  #91 (permalink)
Old September 25, 2013, 12:35 AM
trodas's Avatar
One leak gone, another up for testing - congratulations! :) I think you will be fine this time... fingers crossed!
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
  #92 (permalink)
Old October 4, 2013, 10:46 PM
Father Fuzzy's Avatar
Did you have any luck with the rad area leak?
Insanely awesome rig you have built there
  #93 (permalink)
Old October 5, 2013, 08:01 AM
akira749's Avatar
Good god you must have devine powers!!! I didn't update in around 2 weeks and this morning I will end up my final leak phase and boom you ask for an update.
Of all the builds I made this one cause me the most issues in leak tests that I ever encountered.
The first time (2 weeks ago), the flow indicator and the top rad were the issues. Those 2 were fixed. The flow indicator was fine it was just me who didn't thight enough the covers so the o-rings didn't do their job. For the rad I simply switch the fitting for another in my loop and carefully screwed the fitting in place and it was okay. Since I re-use the "faulty" fitting in the loop and that everything is good now I must assume that it was me that didn't screw the fitting correctly the first time even if it looks like it was okay?!...After fixing this I re-filled my loop and started leak tests and then.....leak from a GPU block. I jumped on the BST thread and bought the same one from a fellow member.
The second time (a week ago), I replaced the GPU block and re-filled my loop and started yet another leak test....guess what another leak?!?!?.........from where.....THE OTHER GPU BLOCK!!!!!!!!!!I couldn't believe it!! I never broke any plexi or acetal block in my life and 2 in the same build!!! The day before I put an order at Daz so I jump on my keyboard to check if Daz had the block in stock and it did!! I emailed Daz on a saturday night to see if he could ship me the block with my order and guess what he answered me within the hour this guy is the real deal!!!!!!
The THIRD time (yesterday), I installed the new GPU block then re-filled the loop again and it's as now been running for 15 hours without an issue
So later today I will flush it and fill it with Mayhems
And then....PHOTOS!!!
  #94 (permalink)
Old October 5, 2013, 08:14 AM
Thats good news akira
really lookin forward to seeing your pics of this stellar build
glad you got the leaking fixed and Daz's service is second to none
  #95 (permalink)
Old October 6, 2013, 08:46 AM
akira749's Avatar
The build is "Done"....
The reason i'm quoting it is because even if the build is completed the motherboard looks like it failed on me.
So the pictures are taken but the rig will be temporary dismantled for investigation and when it will be put back on this rig will become another folder since I already switch my main daily/work/gaming setup in my new S5 (build log soon)
I'm really happy on how it turns out the Mayhems X1 UV Emerald Green is freaking nice it looks like Prestone in daylight which is a near perfect match with the Gelids!!! And in the dark under UV it glows cool
You can see the final pictures in the second post right HERE
Have a nice day!
  #96 (permalink)
Old October 6, 2013, 09:06 AM
Great work Akira
shame about the mobo,maybe it'll perk up
everything looks super deluxe
coolant is wicked
those casefeet are Beautiful
photo's are sweet...really top notch build Sir!
  #97 (permalink)
Old October 6, 2013, 10:48 AM
nasrott's Avatar
Ya nice job Akira, looks sweet.
  #98 (permalink)
Old October 6, 2013, 01:17 PM
akira749's Avatar
Thanks guys!!
I dismantled the rig to see what was going on with the motherboard and now it's fine!!! So it's a relief!!!!
This build is really done now
  #99 (permalink)
Old October 6, 2013, 01:18 PM
sswilson's Avatar
Great to hear you got everything working right. That's an amazing build!
  #100 (permalink)
Old October 26, 2013, 08:43 AM
XNine's Avatar
Manufacturer Rep
Originally Posted by akira749 View Post
Thanks guys!!
It's always SOMETHING, isn't it? I can't tell you how many hours I've had to troubleshoot builds and the problem being one wire, one screw, one twist of a fitting. Bah!
CaseLabs Media Machinist
Best Water Cooled Case For Workstation 1-2 GPU Max JG23 Water Cooling 7 November 6, 2011 09:21 AM
Kingston HyperX Labs - Water Cooled RAM Soultribunal Press Releases & Tech News 2 January 1, 2010 12:28 PM
[FS] FS:2x EVGA GTX260 SC|4GB OCZ Reaper DDR3 PC3-1600|SunBeam Water cooled Plexi UV Case. MarcusFoX Buy/Sell & Trade 9 October 22, 2009 11:07 AM
[FS] FS: i7 920 D0 EVGA GTX280 & SunBeam Water cooled Plexi UV Case. MarcusFoX Buy/Sell & Trade 21 October 8, 2009 07:34 AM
Water Cooled Case Gallery! cyberspyder Water Cooling 5 September 19, 2007 12:11 PM
