  #21 (permalink)
Old February 9, 2013, 05:49 PM
Soullessone21's Avatar
Originally Posted by ZZLEE View Post
Dora the Explorer bet she has 9 lives.
Jake and the never land pirates, those A holes cost me more computer down time then BSOD or forum trolls that force me to walk away instead of reaming into them.
looks like this build should see like or at least its premature birth next week :P haha.
It will be lots of fun and a good use of tons of my gear :D
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
  #22 (permalink)
Old February 9, 2013, 07:49 PM
JD JD is offline
SketchUp has a bunch of user-based models that have already been drawn. Like 120mm fans, 5.25" DVD drives, 3.5" HDDs, ATX motherboards, etc.
Makes designing cases much easier I'd say, and it's why most people use it.
For example, Mountain Mods ATX Motherboard Tray by Ric2L - 3D Warehouse That's a readily available part that would be easy to incorporate into your own design.
  #23 (permalink)
Old February 11, 2013, 06:48 PM
3.0charlie's Avatar
Per your initial dims and specs:
Couple of issues: weight already stands at 41 Lbs... Steel L extrusions, front + doube Al. side panels.
The triple fans that fit are 200mm, not 230mm. Moreover, if you want triple fans on the side panels, those wont fit - they'll foul into the front fans. And lastly the spacing will need to be tighter since the end fans are too close to the vertical extrusions.
Also, the side blue extrusions will need cut-outs at their ends before being welded to match the front and back extrusions.
Hydro-Quebec is salivating...
  #24 (permalink)
Old February 11, 2013, 08:16 PM
This is coming along great thanks again, think the middle pays for the 5.25" need a small gap of about 1/2" between them to mount the bays right within there
Site and Forum:
  #25 (permalink)
Old February 11, 2013, 08:22 PM
3.0charlie's Avatar
If you want to weld both 5.25" cages to the front panel, you'll have a hard time welding in a 0.5" gap. Needs to be more (1", and then some), or you weld both cages together first, then you weld the assembly to the front panel.
  #26 (permalink)
Old February 11, 2013, 08:33 PM
See this is why I'm taking your advice with the build thats a great point stay the course it is :) and weld those mofos together
Site and Forum:
  #27 (permalink)
Old February 12, 2013, 12:36 AM
Dzzope's Avatar
Very simple actually.. you just weld them from the front. They don't need to be fully welded anyway so a few 1" tacs will be plenty of support.
This of course depends on the type of welding. arc is the best for getting into tight spots as you don't have the gas nozzel in the way and you can bend the rod to get the correct angle to weld from.
That is of course if your bothered about them being fully welded. there will be more than enough strength in 3 x 1" welds top and bottom to hold your drives / res / whatever.
Actually this will probably be better anyway as you want the thinnest possible metal and too much heat isn't good for it.
(Jack of all trades master of none, have worked in everything from fast food and cleaning to enterprise IT, roady for a band, photography, pipe cleaner (basically) for large pharmaceutical companies and construction, specifically as a metal fabricator. :P )
May I also suggest smaller windows. personal preference but a window that shows the drive bays/hdd cage isn't great.
That it unless your going to have a fancy res to have in-front of them.
  #28 (permalink)
Old February 12, 2013, 10:39 AM
3.0charlie's Avatar
Welding from the front will change the edge of the opening from a sharp one to a rounded one. It's only a matter of aesthetics, but I do agree with your explanation.
  #29 (permalink)
Old February 12, 2013, 04:31 PM
Dzzope's Avatar
Yes, but considering how thin the metal is anyway you'll have some if welding from the back anyway..
As I said top and bottom would be strong enough and mean you can weld from the back too.
  #30 (permalink)
Old February 12, 2013, 05:34 PM
3.0charlie's Avatar
Update. 24" sides, 140mm fans, dual 230s on the bottom.
I'll create the board planes tomorrow, but it will be tight to locate them both at an angle with both upper PSU cut-outs.
Again, locating triple triple 140mm rads on the bottom will be interesting. The rad corners will be too close, and the front 230mm fan housing will be in the way.
Cube World headsh0t Gaming 1 January 5, 2012 10:26 PM
My AMD Gaming Cube/HTPC audirs HTPC Systems & Software 4 March 16, 2011 02:59 PM
The NVIDIA Cube PC Mnpctech Case Mods, Worklog & Gallery 31 March 24, 2010 02:31 PM
[WTB] m-atx cube case kyle_L Buy/Sell & Trade 4 February 14, 2010 11:19 AM
Software for Case Design. CMetaphor Cases 6 December 22, 2008 05:59 PM
