-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   WIP Corsair v70 Vengeance Case Mod: Planetside 2 (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/57092-corsair-v70-vengeance-case-mod-planetside-2-a.html)
Mnpctech October 5, 2012 05:58 AM
http://www.mnpctech.3dpixelnet.com/p...l_mnpctech.jpg
It's good to be BUSY and I love Sci-Fi & Military theme builds. So I was very excited to receive an inquiry from Planetside2's Creative Director Matt Higby, about doing a New Conglomerate theme case for his new PC build.
"PLanetside2" is the sequel to the landmark MMO FPS has been revealed and is bigger and better than ever. PlanetSide 2 is a massive multiplayer online first person shooter. Game play delivers truly epic combat on a scale never before seen in stunning, breathtaking detail. Battles wage with literally thousands of players aligning with one of three unique factions in intense land, air and vehicle gameplay where the fight for territory is more than a victory, its survival. The "New Conglomerate"(commonly abbreviated NC) is Matt Higby's favorite faction. The NC is one of three empires waging for control over the planet Auraxis. They are characterized by hard-hitting weapons and heavily-armored vehicles that are designed with straight lines and hard edges. Their faction colors are blue and yellow.
http://www.mnpctech.3dpixelnet.com/p...rsair_H100.jpg
Matt will be utilizing Corsair's H100 CPU cooler for the best optimal cooling.
http://www.mnpctech.com/120mm_fan_gr...ctech.com4.jpg
I'll be creating a front intake with LEPA Chopper Cooling fan and 120mm Overkill Fan Ring
http://www.mnpctech.3dpixelnet.com/p...ow_review1.jpg
My canvas is Corsair's new Vengeance c70. It's a rugged, military inspired design. It arrives equipped with lots of features. It includes three Corsair 120mm fans, with the option to add seven more 120mm fans. Option to mount 240 or 360 radiator in the top panel. It has eight expansion slots. The retail price is $139.99. You can read my Corsair c70 Vengeance Case Review
Factory Specification List:
Warranty: Two years
Dimension: 19.7" x 9.1" x 21" / 501mm (H) x 232mm (W) x 533mm (L)
MB Support: ATX, mATX
Expansion Slots: 8
Material: Steel
Drive Bays: Three (3x) 5.25” bays, and Six (6x) 3.5”/2.5” hard drive bays
Cooling Fans Included: Three (3x) 120mm fans
Front I/O: (x2) USB 3.0, (x1) Headphone, (x1) MIC, Power, Reset Switches
Power Supply: ATX (not included)
http://www.mnpctech.3dpixelnet.com/p...ow_review3.jpg
http://www.mnpctech.3dpixelnet.com/p...ow_review4.jpg
Onto the first Case Mod!
http://www.mnpctech.3dpixelnet.com/p..._mnpctech1.jpg
The first modification is converting the c70's factory window to plain window without any fan hole perforations.
http://www.mnpctech.3dpixelnet.com/p...mnpctech1a.jpg
The c70 window assembly dismantled. Save the 16x Black screws! We will be using them to re-install out custom window.
http://www.mnpctech.3dpixelnet.com/p..._mnpctech2.jpg
The new window will be cut from 24" x 24" sheet of 1/8" thick, Clear, cast acrylic. I'm tracing the factory window dimensions onto the sheet.
http://www.mnpctech.3dpixelnet.com/p..._mnpctech3.jpg
Using Vertical Saw to cut the new window.
http://www.mnpctech.3dpixelnet.com/p...y_band_saw.jpg
Going on 6 years ownership of my 14" Grizzly Vertical saw w/o a hitch.. You can use 1/8″ x .025 bi-metal blade for cutting acrylic and metal sheets. I usually cut 1/8″ thick sheets, Grizzly G0580 14" Bandsaw 3/4 HP - Amazon.com
http://www.mnpctech.3dpixelnet.com/p..._mnpctech4.jpg
This step is optional! I Rounded corners in the window with Hand file.
