Old August 29, 2013, 03:34 AM
trodas's Avatar
Wink Point of View 7300GT gfx card recap
About four years ago I was confronted with this unfortunate fact, that computer witch I build for friend, started giving him troubles. The image on screen started going off, PC refuse to start, etc. After a while the PC get started in the end, but it was pretty clear, that once it will fail completely and it will be impossible to start it anymore. Not even with convincing the PC to start anymore.
This problem was the more embarassing for me by the fast, the my friend absolutely did no play games at all, so he is not stressing the gfx card much at all. That is why I picked up reasonably low powered (24W TDP) 7300GT with masive passive cooler for quiet operation. That is because in the case, there is a bit 120mm front fan, that at 7V spin pretty well and move cool air directly on the heatsink, right to the fins well orientated for it. So I expected a long life, despite the questionable caps (any cap, that is no genuine Rubycon, Nichicon, Samxon, Panasonic or Sanyo I call questionable if not outright bad... and yes, I did not like Chemicons and not consider them as good, but I could be mistaken or smeared away by bad personal experience with them, or more precisely - with likely fakes of them).
However the cause was embarassing for me the more, that I did the PC build from start to finish and has virtually only a little budget restrictions, so I was proud of the result and... this was just unexpected.
Not to mention that the GFX card itself looks cool:
After we discovered, that the waiting for RMA will took a month (and my friend was not cool with this and he fear, that after a month it will get his old card back because it works and that will be it), so we took a round to local shops in Prerov, yet not find anything that will be at least closely as usable and good as this card. So I get the idea, that I could try recap the card and see, if that helps. I suggested this, even none of the caps on the card are bulging or leaking at all. Yet they are still qestionable caps and there aren't that much of them on the card, so we decided to give it a try.
Rush was really big, so I did not even write down what caps are there in the first place, not even taking a picture of them. These pictures I made just after four years...
As you can see, I used a combination of what I had on hand. The bigger caps I replaced with Samxon GC caps, on the smaller ones I used Panasonic FM caps. I did not even added the missing cap. Also I did not optimized the voltages of the caps - at normal situation I measure the voltages that are really in action there and then use as close voltage and as big caps, as they fit there. Trying to make the voltage filtering better.
But as I was saying, there is not time. It was like a blitzkrieg. Yet despite the rush, the recap went fine and th card kicked on. And mainly - from this time on, the card is not giving any problems at all. I get to it after four years just because Mirek lend me it for testing, what works in my Sapphire A9RX480 mainboard. Because MSI GeForce 210 card do not...
So after four years of usage are there no signs of any problems, that with the questionable caps come just after one year and they are quite serious problems... And the graphic card is reasonably hot in run. Temperature just on the testing desk w/o any fan around is very high indeed:
So after years I checked up on my worn and come to conclusion, that it was not that bad, after all. So if anyone is recapping a Poing of View 7300GT gfx card, then he need something like that:
5x 1500uF 6.3V Samxon GC d10
4x 470uF 16V Samxon GC d6.3
2x 120uF 16V Panasonic FM d5
...or adequate replacements, like Nichicon HN/HM/HZ or polymer caps (Nichicon LE, FP...), where it will be necessary measure the actual voltages on the caps, because polymers are for 16V huge and hard to fit there. And I have my doubts that the 470uF 16V caps are under 12V. There is almost no way they will be. Usually the input voltages are used as low, as possible, to get as few voltage drop on the regulator, as possible, while this way is used to get as low heat output out of the regulators, as possible.
For example the two 1500uF caps on the back of the card will be for rams, so they are likely only up to 2.5V. And the 470uF 16V caps before them will be on the input of voltage regulator, likely powering from 3.3V or 5V rail. Hardly a point for 16V cap, IMHO... etc.
It can be optimized a lot :)
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old August 29, 2013, 07:25 PM
Perineum's Avatar
I haven't done this to video cards yet, but I've done quite a few motherboards now....
Old August 29, 2013, 09:13 PM
I have a recapped 8600GTS somewhere that I use as a spare card here and there. it's one of the asus silent models. sometimes sh1t just happens I guess. recapping doesn't always fix everything, sometimes there's more damage than what meets the eye, but it's worth a try for those times you get lucky. that's how I got my 4 matching 20" LCD monitors
Old August 30, 2013, 12:34 AM
trodas's Avatar
Well, not only mainboards have bad caps :) GFX cards and other hardware suffer from the very same problem often...
But it is true, that recapping is not a magical fix for everything. Especially not for LCD monitors - the lighting tubes could give up because of bad caps producing voltage spikes (or they are just get overused and die) and then recapping is not helping anything. You are lucky with your 20" monitors serie, stlouis1 :)
I tried and failed on BenQ FP737s-D ...
eVGA 7300GT dead fan snowbound Video Cards 6 February 2, 2010 06:45 AM
View from the Top [breitbart TV] gingerbee Off Topic 9 December 5, 2009 07:45 AM
X800XL or 7300GT? Dr_BenD_over Video Cards 8 October 27, 2009 04:55 AM
7300GT - Fan Failure Dr_BenD_over Troubleshooting 26 August 19, 2009 10:07 AM
'View All' not there? or am I missing it. biff Suggestions & Feedback 3 September 22, 2008 12:38 PM
