Old January 12, 2013, 08:57 AM
lowfat's Avatar
A jigsaw will definitely work better for larger cuts. Just make sure you get the proper blades for metal.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 14, 2013, 12:06 AM
Alright so for side windows, basically use drill to cut a hole, then the jigsaw to cut the metal and then file to perfection?
Or...?
I'm gonna be buying a dremel but from what I understand, drilling a hole, jigsaw and then filing the remaining bit is the way to go?
Old January 14, 2013, 12:28 AM
Father Fuzzy's Avatar
Or...?
first one is the best option
Mask the Side panel first for protection from scratches
dremeling out a large window in thick metal would take 20-50 discs and not as straight as a jigsaw
and of course file to perfection
Old January 14, 2013, 01:36 AM
How does the masking tape protect from scratches?
and protect yourself, or the metal? I've been meaning to ask about that.
Old January 14, 2013, 01:50 AM
you wouldn't want the metal base of the jigsaw scratching the door
as your pushing it around
or scratch the corners
Ive used a bucket to cut on top of
and wear goggles
Old January 14, 2013, 01:55 AM
ah ok, I'm 18, I think the only time I used a jigsaw was when I was around 13 or so haha
Old January 14, 2013, 08:51 AM
Maximum PC has a great article on case modding and case modding tools, you may want to check it out.
Modders Toolkit: Everything You Need to Make Kick-Ass Custom Case Mods - Page 1 | Maximum PC
Old January 14, 2013, 09:16 AM
KaptCrunch's Avatar
and wear goggles
thats why they invented painters masking tape
tape off the area(2 layers) and mark out your cut route
  #19 (permalink)
Old January 14, 2013, 09:33 AM
KaptCrunch's Avatar
very extra fine and max TPI rating or
Carbide (grit) but need a varible speed saw to run slow and water to cool blade
for a clean cut
or fastest cut a hole inside of cut out and use tin snips to cut hole then dremel edges smooth with tube sander or hand file then wet paper on file to polish edge
  #20 (permalink)
Old January 14, 2013, 11:48 AM
In that case don't forget to get yourself a pair of safety goggles. Even though modding can be seen as a casual thing safety comes first! Don't want a little shaving of metal in your eye it's far different from hair or dust. :P
Mnpctech's Guide to Tools For Case Modding. Mnpctech Guides & How-to's 109 January 15, 2015 11:06 AM
Basics of HTPC Phobia HTPC Systems & Software 1 May 26, 2008 05:35 PM
Basics on Lapping ineedaname Guides & How-to's 6 March 8, 2008 05:50 PM
Sound Card basics? chibi_man Audio 22 November 26, 2007 01:36 PM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
