  #21 (permalink)
Old May 20, 2008, 01:40 PM
Wankerfx's Avatar
Thanks a lot. No problem about the time, I know what it's like to a busy kid.
[ER]
  #22 (permalink)
Old May 20, 2008, 04:55 PM
bobletman's Avatar
Thats a really nice design you got going there.
Q6600 Core 2 quad @ 3.0Ghz
2gb of patriot ram reduced latency.
500GB 7200 rpm Seagate (baracuda)
BFG nvidia 8800 GTS 512 MB G92 core
Zalman CNPS9700 LED CPU fan
Ultra X-Blaster computer case
P5K-E Wifi edition MOBO
G15 keyboard and G7 mouse
22 inch widescreen samsung
Z5300e speaker system
3Dmark06 score 15K
  #23 (permalink)
Old May 20, 2008, 07:47 PM
NoL NoL is offline
And I got my Eagle Scout on Wednesday, you don't know busy ;)
Tomorrow I have USA Chemistry Olympics (built a water cannon hehehe) and pics later. Cam won't work damnit. I put card into printer, printer blinks blinks blinks, nothing. Restart printer, blinks blinks blinks nothing. And worse, when I pull out the card windows says it found a card and then lost a card!
grr
  #24 (permalink)
Old May 23, 2008, 01:29 PM
magictorch's Avatar
Default crazy cooling
I've looked at the pics a few times but have been lost for words--its definitely good to improvise but Id be in a "lot" of trouble if something like that ever found its way out of the basement.
I'm curious about the specific design problems you need to overcome to get it cooling a CPU/GPU and what kind of performance you'll get.
Its going to help push anything real good though.
  #25 (permalink)
Old May 29, 2008, 02:49 PM
NoL NoL is offline
Cooling two locations is not hard, however the condenser needs to be large enough to reject the heat load. The main problem is insulating a GPU with a very powerful unit. A low or medium power that holds in the -10 to -25C range would not be hard, however -40C on a GPU is quite intense to insulate for. Basically it can be done, and not that expensively. A lineset adds $180 or so, and a larger condenser or second would add $70 more, plus tuning and more refrigerant and insulation, so expect it to add $300 for a second evaporator.
