-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Completed Ergo Proxy (Water Cooled Case Labs SMH10) (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/61912-ergo-proxy-water-cooled-case-labs-smh10.html)
akira749 June 28, 2013 07:13 AM
http://www.lgti.ca/hwc/ergo-proxy.jpg
When I built the White Asylum rig with my first Case Labs case I wrote in one of my last posts that I was gonna order another CL case
to replace the case of the "New Beginning" rig which is a Mountain Mods one. Well here we go! A brand new Black SMH10!! :biggrin:
So here’s the new Build Log which feature the replacement of the current case with the current components BUT with some replaced one and some additions too…
This new build is called "Ergo Proxy" which was a manga aired in 2006 for only a season but I loved it very much. It will not be a tribute to the show.
I only took the name because I find it cool. The only thing that could ressemble the show and the case is "darkness". But you’ll have to add some UV to describe the case :biggrin:.
I hope you’ll like it so let’s go! :thumb:
Build setup/parts listing :
In Blue are the new parts
In Red are the already owned parts
Case and accessories
  • CaseLabs Magnum Black Matte SMH10 (reverse layout) with XXL Window
  • CaseLabs 120.3 Flex-Bay Rad Mount
  • CaseLabs 120.4 Side Rad Mount (2x)
  • Phobya Touch 6 Black Fan Controller
Components
  • Gigabyte GA-Z77X-UP5 TH Motherboard
  • Intel i5 3570K CPU
  • Corsair Dominator Platinum 16GB DDR3-2133 RAM
  • Corsair AX860i 860W 80PLUS Platinum PSU
  • EVGA GTX 770 SC w/ ACX Cooler (2x)
  • Samsung 840 SSD 250GB
  • Silverstone FP32B-E 3.5" USB3.0 Front Bay Device
Cooling
  • Gelid Wing 12 UV Green 120mm Fans (18x)
  • XSPC RX480 120.4 Radiator (2x)
  • XSPC RX360 120.3 Radiator (2x)
  • Swiftech MCP655-PWM-DRIVE D5 PWM Pump
  • Bitspower Dual / Single D5 Top Upgrade Kit 150 (Clear Acrylic Cap) Reservoir
  • Bitspower D5 / MCP655 Mod Kit - Matte Black Finish
  • Primochill Anodized Green Rigid Ghost Compression Fittings 1/2"OD
  • PrimoChill 1/2"OD Rigid Acrylic Tube Clear
  • PrimoChill Vortex Black POM Visual Flow Indicators - UV Green Faceplate
  • EK Supremacy CPU Waterblock - Plexi-Nickel Clean CSQ
  • EK-FC770 GTX - Nickel GPU Waterblock (2x)
  • EK-FC Titan SE Backplate - Black (2x)
  • EK-FC Terminal DUAL Parallel 3-Slot
  • Mayhems X1 UV Emerald Green Coolant
Sleeving
  • MDPC-X Titanium Grey MKII
  • MDPC-X Toxic Green
akira749 June 28, 2013 07:14 AM
Final pictures thanks everyone! :punk:
http://www.lgti.ca/hwc/IMG_3439s.jpg
http://www.lgti.ca/hwc/IMG_3444s.jpg
http://www.lgti.ca/hwc/IMG_3449s.jpg
http://www.lgti.ca/hwc/IMG_3452s.jpg
http://www.lgti.ca/hwc/IMG_3453s.jpg
http://www.lgti.ca/hwc/IMG_3468s.jpg
http://www.lgti.ca/hwc/IMG_3469s.jpg
http://www.lgti.ca/hwc/IMG_3471s.jpg
http://www.lgti.ca/hwc/IMG_3472s.jpg
http://www.lgti.ca/hwc/IMG_3475s.jpg
http://www.lgti.ca/hwc/IMG_3476s.jpg
http://www.lgti.ca/hwc/IMG_3481s.jpg
akira749 June 28, 2013 07:24 AM
Here's the first pictures
That's a BIG box!!!
http://www.lgti.ca/hwc/IMG_3092s.jpg
Completed case :punk:
http://www.lgti.ca/hwc/IMG_3114s.jpg
A preview of the new things that will go in the SMH10
http://www.lgti.ca/hwc/IMG_3099s.jpg
http://www.lgti.ca/hwc/IMG_3105s.jpg
Since the fans I wanted were less expensive at FrozenCPU I had to order there and I receive this in my shipment...:haha:
http://www.lgti.ca/hwc/IMG_3102s.jpg
Father Fuzzy July 25, 2013 08:29 AM
Very nice case Sir!
and alot of goodies
awesome:punk:
onin July 25, 2013 08:33 AM
That is a lot of green... awesome
akira749 July 25, 2013 09:25 AM
Thanks guys! :thumb:
The build is slow for now due to a lot of work. But my vacations starts tomorrow so I'll finally have free time!!! :biggrin:
sswilson July 25, 2013 09:42 AM
Wowzers!!!!! No shortage of radiator square footage going on there..... :)
Looks like some great parts, and I suspect we'll get a feel for just how massive that case is by the time the build is done. It might seem like a small thing but I'm impressed with the fact that they shipped the case with the plexi / lexan protective paper still affixed to the window.
akira749 July 25, 2013 01:48 PM
"No shortage of radiator square footage" I like that :biggrin:
About the protective paper, it's indeed not a small thing. I think it reflect the kind of detail that CL is heading for and I like those little details. And the window is secured with bolts so you just have to unscrew them, remove the protective paper and screw your window in place. Very neat!
hero1 August 2, 2013 09:13 AM
I am itching to see this thing put together:clap:
P.S: I have been looking for an awesome case and I am very picky. I am waiting for the Phatenks Enthoo Primo but seeing the SMH10 makes me want to just go ahead and order it. I hate deciding so I will play eenie meenie ma ne mo!:haha:
akira749 August 2, 2013 05:00 PM
Okay finally some updates on this build :biggrin:
In the last days I installed the radiators and fans. Everything is wired to the fan controller and the molex extension for the controller is done too. I tested the setup and everything is working fine! :thumb:
Here are a few pictures. Sorry for the lightning spots on the pictures :angry2: I hate myself when I see this...
The 360mm on the PSU side
http://www.lgti.ca/hwc/IMG_3185s.jpg
Front 360mm
http://www.lgti.ca/hwc/IMG_3187s.jpg
Both 480mm on the top and on the motherboard side
http://www.lgti.ca/hwc/IMG_3191s.jpg
Just another angle for fun :haha:
http://www.lgti.ca/hwc/IMG_3192s.jpg
This is what I call TIGHT!!!! :shok: :punk:
http://www.lgti.ca/hwc/IMG_3197s.jpg
This one is just to give you an idea of where the pump/res should be
http://www.lgti.ca/hwc/IMG_3198s.jpg
I'm still waiting for my Primochill stuff to arrive. After almost 2 weeks the Customs finally released the package today....bunch of :censored:
have a nice day!
