Old April 20, 2008, 02:28 PM
BALISTX's Avatar
Default Project Copperhead
Well folks I finally have all the parts for my system and a few days ago my buddy and I painted my Coolermaster CM690. I'm not revealing the paint I used, lets just say it's a custom blend I had a local automotive paint store mix up for me and put into an aerosol.
We painted the interior of the case a semigloss black. The exterior has 2 coats of base and 3 coats of clear.
I fully disassembled the case and we prepped it by scuffing the exterior parts with a Scotch Bright pad and then after we laid two coats of automotive primer we sanded the exterior with 2000 grit wet/dry sand paper.
Here are the results.
Don't mind the quality of the pics they were taken with my camera phone. I will have better pics once I get a change to take them earlier in the day when the sun is hitting the case so you can see the metalflake and the pearl in the paint.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old April 20, 2008, 02:51 PM
Cptn Vortex's Avatar
Ou that is pretty! Hehehe, looks really awesome. You're going to have to paint your car to match it!
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old April 20, 2008, 02:55 PM
BALISTX's Avatar
Thanks. The wife said we should paint the Jeep the same colour.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old April 20, 2008, 02:58 PM
Did you do it yourself or did you bring it to a shop? I've got an airgun for painting cars back home in Ontario, tempted to bring some cases the next time I go visit the family. Man I miss my old shop! You name it we have it. Just no CNC or milling tools...
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old April 20, 2008, 03:00 PM
BALISTX's Avatar
I'm not that good of a painter but my buddy painted it with aerosol can in my driveway. Just got the painted put into aerosol.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old April 20, 2008, 03:02 PM
Oh, gotcha. Looks really good!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old April 20, 2008, 03:04 PM
BALISTX's Avatar
Thanks. It looked good without the clear but once we cleared it, it made the copper pop and then once we removed the tape the black made it pop even more.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old April 20, 2008, 05:20 PM
3.0charlie's Avatar
Whoa. That's very nice. Very well done for aerosol paint application.
Old April 20, 2008, 06:05 PM
BALISTX's Avatar
Thanks John. We just took our time with it and did it right the first time.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old April 20, 2008, 06:59 PM
low351's Avatar
Very nice Job! I've just been through that and it takes patience. I didn't do as well as you though, and I didn't risk my CM690. yet...
