Old January 7, 2013, 02:38 PM
Default Need help with modding basics/tools :3
Hey guys. I need to buy some tools to start my modding work. Dremel, a heatgun and a jigsaw are the basics.
Also what bits are useful?
Any certain models, types, things I should be aware of?
Thanks for your time in advance
Old January 7, 2013, 02:43 PM
sswilson's Avatar
Dremel tools are easy... generally they come with everything you need, but if not, Princess Auto or Canadian Tire have kits which include everything you'll ever imagine needing for bits. What you will probably need to replace are the circular cutting wheels, they break easily.
On top of all that, do yourself a favour and buy yourself a set of both standard and jewelers' files. Much easier to come up with a nice clean edge/cut when you cut "long" and then file down to size.
Old January 7, 2013, 03:04 PM
Well Im located in the US. Is a dremel ok for window mods? I want a clean cut.
Old January 7, 2013, 03:07 PM
sswilson's Avatar
As I suggested, a Dremel will cut fine, but if you want the best possible clean edge you'll use the dremmel for a rough cut and then file the edge down to a clean line.
Old January 7, 2013, 03:13 PM
Hooded's Avatar
Smile
For your Dremel make sure you get the Dremel EZ Lock Kit | Canadian Tire for cutting disks. Note alot of people just buy the cheap job mate version for $15 and Dremel bits.
You might want to add a power drill and drill index.
Old January 7, 2013, 03:17 PM
SugarJ's Avatar
I find a jigsaw with a 24 tpi blade works better than a dremel for large cuts. You'll still need to file when done.
Old January 7, 2013, 03:49 PM
clg clg is offline
I have the Dremel brand EZ Lock discs for harder materials, but for most things I use this kit I got for $25. 500-pc kit which if you bought everything Dremel brand would run you hundreds upon hundreds. Their tooling is better yes, but for most stuff the cheaper bits will suffice.
Mastercraft Rotary Bits Set, 500-pc | Canadian Tire
Do you have all the basic hand tools? I know myself I need to get pin disconnectors. Invest in a good pair of wire strippers and a crimper as well.
Old January 7, 2013, 04:13 PM
Hooded's Avatar
Just don't get the job mate bits the wear out in no time or just break before use.
Old January 11, 2013, 10:24 PM
ZZLEE's Avatar
Default Look
Mnpctech's Guide to Tools For Case Modding.
still say it needs a sticky
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 12, 2013, 07:37 AM
Pabz0r545's Avatar
A riveter will come handy for case modding. They are very cheap at Canadian tire or any hardware store. About 10-20 bucks.
"Water cooling is basically like injecting drugs into your veins and you'll find that what once was enough is quickly not enough anymore."
-Linus
Mnpctech's Guide to Tools For Case Modding. Mnpctech Guides & How-to's 88 February 17, 2013 05:35 AM
Basics of HTPC Phobia HTPC Systems & Software 1 May 26, 2008 05:35 PM
Basics on Lapping ineedaname Guides & How-to's 6 March 8, 2008 04:50 PM
Sound Card basics? chibi_man Audio 22 November 26, 2007 12:36 PM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
