read all the above, you can see how I really had no other choice if I wanted the GTX360 to be used in this project. Now, I will do something else on the case...
Main rig: NZXT Phantom modded case watercooled, Gigabyte GA-P67-UD4-B3, 2500K@4.7Ghz,1.428V, 8GB GSkill Sniper 2133Mhz 11-11-11-30@1.6V,
Gigabyte GTX960, Acer 24" 2ms, 2xOCZ Vertex4 128GB RAID0, Samsung 2TB; PC P&C 750W, Win7 Ultimate 64
Laptop: Dell XPS 1530 (T9500; 4GB 800 RAM; 120GB Crucial SSD; 8600GT; WIN7 64bit)
my 6800LE mod
Old January 8, 2014, 06:12 PM
sbohdan's Avatar
Now, I will do a little mod, to make this beautiful case a little sharper looking and more unique. So, this is what I had in mind: to have an NZXT logo cut out in the front door of the case. I was a bit worried before, 'cause the case is brand new, there are no scratches whatsoever, so I kind of felt reluctant to actually start cutting it but I decided, so I started by being as careful as I could. First, I removed the front door of the case and carefuly unscreved the inside part, so that only the white front part remained. Next, I taped the whole part around, to prevent any accidental scratches. Next, I downloaded a pic with the NZXT logo and printed it out, to have a template for the cutting. I used a little dremel set to cut the letters:
Now, it is not a laser cut but it is better than I thought it would be. This is a first time I have used a dremel and I feel it would be better next time. I have also cut out a seethrough strip of a clear acrylic and glued it on from inside to have a sort of window (preventing dust from getting in). It is sendwiched between the white outer shell and the black inside cover part.
Anyway, it is almost ready but not quite - I want to light up the inside with leds later on, so that the cut out logo would be glowing - probably a blue light would go with it, since the whole inside theme will be white, blue (the darkblue Primochill tubing ex. and the fan LED's) and black - unless I change my mind later on
my 6800LE mod
Old January 8, 2014, 07:26 PM
hero1's Avatar
That's awesome stuff. Subbed!
Old January 9, 2014, 12:56 PM
sbohdan's Avatar
Just warming up
I now have all the parts needed, except the new VGA (Zotac GTX 660Ti), which should be arriving in a week. here are the parts I have so far. Everithing uses the 1/2" ID and 5/8" OD:
Danger Den Black Ice GTX 360 Radiator
Danger Den Black Maze 5 GPU block
Danger Den Crystal Reservoir (Dual 5 1/4" Bay Reservoir)
Danger Den CPX-pro pump
Swiftech Apogee HD (black)
Primochill UV tubing blue (10')
Primochill anti-kink coils (2pc)
Bits Power Compression Fitting 1/2" ID 5/8" OD (8pc)
Antimicrobial silver coil
NZXT sleeved led kit (white)
Heater core radiator
mod/smart Power Supply Cable Sleeving Kit- White
home made retention brackets to hold the DD radiator
Now that I'm still waiting for my new VGA card, and since this is my very first WC project, I decided to put together a temporary WC loop with the old card and a clear tube, that I first purchased and also sleeve some cables. This will also help in cutting the proper lengths once I use the Primochill tubes. I can also do some alterations to the loop before I start putting together the final build:
my 6800LE mod
Old January 9, 2014, 08:21 PM
Fortier's Avatar
This is looking awesome, going to keep an eye on it
Old January 10, 2014, 02:42 PM
sbohdan's Avatar
Thank you
Seriously, I wasn't sure, before I made the first cut, if I didn't screw up and be left with a brand new case without the front door
Hell, I wasn't sure to the end if it works out. I think I will install a pair of LED's like this, to have the cut out glow with blue light:
my 6800LE mod
Old January 11, 2014, 05:40 PM
sbohdan's Avatar
I have removed the little HDD cage from the case, since I won't be using it and replaced the seethrough tubing with the Primochill UV blue ones and it was time for the leak-test
As you can see, I've put a towell on the PSU just in case of a bigger leak and little pieces of paper towell under the compression fittings to see if there are any leaks. So far (4 and a half hours) there are no leaks
Of course only the pump is connected to the PSU to be on the safe side..
I will leave it like that 'till tomorrow and if all is OK, will continue installing the LED strips and rest of the assembly. So far so good
my 6800LE mod
Old January 14, 2014, 04:14 PM
sbohdan's Avatar
So after a little glitch, I have proceeded to the final assembly of the rig.
Well to tell you the truth, there was a bit of a leak at the pump but half of a turn on the barb solved it
I was working today on the project and first I did cut about an inch from three of the tubes because they were too long. Of course I had to let out some water and refill the system again after :)
I also put the anti-kink coils on the tubes and I think they look great - better than I hoped anyway. I also did some sleeving and I did put most of the parts back in the rig and it was the first time I actually connected the power to the motherboard and turned on the system. There is still more work I will be doing but it already looks better than last time, so here are the pics:
And some sleeving:
I also placed little heatsinks on all the chips that are heating up on the motherboard - here are some of them:
I found the PCI-E wires to be ugly and not matching the rest of the inside, so I took a piece of a leftover tube and put them both in, then anti kinked them for the looks. Kind of looks like being part of the WC loop but of course it isn't This is how it came out:
I also did some wire management on the back. It is not pretty but now I can close the back side of the case without struggling with all the wires sticking out
More to come, so stay tuned
my 6800LE mod
Old January 14, 2014, 08:38 PM
I love the fact you have a heater core and barb fittings. Reminds me of when I started modding. Also great work on the logo. Two thumbs way up.
Old January 15, 2014, 10:59 AM
Kartner's Avatar
I like what you did to hide the PCI-E cables, looks good and very clever!
Considering my next build on same PC case ... GreenPC New Builds 43 April 14, 2012 02:53 PM
Which case for my build? jonnyavg Cases 7 January 8, 2012 09:58 AM
New Case/First Build. jakers11 Cases 7 January 11, 2011 09:36 PM
Moving Build to new Case impruv New Builds 2 January 12, 2010 10:28 PM
Case for i7 Build ImmaPC Cases 42 January 15, 2009 06:45 PM
