-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   caselabs build (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/59450-caselabs-build.html)
radish January 31, 2013 11:08 PM
caselabs build
Having learned allot from my 800D build I decided to go with this thing, and after 7 hours of none stop building.... This is where I'm at...
http://i.imgur.com/yS2dIbE.jpg
I plan to sleeve everything black. And have minimal cables showing.
6tb storage between 3 2 tb greens and a work 1 wd black drive
http://i.imgur.com/z9ClHlN.jpg
4 ssds in RAID 0
http://i.imgur.com/KeFewsX.jpg
2x360 rads up to with push pull.
http://i.imgur.com/CJa2dG8.jpg
Reserved
ZZLEE February 1, 2013 08:00 PM
Lookken good
that case is a monster want MITX board fore it :biggrin:
dustin1706 February 1, 2013 09:42 PM
Was thinking about the 900D..... But this thing looks incredible.
radish February 3, 2013 12:02 AM
Originally Posted by ZZLEE (Post 687972)
Lookken good
that would be a bit of a waist dontcha think? lol if anyone did this i would --> http://romaninukraine.com/Graphics/DoubleFacePalm.jpg
yea despite the 900D being significantly cheaper... even at a premium over the 800D which is owned btw... i would go with this one. the 800D was a b**** to move around and the only selling point was the hotwap bays which are no longer present in the 900D. i had issues moving the 800D with a water cooling loop and all of its components... and i wouldnt even want to imagine moving the 900D. corsair is officially off my list.
Hooded February 3, 2013 05:26 AM
900D = 40lbs empty
Thats a nice build your putting together.
Should have posted in the Worklogs forum though. imo
This was more for questions about or news about watercooling.
radish February 4, 2013 12:32 PM
hmm i see your point. i figured i would get more suggestions then i did. maybe a mod can move this thread there? perhaps?
SugarJ February 4, 2013 02:08 PM
Thread moved to work logs.
radish February 8, 2013 06:37 AM
i got a bunch of 2150rpm typhoons from daz and sleeved cables and put the thing together.
http://cdn.overclock.net/f/f3/f3e3eec8_2KYEZgo.jpeg
http://cdn.overclock.net/9/96/96ebb0e3_yt2OQZb.jpeg
http://cdn.overclock.net/d/db/dbe55a89_dXaW80K.jpeg
http://cdn.overclock.net/5/59/59c960e2_G9pPC3n.jpeg
and finally this is what it looks like from the front.
http://cdn.overclock.net/1/17/17ece922_QIYQoFs.jpeg
nasrott February 8, 2013 04:18 PM
What did the case cost ya shipped? Like the build by the way. Also what size sleaving did ya use on the tubing an its size?