http://www.mnpctech.3dpixelnet.com/p..._mnpctech6.jpg
Using "Plas-Drill" 1/4" drill bit to make insert holes for the mounting pegs, on the 4 individual Black window trim pieces. The best drill bits for plastics are spur-point bits, also known as dowel bits. They are specifically angled to make smooth cuts in the material. A spur-point bit has a central point and spurs that keep the bit aligned, maintaining a clean, neat hole.
http://www.mnpctech.3dpixelnet.com/p..._mnpctech7.jpg
Place the acrylic sheet onto the panel and mark off the locations for mounting peg holes.
http://www.mnpctech.3dpixelnet.com/p..._mnpctech8.jpg
Using 1/4" Drill bit made for Plastic.
http://www.mnpctech.3dpixelnet.com/p..._mnpctech9.jpg
The acrylic sheet is placed on backside of the panel in this photo.
http://www.mnpctech.3dpixelnet.com/p...mnpctech9a.jpg
Reinstall the 4, Black window trim pieces into the panel. The pegs on the trim piece protrude through the panel and into your acrylic sheet, (after removing the paper backing on your acrylic sheet).
http://www.mnpctech.3dpixelnet.com/p...mnpctech9b.jpg
Remove the paper backing, then install the acrylic sheet. The pegs on the Black trim should protrude through.
http://www.mnpctech.3dpixelnet.com/p...mnpctech9c.jpg
Use the 16x factory Black mounting screws, you removed to install your new window. You will need washers. You can get washer from Hardware or Home Improvement stores. I chose these fan grommets as spacers, to mount the acrylic sheet.
http://www.mnpctech.3dpixelnet.com/p...mnpctech9d.jpg
Close up of fan grommets being used as spacers, to mount our custom window.
http://www.mnpctech.3dpixelnet.com/p...mnpctech9e.jpg
Our new window is installed!
http://www.mnpctech.3dpixelnet.com/p...mnpctech9f.jpg
Now Matt can view into his PC without anything obstructing his view. Next stage is customizing the c70's front bezel with something a bit more Industrial look..
Mnpctech October 5, 2012 05:59 AM
Much like my other recent case mods, this PC to emulate Field Equipment that looks used.... I want to make the bezel much more aggressive and Industrial look.
http://www.mnpctech.3dpixelnet.com/p...h9f_bezel1.jpg
http://www.mnpctech.3dpixelnet.com/p...h9f_bezel3.jpg
Lancool K58 bezel
http://www.mnpctech.3dpixelnet.com/p...h9f_bezel4.jpg
The K58 over the c70 bezel.
http://www.mnpctech.3dpixelnet.com/p...h9f_bezel5.jpg
K58 bezel over c70.
http://www.mnpctech.3dpixelnet.com/p...h9f_bezel7.jpg
http://www.mnpctech.3dpixelnet.com/p...h9f_bezel2.jpg
Removing the Corsair c70 front grill.
Mnpctech October 5, 2012 06:15 AM
I will be creating a unique cooling fan intake. I want to simulate hydraulic lines connecting to the sides that look hydraulic hoses. Here is what I have in mind of parts so far....
http://www.mnpctech.3dpixelnet.com/p...a_chopper4.jpg
120mm LEPA Chopper LED Cooling fans Link,
Newegg.com - LEPA Chopper (LPCP12N-BL) 120mm Blue LED Case Fan
120mm Overkill Fan Rings Link, 120mm Overkill Fan Grills
http://www.mnpctech.3dpixelnet.com/p...a_chopper1.jpg
http://www.mnpctech.3dpixelnet.com/p...a_chopper3.jpg
http://www.mnpctech.3dpixelnet.com/p...su_sleeve2.jpg
http://www.mnpctech.3dpixelnet.com/p...su_sleeve3.jpg
http://www.mnpctech.3dpixelnet.com/p...su_sleeve4.jpg
http://www.mnpctech.3dpixelnet.com/p...su_sleeve6.jpg
http://www.mnpctech.3dpixelnet.com/p...su_sleeve5.jpg
Mnpctech October 5, 2012 08:59 AM
The New Conglomerate Badge will be on the right side panel. Instead of just painting it on the panel, how about a Three Dimensional version? Hell Yeah! So I surveyed my pile of acrylic.. I got some Transparent Blue and Clear. No Yellow, but I can always paint it!
