Old November 19, 2013, 02:44 AM
Father Fuzzy's Avatar
looks great SugarJ
I'm partial to that orientation
typhoons,monsoons...oh i'm in
Old November 19, 2013, 09:13 AM
SugarJ's Avatar
Originally Posted by Father Fuzzy View Post
looks great SugarJ
Typhoons, monsoons, cyclones oh my! Yeah, I'm really liking that with the window on top. If my pump fits to the right of the motherboard, it's definitely a go. I was too tired to grab a tape measure out of the garage after a dozen trips up and down last night so the suspense will have to keep until tonight.
Hmm, just had another thought. If it won't mount on the back wall, it should fit on what would be the side, where the top fans are supposed to mount.
Old November 19, 2013, 03:29 PM
3.0charlie's Avatar
There's a box in that shot that does not belong in this build...
Hydro-Quebec is salivating...
Old November 19, 2013, 03:36 PM
SugarJ's Avatar
Ssshh, it's off to the side, no one will notice. I bought a Z77 mITX board from 3.0 that arrived yesterday too. But that's another build log.
Seeing as I have to change the screws in the rad tonight anyways, I'm going to check if the rad will fit with the fittings up instead of down. It would make for shorter tubing runs wherever the pump gets mounted.
Old November 19, 2013, 11:21 PM
SugarJ's Avatar
Well, the pump wouldn't fit on the back wall, there isn't enough room between the fan and the side. So it was time to go out to the drill press and put a couple new holes in the mounting bracket.
A little out of focus, but you get the idea on where the pump is. Next was changing the screws on the rad fans to see if I could get the front grill back on.
Success! Notice that the case badge has mysteriously rotated. Damn straight, I love the look of this case in this orientation, it's staying.
Here's the old leak test shot:
I put paper towel under every fitting when I leak test, even the ones I didn't touch. Because I've been doing this for a few years and I use compression fittings, my leak test time is a lot less than 24 hours.
As you can see, there's not a lot of room left on the old Ikea Jerker I'm using in the spare bedroom after you put this thing and a U3011 on the desk. After New Year's I'm claiming back some space in our loft with room for a bigger desk.
Things left to do:
FEET! I need something under it. The PSU can draw lots of air through the back panel, but it looks funny without something under it.
PAINT! A sugar cube is white, not black. I'll take all the panels off and paint them, but the interior frame will stay black.
SLEEVING! My fingers are cramping up already and I haven't even started.
I also need a couple more Monsoon fittings for the rad, and I need a not-silver stop fitting for the top of the res. But enough for tonight.
Old November 19, 2013, 11:58 PM
glad to see it works out that way excellent
now I dont have to get one
Old November 20, 2013, 10:37 AM
lowfat's Avatar
What colours are you planning on using for sleeving?
Mael
Big Lian Li
Forever Alone
Old November 20, 2013, 10:54 AM
sswilson's Avatar
Looks great!!!!
Wrong time of year to be checking out your neighbors' trash for the "big" garbage pickup, but old junked stereo components often have some high end feet attached.......
So the pump/res is now firmly attached to one of the structural components of the case? I was a bit concerned that the first mount you showed might have transmitted pump noise through the case.
  #19 (permalink)
Old November 20, 2013, 11:44 AM
SugarJ's Avatar
It's a secret. I'm thinking white with some orange accents.
Originally Posted by sswilson View Post
Looks great!!!!
My major concern is that the side panel is so flimsy I don't want to put point loads in it. A brief look at the frame last night suggests that there might be enough meat in the little gussets in the corners that I could attach feet there, and run the case with out the side panel (now the bottom). More investigation is needed. And I have to take some stuff to the electronic recycling depot anyways, so I will check it out when I'm there.
Yes, the pump/res is now solidly attached to one of the fan mounts. A couple hours of use didn't give me any noticeable buzzing. I agree that I would have had to use some gel stuff or something on the mesh mount. That works for reservoirs no problem, but I haven't run a pump attached there before. If I had a 6-32 tap (and was keeping the case in the upright orientation), I'd actually have preferred to try to mount it to the mobo tray.
  #20 (permalink)
Old November 20, 2013, 12:23 PM
ZZLEE's Avatar
Lookken good with that orientation.
My desk realesstate is smaller than yours an much more cluttered.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
WIP Safe Haven The CUBE!!(Dual System Cube of the Gods) Soullessone21 Case Mods, Worklog & Gallery 80 February 10, 2014 08:37 PM
Corsair H100 or TT Big Water 760 Plus? siegfx Water Cooling 9 October 26, 2011 06:42 PM
Water Cooling a Corsair 700D Skippman Water Cooling 5 October 18, 2011 06:55 AM
Corsair RAM Water Cooling? AmuseMe Press Releases & Tech News 0 December 15, 2009 06:59 PM
