-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Completed EkLeCt1k (Water Cooled Mountain Mods Extended U2-UFO) (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/61842-eklect1k-water-cooled-mountain-mods-extended-u2-ufo.html)
akira749 June 24, 2013 04:35 PM
http://www.lgti.ca/hwc/eklectik.jpg
The White Asylum rig was my first attempt at folding and I have to admit that I kinda dig the concept :biggrin: so I decided to build a second folding rig!
So here it goesÖ
This new build is called the ę Eklect1k Ľ simply by itís cooling components origins.
First you have to understand that I donít usually use a ton of brands on a single build. Maybe 6-7 including tubing and coolant.
And this time itís a stunning 13 brands if you count the Phobya Bench :haha:. And also in this build it will be a mix of new, used and already owned components.
Thatís a very eclectic build and since I wanted to add an eclectic touch even in the name. So gamertag style it was :thumb:
Build setup/parts listing :
In Black are the new parts
In Blue are the already owned parts
In Red are the used parts (from HardwareCanucks and Overclock.net fellows and also from Ebay)
Case and accessories
  • Mountain Mods Extended U2-UFO
  • NZXT Sentry Mesh Fan Controller
Components
  • ASUS Rampage III Black Edition Motherboard
  • Intel i7 980x CPU
  • Crucial Ballistix Tactical Tracer 12GB DDR3-1600 RAM
  • NZXT HALE90 V2 Series 1200W 80PLUS Gold PSU
  • XFX HD7970 Black Edition Video Card
  • HIS IceQ X2 HD7970 Video Card
  • Sapphire HD7970 Video Card
  • WD VelociRaptor 150GB 10000rpm HDD (2x) in Raid 0
Cooling
  • Swiftech Helix 120mm Fans (12x)
  • XSPC Xinruilian 1650rpm 120mm Fans (6X)
  • Alphacool NexXxoS UT60 120.3 Radiator (2x)
  • Magicool HEXA720 120.6 Radiator
  • Alphacool D5 Vario Pump
  • Monsoon Series Two D5 Premium Dual 5.25Ē Reservoir
  • Koolance Black Compression Fittings 1/2"ID x 3/4"OD
  • Koolance Black QD4 Quick Disconnect 1/2"ID x 3/4"OD
  • Koolance Black 90 degrees Swiveling Angle Fittings
  • PrimoChill PrimoFlex Advanced LRT 1/2"ID x 3/4"OD Clear
  • MIPS ASUS Rampage 3 Black Edition Fullcover POM Motherboard Waterblock
  • XSPC Raystorm CPU Waterblock
  • Swiftech KOMODO-HD7970 GPU Waterblock (3X)
  • Swiftech CrossFireX 3X Bridge for Komodo HD7900
  • Mayhems Pastel Ice White Coolant
Sleeving
  • MDPC-X Shade 19
  • MDPC-X White
EDIT :
I decided to switch the rig into a closed case. So I resurrected my Mountain Mods Extended U2-UFO :haha:
Also recently I removed the 580's and the 560 Ti's and replaced those 4 GPU's with 3 Radeon HD7970 :punk:
akira749 June 24, 2013 04:36 PM
Reserved for final pictures!
Here are the completed build...:thumb:
EDIT : Pictures of the completed upgrade HERE
http://www.lgti.ca/hwc/IMG_3166s.jpg
http://www.lgti.ca/hwc/IMG_3167s.jpg
http://www.lgti.ca/hwc/IMG_3168s.jpg
http://www.lgti.ca/hwc/IMG_3169s.jpg
http://www.lgti.ca/hwc/IMG_3170s.jpg
http://www.lgti.ca/hwc/IMG_3173s.jpg
http://www.lgti.ca/hwc/IMG_3174s.jpg
http://www.lgti.ca/hwc/IMG_3176s.jpg
http://www.lgti.ca/hwc/IMG_3178s.jpg
http://www.lgti.ca/hwc/IMG_3179s.jpg
http://www.lgti.ca/hwc/IMG_3181s.jpg
http://www.lgti.ca/hwc/IMG_3184s.jpg
Thanks to those who subscribe!!! :clap:
akira749 June 24, 2013 05:05 PM
Here's the first pictures :haha:
Before going under water I had to test if the motherboard, the CPU and the 2 GTX 580 were all working well so I tested them on air (except my trusty H100 since the CPU didn't come with a HSF)
http://www.lgti.ca/hwc/IMG_3046s.JPG
The result was successful for everything! The CPU is overclocked at 4.2-4.3GHz. I also did a folding test with the CPU only and it was quite nice.
Here's a picture of the stock I have to stuff in this build :punk:
http://www.lgti.ca/hwc/IMG_3065s.JPG
That's all for now...more updates tomorrow :thumb:
Oh! by the way...we have got to love Phobya :clap:
http://www.lgti.ca/hwc/IMG_3066s.JPG
Bungwirez June 26, 2013 12:34 PM
Really love the MIPS block... too bad they folded.
Pabz0r545 June 26, 2013 12:59 PM
This build looks promising! Eagerly waiting completion. mmmm Phobya gummies. I LOVE Aquatuning.
akira749 June 26, 2013 03:05 PM
Yeah too bad :sad: and the block look awesome! Picture below :thumb:
:biggrin:
Okay yesterday's update!
I removed the stock heatsinks on the motherboard to replace it with the MIPS waterblock. I have to say this block look is stunning!
BEFORE
http://www.lgti.ca/hwc/IMG_3068s.jpg
NAKED
http://www.lgti.ca/hwc/IMG_3069s.jpg
AFTER
http://www.lgti.ca/hwc/IMG_3072s.jpg
Sorry for the blurry pictures :doh:
Second job was the installation of the blocks on the 580's...and I hit a "rock" :blarg:
The first one was the Heatkiller and it was a charm to install and DAMN it looks good :biggrin:
The second one was the Aquacomputer one and this is where I hit a "rock"...one of the screw post near the processor failed on me and I still don't know how. So I went online and bought a second Heatkiller and since I will have 2 Heatkiller block I also bought a Heatkiller bridge :thumb:....so this little "rock" cost me some money but it is what it is...
Here's some pictures of the GPU's
The 2 GTX 580 with the blocks (of course the one with the Aquacomputer block is for archive now :bleh:)
http://www.lgti.ca/hwc/IMG_3073s.jpg
And the precious :biggrin:
http://www.lgti.ca/hwc/IMG_3079s.jpg
Here you see what broke on the Aquacomputer block
http://www.lgti.ca/hwc/IMG_3080s.jpg
That's all for now. Next step is CPU block and radiators/fans installation...
I leave you with an artsy shot just for the kick of it :thumb:
http://www.lgti.ca/hwc/IMG_3083s.jpg
bjcsoln June 26, 2013 03:59 PM
Damn, those HeatKiller blocks look amazing. I was so close to purchasing them for my rig (for a GTX 680) as they also have a sweet looking back-plate. Sill not sure if I made the right choice going all acrylic (with EK blocks) - the Heatkillers would've fit in brilliantly with a shining silver theme.
akira749 June 26, 2013 04:56 PM
Sure EK and Heatkiller are different in terms of look but you won't be disapointed with EK blocks...I usually only have EK waterblocks on my GPUs
shirazi_r June 26, 2013 05:08 PM
I'm sorry but that's not even close to enough fans...... :haha:
akira749 June 27, 2013 08:05 AM
I'm not sure what you mean but there's 12 fans for 2 360mm rads in push-pull...
