-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Gallery Lian-li PC-7HX (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/57825-lian-li-pc-7hx.html)
blueweb November 11, 2012 10:36 AM
Lian-li PC-7HX
All I did was transfer my current hardware and case handles from my old U2-UFO to my new Lian-li PC-7HX.
Asus Sabertooth 990FX
AMD 1090T @ 3.8Ghz
Corsair H80 w 2x Xigmatek crystal fans.
2x MSI 460GTX @800mhz
16GB Ram Gskill
120GB SSD, 2x WD 1TB, 1x WD 500MB
Lian Li fan controller
1x LG BDRW 1x BDROM
2x led tube lighting.
Alienware TactX keyboard
M60 Corsair mouse
z5500 Logitech Speakers
http://i752.photobucket.com/albums/x...2/DSC01699.jpg
http://i752.photobucket.com/albums/x...2/DSC01700.jpg
http://i752.photobucket.com/albums/x...2/DSC01701.jpg
http://i752.photobucket.com/albums/x...2/DSC01702.jpg
http://i752.photobucket.com/albums/x...2/DSC01704.jpg
http://i752.photobucket.com/albums/x...2/DSC01706.jpg
http://i752.photobucket.com/albums/x...2/DSC01707.jpg
http://i752.photobucket.com/albums/x...2/DSC01708.jpg
http://i752.photobucket.com/albums/x...2/DSC01709.jpg
http://i752.photobucket.com/albums/x...2/DSC01710.jpg
http://i752.photobucket.com/albums/x...2/DSC01711.jpg
http://i752.photobucket.com/albums/x...2/DSC01712.jpg
http://i752.photobucket.com/albums/x...2/DSC01714.jpg
http://i752.photobucket.com/albums/x...2/DSC01715.jpg
http://i752.photobucket.com/albums/x...2/DSC01717.jpg
http://i752.photobucket.com/albums/x...2/DSC01719.jpg
http://i752.photobucket.com/albums/x...2/DSC01720.jpg
dandelioneater November 11, 2012 11:43 AM
Looks nice with the handles. The aesthetics of lian li cases just can't be beat in my opinion.
blueweb November 12, 2012 07:54 AM
Definitely a sleek looking case and the handles make things so much easier!
Father Fuzzy November 12, 2012 09:26 AM
Nice rig you have there
what did you do with the ufo?
blueweb November 12, 2012 09:32 AM
Thanks.
I put her up for sale.
http://www.hardwarecanucks.com/forum...ckup-only.html
Vittra November 12, 2012 02:41 PM
Looks great. You end up purchasing the case from Newegg? I've been waiting to see if it would pop up at NCIX or CC.
blueweb November 12, 2012 07:51 PM
Thanks :) Yep got it from Newegg.
I've asked Lian Li about the optional fan top shroud but they are ignoring my email.
I've ordered the tooless pci bracket, should be getting that soon.
concinnity November 29, 2012 07:12 AM
I assume those are MNPC handles. Did you just bolt them to the top panel or are they attached to the internal frame? I was thinking about putting some on a new build of mine...
blueweb December 4, 2012 07:48 PM
The case handles are from mountain mods (These pulls offer a wide 5 inches from centre to centre of the rods and 1.4 inches of clearance for most any size hand. The rod itself is .375 inches in diameter giving no flex under heavy loads. Use 8/32nd screws to fasten.) they are mounted directly and only on the top panel and fit perfectly so they don't hit the frame. The case comes with 4 small screws that you put around the top fan mounts, they align with mounting holes directly on the frame so it will give the panel more rigidity.
OrangePanda December 19, 2012 08:01 AM
You did an awesome job with the cable management.
