Hello everyone!
A very little update since I did very little on the build today.
I installed the green LED power and reset switches which I have no pictures since it's pretty straight forward
After that I receive a small order from Dazmode to be able to complete the connection of the 2 bottom rads and also installing the drain plug.
You will see in the pictures that I didn't bind any acrylic there not because I was too lazy but for practical reasons. The bottom port on the RX360 will be squeezed in a bunch of wires from the PSU so I wanted this part to be more solid for security reasons. The bottom port on the RX480 must hold the drain plug so I can't bend all the way through the radiator. But at least there's a straight piece of acrylic and 2 sweet Ghost fittings in there.
Here are the pictures of the completed job...
Have a nice evening!
