  #31 (permalink)
Old January 13, 2013, 09:33 PM
Father Fuzzy's Avatar
Super sexy case and build
Great Job Xnine
Lcd Screen looks amazing with the project logo on it
Gold monsoons look very luxurious in there and mingle well with the Vanilla sands
Love that shot of the cpu block
Congrats on your Killer build
  #32 (permalink)
Old January 13, 2013, 10:12 PM
ZZLEE's Avatar
inspiring
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #33 (permalink)
Old June 11, 2013, 02:31 PM
IRQ Conflict's Avatar
Very nice indeed. I was thinking of getting this case with a similar colour scheme. Gold/Beige. This build will probably be the basis for mine. Very elegant. Lovely.
  #34 (permalink)
Old December 24, 2015, 02:09 PM
Trial Member
Hi
Amazing build indeed.
Just wanted to ask something quickly. i've just ordered the same case and will want to do custom waterloop as well. How did you mount the reservoir to the case ? Are there pre-drilled holes so you can attach those strings directly or you had to make them yourself ?
Thanks a mill in advance
A rad in a Phantom? itayassa Water Cooling 0 June 16, 2012 09:24 AM
haf or phantom techman95 Cases 3 March 15, 2011 01:10 PM
NZXT Phantom Dr_BenD_over Cases 26 February 26, 2011 06:47 AM
600T vs. Phantom tl9015 New Builds 3 January 17, 2011 12:25 PM
