Old September 18, 2013, 08:47 PM
Default HP DC7100 Heatsink Problem
I'd like to put an HP DC7100S board back to work but I've got a problem with mounting the heatsink.
I managed to get the right thing - a Foxconn 364410-001 part - but I didn't get the under the board brace bit.
Thought I could use something else, any other brace. But it turns out the HP thing uses an oversize screw (bolt? what should we call them?) on the legs of the cooler assembly. They won't screw into any of the braces I've got.
It is a standard computer fastener size of some sort - I've got some standoffs that will screw onto those legs (bolts, screws..whatever) but I don't know what the measurement exactly is.
Did a lot of googling and contacted a number of places and ebayed and posted on forums but I can't find an underboard brace (what should I call them?) to fit yet.
Could I perhaps make one up I wonder?
Can anyone help at all?
Old September 18, 2013, 09:03 PM
KaptCrunch's Avatar
manual.pdf 6.18 see if same
Old September 19, 2013, 05:47 AM
Sure looks like it to me.
Here's a pic of mine:
Old September 19, 2013, 06:20 AM
KaptCrunch's Avatar
follow the manual and you be ok
question this going back to HP case or retail case ?
No bottom cpu bracket,
ah so if know a machine shop, or anyone with a tap set to re-tap your bottom bracket to HP thread
Tags
dc7100 heatsink brace
Could a hardware problem cause a driver problem? LaughingCrow Troubleshooting 4 January 19, 2012 11:46 AM
Steam connection problem (Problem Fixed) great_big_abyss Gaming 3 January 10, 2012 05:37 PM
Hard drive problem or Windows 7 Problem?! aeminence New Builds 4 October 13, 2011 06:46 AM
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 07:01 AM
Heatsink problem miggs78 Air Cooling 11 April 10, 2008 11:49 AM
