mITX build Coolermaster Elite 120 Put together this little build yesterday! i7 3770K Gigabyte GA-H77N-Wifi Patriot Viper 8GB DDR3 1600MHz https://fbcdn-sphotos-a-a.akamaihd.n...49082047_n.jpg https://fbcdn-sphotos-h-a.akamaihd.n...21095258_n.jpg Cant really see it there but i put in a Seagate 500GB momentus XT and you can see the 3TB Barracuda XT https://fbcdn-sphotos-c-a.akamaihd.n...70972470_n.jpg This is where it gets tricky! once you get the power supply in there https://fbcdn-sphotos-a-a.akamaihd.n...48221344_n.jpg had to use the stock cooler because my h100 will obviously not fit haha https://fbcdn-sphotos-e-a.akamaihd.n...49731388_n.jpg This is the best i could do with the cables https://fbcdn-sphotos-c-a.akamaihd.n...78640008_n.jpg Finished! https://fbcdn-sphotos-b-a.akamaihd.n...43466247_n.jpg |
Very nice build! I have a thing for mini-ITX builds. Small and mighty! |
Small and very powerful in this case. Nice build. Is the only case fan the 120mm in the center? What are CPU and GPU temps like? |
I ran furmark and intelburntest at the same time both at max settings for an hour and the cpu got pretty hot. like 89c-92c and the gpu was at around 79c-85c but i cant imagine the cpu will ever be that stressed in normal games. |
What direction you have the airflow from each fan going? |
Ah, gotcha. I'm new to the 77 chipset, and I don't know the ins and outs fully yet! On a different note, you now have a new use for your SFF PC...Put a pan of water on top of it and make some tea, LOL! |
Ive got a similar build. Except I yanked out my front HDD cage to put my h80i in the front. I suggest to battle the heat and noise issues's (well the ones I had anyways) is to flip the 80mm fan next to the mobo to exhaust, and set the front fan's to exhaust as well. With this setup, my chip is @ 4.6ghz 1.2v (3570k) and the gpu is left untouched. Temps are about 65 after gaming for a few hours with the h80i set to quiet 850rpm speeds. The gpu seems to run pretty cool and quiet as well. https://fbcdn-sphotos-c-a.akamaihd.n...58231096_n.jpg https://fbcdn-sphotos-h-a.akamaihd.n...19929501_n.jpg |
| All times are GMT -7. The time now is 01:46 PM. |
