  #101 (permalink)
Old October 26, 2013, 09:26 AM
Bungwirez's Avatar
whew.... I thought I was the only one this ever happens too.
great finish Akira.
  #102 (permalink)
Old October 26, 2013, 01:00 PM
akira749's Avatar
Originally Posted by XNine View Post
Originally Posted by akira749 View Post
Thanks guys!!
I dismantled the rig to see what was going on with the motherboard and now it's fine!!! So it's a relief!!!!
This build is really done now
It's always SOMETHING, isn't it? I can't tell you how many hours I've had to troubleshoot builds and the problem being one wire, one screw, one twist of a fitting. Bah!
You can say that XNine! This time it was probably my CPU block that was too tight and was bending the board or I don't know what
great finish Akira.
Don't worry Bungz you're not alone! On a previous rig it was a motherboard standoff problem and now this wierd one
Thanks
  #103 (permalink)
Old October 26, 2013, 01:03 PM
hero1's Avatar
I'm assuming that all is well now.
  #104 (permalink)
Old October 26, 2013, 06:17 PM
akira749's Avatar
Yes it's finished and running great
  #105 (permalink)
Old October 30, 2013, 06:39 PM
Hanoverfist's Avatar
Super Build with sharp pics...Top Shelf for sure.
Nice work Akira.
  #106 (permalink)
Old October 30, 2013, 07:04 PM
akira749's Avatar
Thanks Hanover and welcome on HWC!!
  #107 (permalink)
Old October 30, 2013, 08:36 PM
Birk's Avatar
Loorks awesome! great job :)
  #108 (permalink)
Old October 31, 2013, 10:16 AM
akira749's Avatar
Thanks
  #109 (permalink)
Old June 21, 2014, 11:33 PM
lutro0's Avatar
I did my 24-pins and tested it to see if everything will fit with the rad and it did!!
I had one double wire to do and I decided to try the method Lutro0 showed in his video and it worked like a charm!
Here's the result...
-snip-
The rest of the sleeving job will be done soon
Great follow through with the guide! Keep up the good work! The double wire method can be used with many cables if you need to use it. I just finished a huge job for Nvidia and basically all of the 8&6pin cables had to be doubled but they turned out great.
Best Water Cooled Case For Workstation 1-2 GPU Max JG23 Water Cooling 7 November 6, 2011 09:21 AM
Kingston HyperX Labs - Water Cooled RAM Soultribunal Press Releases & Tech News 2 January 1, 2010 12:28 PM
[FS] FS:2x EVGA GTX260 SC|4GB OCZ Reaper DDR3 PC3-1600|SunBeam Water cooled Plexi UV Case. MarcusFoX Buy/Sell & Trade 9 October 22, 2009 11:07 AM
[FS] FS: i7 920 D0 EVGA GTX280 & SunBeam Water cooled Plexi UV Case. MarcusFoX Buy/Sell & Trade 21 October 8, 2009 07:34 AM
Water Cooled Case Gallery! cyberspyder Water Cooling 5 September 19, 2007 12:11 PM
