  #51 (permalink)
Old January 6, 2014, 01:33 PM
SugarJ's Avatar
It does. I got the transplant done, new tubing in, put the fan grill in and put a light in yesterday. I'll take some photos tonight.
  #52 (permalink)
Old January 6, 2014, 06:09 PM
sswilson's Avatar
Originally Posted by SugarJ View Post
Not a lot happened over Christmas, other than playing some BF4. And thinking to myself "Ivy Bridge is so last gen, the Cube needs to be more cutting edge!"
Sugar Cube, meet Haswell.
<image snip>
NCIX had a smoking deal on that mobo on Boxing Day, $140 off plus another $50 via rebate. Almost free, right?
Tomorrow is painting the dining room, but tomorrow night or Sunday there's some work going on in the Cube. Drain the loop, change the fittings on the rad, swap out the mobo and CPU, cut new tubing and reassemble. I've got a fresh bottle of Mayhems ready to go in, and then I'm down to lighting and sleeving.
Does that work on your better half? I've tried it a few times on mine with little success.... ;)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
  #53 (permalink)
Old January 6, 2014, 06:26 PM
Ya, gloss white shows every defect. Like I said, lots left to do on the paint but I wanted to get an idea of how the white looked before I spent another bunch of hours sanding and painting.
The only piece that looks almost done is the side panel. The steel took the lacquer very well.
I hear ya man... yeesh. White shows everything else so nice but shows everything ya don't wanna see either hehe.
Mine didn't turn out perfect either but its a lot better than what it was.
Mah Rig now
Mah Rig before
My stuff for sale.
  #54 (permalink)
Old January 6, 2014, 06:42 PM
SugarJ's Avatar
Nope. But my computer parts come out of my fun money allowance, her purse addiction comes out of hers.
Here's a shot with the new mobo in. This is without a flash, I have a 12" LED stick in there on top of the rad.
The fan grill fits, barely. The plexi window is actually touching it when the panel is on. I'm going to take the screws out and paint them white the next time I'm painting something. So now I'm down to sleeving. And deciding whether to put the R9 280X in there, but I'm waiting to see what Mantle does.
  #55 (permalink)
Old January 9, 2014, 08:25 PM
Fortier's Avatar
That fan cover is awesome
  #56 (permalink)
Old January 10, 2014, 11:54 AM
Caldezar's Avatar
The important question here is...
If you light the case from the inside, will it cast a HWC shadow on the wall?
  #57 (permalink)
Old January 10, 2014, 02:12 PM
SugarJ's Avatar
Funny you should ask, I was looking at the shadow cast on the wall last night. Because it's an LED light stick with about 20 LEDs in it across 12 inches, it doesn't cast a crisp shadow. You'd need a tighter grouping on the LED's or a single point source light.
  #58 (permalink)
Old January 10, 2014, 02:23 PM
ZZLEE's Avatar
Blinding white 5 Led Fan on max volts.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #59 (permalink)
Old January 10, 2014, 02:46 PM
Caldezar's Avatar
Bummer. Although you would at least be able to see the logo when looking directly at the fan. And the spinning fan blades should cut down the glare from the light a bit.
WIP Safe Haven The CUBE!!(Dual System Cube of the Gods) Soullessone21 Case Mods, Worklog & Gallery 80 February 10, 2014 08:37 PM
Corsair H100 or TT Big Water 760 Plus? siegfx Water Cooling 9 October 26, 2011 06:42 PM
Water Cooling a Corsair 700D Skippman Water Cooling 5 October 18, 2011 06:55 AM
Corsair RAM Water Cooling? AmuseMe Press Releases & Tech News 0 December 15, 2009 06:59 PM