http://www.mnpctech.3dpixelnet.com/p...rate_logo1.jpg
All of the acrylic I'm using is Cast Acrylic, 1/8" thick. I printed out the logo, cut it, and traced around it, onto a 12" x 12" sheet of Clear acrylic.
http://www.mnpctech.3dpixelnet.com/p...rate_logo2.jpg
I used the Vertical saw to cut the traced pieces from the acrylic sheets.
http://www.mnpctech.3dpixelnet.com/p...rate_logo3.jpg
Cutting notches in the wingspan.
http://www.mnpctech.3dpixelnet.com/p...rate_logo4.jpg
Refining and defining the cuts with Hand File.
http://www.mnpctech.3dpixelnet.com/p...rate_logo5.jpg
Detailing the star, from the center of the logo.
http://www.mnpctech.3dpixelnet.com/p...rate_logo6.jpg
I'm debating about implementing some metal into the piece as well... Maybe mount the logo on metal shield... (back to the bench!)
Mnpctech October 6, 2012 04:49 AM
In-progress shot from the paint booth.
http://www.mnpctech.3dpixelnet.com/p...tom_paint2.jpg
The paint I applied is Acrylic Lacquer Metallic Blue.
http://www.mnpctech.3dpixelnet.com/p...tom_paint3.jpg
Under normal circumstances when applying Metallic Paint, you must apply top coat of Clear, but I deliberately skipped the Clear, to create this Dull SATIN finish.
Remember, I don't want the case to look shiny and new. I'm going to distress and weather the exterior, so this PC looks like it's survived some action in the field..
http://www.mnpctech.3dpixelnet.com/p...tom_paint5.jpg
http://www.mnpctech.3dpixelnet.com/p...tom_paint7.jpg
I've painted the junction box and Modders Mesh in Silver Aluminum.
http://www.mnpctech.3dpixelnet.com/p...om_paint9a.jpg
Lancool K58 bezel with Round Modders Mesh.
http://www.mnpctech.3dpixelnet.com/p...tom_paint8.jpg
Next step is installing the front intake fan and connecting the hoses...
Pabz0r545 October 6, 2012 06:49 AM
As always.... AMAZING. Never anything short of!
on a side note I wonder when manu's are going to stop putting those stupid perforated windows. Noone mounts fans on them anyways.
dandelioneater October 6, 2012 08:03 AM
Another sharp build.
I always avoid those cases as well.:haha: fan mounts on acrylic side panels looks so bad.
Mnpctech October 7, 2012 04:19 PM
@Pabz0r545, Thank you! and wish the manufacturers would listen to us! :thumb:
@dandelioneater, Thank you for dropping in and commenting :biggrin:
painted the New Conglomerate shield
http://www.mnpctech.3dpixelnet.com/p...ogo_paint1.jpg
I prepped the acrylic surface for paint by 1st scuffing the surface with Red Scotch brite pad.
http://www.mnpctech.3dpixelnet.com/p...ogo_paint2.jpg
Next step is applying Primer coat, I used RUSTOLEUM Enamel, from Home Depot.
http://www.mnpctech.3dpixelnet.com/p...ogo_paint4.jpg
I let the Primer cure for 2 hours...
http://www.mnpctech.3dpixelnet.com/p...ogo_paint3.jpg
I applied RUSTOLEUM's #7747 Sunburst Yellow, Enamel paint
http://www.mnpctech.3dpixelnet.com/p...ogo_paint5.jpg
I let the Yellow cure overnight....
