Old April 23, 2008, 08:13 PM
Wankerfx's Avatar
Default Wankerfx's phase unit in the making
Well, I decided to jump ship with water cooling after a little incident, and I decided to go subzero. NoL helped me out on this one, and is almost done building me my unit. Now for the pictures:
First glance.
Unloaded temperature. (Still not tuned)
Beastly evap with some ice action.
Nice view of the unit.
Closeups on electronics.
I'm really happy with Adam's work at this point, I recommend him to anyone in need of a phase unit
[ER]
Old April 24, 2008, 12:01 PM
Wankerfx's Avatar
Bump for those who are interested.
[ER]
Old April 24, 2008, 12:24 PM
sswilson's Avatar
Just so we're clear here.... this unit is designed for 24/7 operation, and tuning it will hopefully deal with most condensation issues?
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old April 24, 2008, 12:44 PM
Wankerfx's Avatar
I think all SS systems are good to go for 24/7 use, and tuning it will deal with heatload issues. This one is going to be tuned for 250W =)
[ER]
Old April 24, 2008, 01:01 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Cool man, looks good. I wish I lived closer.
Old April 24, 2008, 02:47 PM
NoL NoL is offline
Yes designed for 24/7. What do you mean though tuned to deal with condensation issue? Insulation is really not that hard, people seem to have this odd idea of insualtion, its 10x easier then doing a water setup. Wanker will be doing a very basic insulation job, that will hold him easily :)
Old April 24, 2008, 02:56 PM
sswilson's Avatar
I guess my question is because I don't quite understand this "tuning" deal...
I obviously haven't done any research into the tech, but it seems to me that a person would want to have the maximum temperature at which their CPU will post, but it also makes me wonder if it can be "tuned" for room temperature which (in my mind anywise) would offer better-than-water OCs, but not build up condensation due to a major difference in temperature between the cpu and ambient air.
Old April 24, 2008, 03:05 PM
Eldonko's Avatar
Units are tuned for a particular heat load, ie. 250W, it doesnt have anything do do with room temp or whatever. He just means it will be set up for hot running processors without sacrificing too much cold. A stock vapo or similar would be tuned for much less heat load so you would see load evap temps near 0C or higher, while a proper unit like this would keep evap prob below -35C under load.
Old April 25, 2008, 12:11 PM
Wankerfx's Avatar
Bump =)
[ER]
Old April 25, 2008, 07:05 PM
BrainEater's Avatar
Nice job .
It's yer fluke thermometer I covet the most tho....
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
