-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Completed Yet another HAF 932 Water Cooling Build (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/59847-yet-another-haf-932-water-cooling-build.html)
Rollergold February 23, 2013 05:31 PM
This is not a build from the ground up per say. Its more of a transition from a AIO cpu cooler and stock video card air coolers to putting both the CPU and GPU's under a custom loop. This is also my first custom loop so go easy on me, still lots to learn.:thumb:
Hardware:
  • Cooler Master HAF 932
  • Corsair HX 850 PSU
  • Asus P6X58-E WS
  • Core i7 920 @ 4.01ghz
  • 24gb (3x 8gb) Corsair Vengeance Black 1600 RAM
  • 2 EVGA geForce GTX 680 SC's in SLI
  • 4 1TB Western Digital Caviar Black Drives
  • Creative Sound Blaster Recon 3D PCIe
  • LG Blu-Ray Writer
Cooling:
  • Swiftech Apogee HD CPU Block
  • 2 XSPC Razor GTX 680 Full Cover Blocks
  • Alphacool NexXxoS UT60 Full Copper Triple 120mm Radiator & Alphacool NexXxoS XT45 Full Copper Single 120mm Radiator
  • Swiftech Maelstrom Reservoir
  • Swiftech MP655-SE Pump
  • 12 Swiftech Lok-Seal 5/8th OD, 3/8th ID Black Compression Fittings, 2 Swiftech Lok-Seal 90 Degree Elbow Fittings, 2 Swiftech Lok-Seal 45 Degree Elbow Fittings and, 1 41mm to 65mm adjustable chrome SLI Lok-Seal Fitting
  • Tygon 3603 5/8th OD, 3/8th ID tubing (Yes I know of its leeching issue, going to replace it something different come system flush time).
  • Primochill PC PURE clear coolent
http://i300.photobucket.com/albums/n...ps79a0b5d3.jpg
Overview of most of the hardware I used (I didn't use the Primochill tubing however)
http://i300.photobucket.com/albums/n...pscf35a32d.jpg
Close up of the cooling. parts The Koolence QDC's O-Rings broke after I connected the two together :dots:
http://i300.photobucket.com/albums/n...ps62a01a01.jpg
Close Up of the Apogee HD
http://i300.photobucket.com/albums/n...psc4a5ca4f.jpg
With her compression fittings installed.
http://i300.photobucket.com/albums/n...psc3dd5212.jpg
Close up of the bay res.
http://i300.photobucket.com/albums/n...psbb5785d7.jpg
What the SE in MP655-SE allows the user to do. (I ended up also using a 90 degree elbow fitting on the inlet instead of the just the compression fitting)
http://i300.photobucket.com/albums/n...psc2ca9639.jpg
What came in the boxes for my XSPC Razor blocks. I kept the plastic shielding on the blocks (until install) so to keep that nice brushed aluminum finish intact
http://i300.photobucket.com/albums/n...psf0e682c2.jpg
http://i300.photobucket.com/albums/n...ps27303bf1.jpg
http://i300.photobucket.com/albums/n...psb1523b7b.jpg
Close ups of the blocks and SLI fitting installed on the cards
http://i300.photobucket.com/albums/n...ps32f3202c.jpg
Ended up moving the compression fitting to the top connection instead of facing away from the block.
http://i300.photobucket.com/albums/n...ps78a42b84.jpg
Overview of all the installed blocks
http://i300.photobucket.com/albums/n...s3c467f1a.jpeg
3 hours in to the leak testing with one of the heaviest "external" PSU's I have :haha:
http://i300.photobucket.com/albums/n...ps83bd53f1.jpg
http://i300.photobucket.com/albums/n...ps9b1dcec2.jpg
Pictures of the finished product.
Also is it just me or was anyone else just a slight bit nervous when they switched on their first custom loop for the first time? I spent over 8 months researching and planing, the system passed its 24+ hour leak test with ZERO leaks but even then I just a little nervous when I pushed the power button for the first time.
Overall though I'm happy with the result, had a few leaks with some defective elbow fittings (they leaked where they swivelled :blarg:) but the system passed its leak test after I replace them (I did 30 hours + an external PSU just to be safe), and the near silence of the system is golden :thumb:
dandelioneater February 24, 2013 12:21 AM
Looks good for a first custom water build. The drop in acoustics is like night and day when you switch over the first time. :-P
Rollergold February 28, 2013 01:59 AM
True that :thumb:. Too bad my top GTX 680 has moderate case of coil whine (when under load) and my side 230mm fan has also decided to whine a little bit now :blarg:. I have rubber fan mounts for the 230mm fan but guess I got unlucky with my top 680 =[
Nate-CM February 28, 2013 12:09 PM
Thank you for choosing Cooler Master.
There can never be too many HAF 932 WC builds.
Rollergold February 28, 2013 06:20 PM
Lol True that :haha:. Its Amazing how much space the 932 had for liquid cooling considering the price and when the case was released. Now if it only came with standard dust filters :whistle:
Matterhorn July 8, 2016 01:09 AM
Hey Rollergold.. Ive got a HAF 932 as well that Im planing on water cooling. Just curious if the NexXxoS UT60 Triple & XT45 single Radiators were enough to keep your system cool?
Im planning on building a water cooling loop for an AMD FX-8350 8 core and dual 980ti's in SLI
I wonder if what you have here would be enough for if I should think about external rads.. there really isnt much room for more rads than that inside the case if you want to keep all your drive space like I do