Instead of just applying the logo on the factory case panel... I want something with a more industrial and rugged look.
http://www.mnpctech.3dpixelnet.com/p...go_shield1.jpg
I want the perimeter of the factory frame for a new backing plate on the right side panel.
http://www.mnpctech.3dpixelnet.com/p...glomerate8.jpg
I used a Jigsaw with 18 TPI cutting blade to remove the center of the factory window.
http://www.mnpctech.3dpixelnet.com/p...glomerate1.jpg
I used a hand file to clean up the edges of the factory window frame.
http://www.mnpctech.3dpixelnet.com/p...glomerate3.jpg
I'll be mounting the logo on this aluminum plate with louvered vents. I cannibalized this sheet from AMS gtower CF-1009 case side panel, which was discontinued several years ago.
http://www.mnpctech.3dpixelnet.com/p...glomerate4.jpg
I painted the frame with Plasti-kote "Aluminum" color Engine Enamel Paint.
http://www.mnpctech.3dpixelnet.com/p...glomerate7.jpg
Aluminum panel mounted on modified c70 factory window. The NC shield is now attached onto the panel.
http://www.mnpctech.3dpixelnet.com/p...lomerate9b.jpg
The paint finish is not going to remain shiny and new...
http://www.mnpctech.3dpixelnet.com/p...dier_armor.jpg
I'll be hand painting and airbrushing the finish with distressed and weathered look, much like this NC Soldier's body armor.
Mnpctech October 8, 2012 04:30 AM
I mounted the New Conglomerate shield onto the left side panel. I used socket head fasteners. This afternoon I'll start hand painting everything with distressed and weathered paint effects. Matt made it clear that he wanted the surfaces to look weathered. He sent images of the NC soldiers for inspiration.
http://www.mnpctech.3dpixelnet.com/p...lomerate9d.jpg
http://www.mnpctech.3dpixelnet.com/p...lomerate9e.jpg
http://www.mnpctech.3dpixelnet.com/p...lomerate9f.jpg
Matt wants the finish of the case to reflect the weathered armor on this New Conglomerate Soldier. I'll be using an airbrush and combination of different paint brushes, and sponges to weather the edges of exterior.
http://www.mnpctech.3dpixelnet.com/p...ier_armor2.jpg
http://www.mnpctech.3dpixelnet.com/p...ier_armor3.jpg
Mnpctech October 8, 2012 10:06 AM
Matt wants the exterior to look aged and weathered.
http://www.mnpctech.3dpixelnet.com/p...eathering1.jpg
Water Drop Masking: "Distressed & Weathered Look"
1. Spray entire surface with Water Spray Bottle
2. Use Airbrush over water drops with Enamel Paint
3. Allow to dry 1 minute
4. Use Paper Towel and Dab up the water, Don't Wipe!
http://www.mnpctech.3dpixelnet.com/p...r_masking1.jpg
http://www.mnpctech.3dpixelnet.com/p...r_masking2.jpg
http://www.mnpctech.3dpixelnet.com/p...r_masking3.jpg
Airbrushing shadows with Iwata around the NC shield, with Brown
http://www.mnpctech.3dpixelnet.com/p...r_masking4.jpg
http://www.mnpctech.3dpixelnet.com/p...r_masking5.jpg
Airbrushed mix of Grey / Black enamel paint over the vertical vents in the panels, to create aged effect.
http://www.mnpctech.3dpixelnet.com/p...r_masking6.jpg
You can see the water spots in the Blue exterior..
http://www.mnpctech.3dpixelnet.com/p...r_masking7.jpg
Scratched and scuffed the shield with red Scotchbrite pad and 80 grit sandpaper...
I'll be in the workshop on Sunday, applying more surface effects and adding some Yellow striping, inspired buy the NC armor.
