  #51 (permalink)
Old August 13, 2013, 06:28 AM
XNine's Avatar
Manufacturer Rep
Originally Posted by lowfat View Post
Congrats on the mention. Always feels good when you get mentioned by a manufacturer.
From looking at the compression fittings for the acrylic, it seems that there is a small space around the compression ring and the acrylic tube. Do you think I'd be able to fit sleeving under the compression ring or no? I've already ordered a bunch but it won't arrive for at least a few weeks.
You're a moderator here now? Woooooooooah. Congrats! :) And I'm the new CaseLabs Rep... funny how things change in this industry, eh?
Originally Posted by akira749 View Post
Thanks! I have to say that I was very surprised!
For the sleeving, I wasn't sure so I tried it and unfortunately it won't fit
There's indeed a small gap but not enough for a layer of sleeve. I used MDPC, I don't know if another brand would be thinner but I don't think so.
Yeah, I've been looking into doing sleeve as well, unfortunately from what I've heard these fittings won't accomodate sleeve as it's a pretty tight squeeze with just the pipe, unless one were to file down the pipe itself.... hmmmm.
Keep up the great work. I'm not a fan of the color green, myself, but you make it look goooooood!
CaseLabs Media Machinist
  #52 (permalink)
Old August 13, 2013, 06:44 AM
akira749's Avatar
Thanks! I like to try different color themes. So far I did Red on the SM8, White on my bench and now Green on the SMH10....Who knows what color theme will be the next one....let's say an mATX build of some sort
  #53 (permalink)
Old August 13, 2013, 06:46 AM
akira749's Avatar
Hi,
I did some test last night with a couple UV sources to see how it will look.
Here's an example...
  #54 (permalink)
Old August 13, 2013, 06:55 AM
akira749's Avatar
Originally Posted by nasrott View Post
thinking of redoing my ufo2 with this tubing and fittings, you have a link to this stuff, guess is primochill in europe?
Primochill is a US based company
You can buy their stuff at FrozenCPU, Performance PCs, etc...
Here's some links on the FrozenCPU website.
The compression fittings
The acrylic tubing
I hope it helps
  #55 (permalink)
Old August 13, 2013, 08:27 AM
Ultima_weaponx's Avatar
Hi,
I love the UV reactive surfaces/lighting!
This will look so cool (and radioactive) with a filled loop!
  #56 (permalink)
Old August 13, 2013, 10:06 AM
akira749's Avatar
I received my new PSU!
Let the sleeving begin!!
  #57 (permalink)
Old August 13, 2013, 01:00 PM
Ohh the Flextronics based ax860i. Very nice!
I look forward to seeing how the sleeving turns out, especially with your UV reactive build
  #58 (permalink)
Old August 13, 2013, 01:07 PM
akira749's Avatar
I really like this PSU. I already have one in my SM8. It's easy to sleeve. Only one double crimped wire on the 24 pin...the rest is 1:1
  #59 (permalink)
Old August 13, 2013, 01:18 PM
hero1's Avatar
Nice stuff man. Keep them coming. Your build and lowfat's Lian Li+ has me thinking about modding my case to some extent.
  #60 (permalink)
Old August 13, 2013, 03:40 PM
Father Fuzzy's Avatar
oooo nice UV shot
those fans look sweet
Best Water Cooled Case For Workstation 1-2 GPU Max JG23 Water Cooling 7 November 6, 2011 09:21 AM
Kingston HyperX Labs - Water Cooled RAM Soultribunal Press Releases & Tech News 2 January 1, 2010 12:28 PM
[FS] FS:2x EVGA GTX260 SC|4GB OCZ Reaper DDR3 PC3-1600|SunBeam Water cooled Plexi UV Case. MarcusFoX Buy/Sell & Trade 9 October 22, 2009 11:07 AM
[FS] FS: i7 920 D0 EVGA GTX280 & SunBeam Water cooled Plexi UV Case. MarcusFoX Buy/Sell & Trade 21 October 8, 2009 07:34 AM
Water Cooled Case Gallery! cyberspyder Water Cooling 5 September 19, 2007 12:11 PM
