Old November 12, 2012, 11:29 PM
Default Lian-Li PC-8FIB case, fans LED lights controls...
I am very interested in the Lian-Li PC-8FIB computer case.
It it the perfect case for me except for a small detail. It comes with blue led lights which i absolutely detest.
Can it easily and safely be disabled so no light emanates from inside the chassis?
In that case, how is it disabled?
Does anyone know the answer?
I would appreciate knowledgeable contributions.
Thank you kindly
Old November 13, 2012, 09:15 AM
SugarJ's Avatar
It comes with blue LED fans. You can either replace the fans, or cut the leads to the led lights in each fan.
Old November 13, 2012, 08:14 PM
From your response I conclude that there are no plugs to unplug.. they are hard wired..
thank you very much.
No Display-Fans and lights turn on-FIXED ak21 Troubleshooting 30 April 13, 2011 05:48 PM
New Lian Li 'Case' J_M Cases 11 July 31, 2010 10:05 AM
[WTB] Lian Li or other 140MM fans lemonlime Buy/Sell & Trade 1 April 30, 2010 01:19 PM
Project Lian Li + MM case implosion222 Case Mods, Worklog & Gallery 3 June 19, 2009 10:56 AM
No Boot, No Post, No Lights, No Fans Capt Proton Troubleshooting 8 August 8, 2008 01:35 AM
