Old June 6, 2012, 11:54 AM
Man this PC is going to look like a million bucks!
Old June 7, 2012, 07:01 AM
Mnpctech's Avatar
Thank you! I just discovered some parts are on back order, so I'm having to ask for deadline extension and wait on finishing some stages.
I installed our polished Machined aluminum "Diamond Knurl" pc case feet which are made in HAAS cnc lathe.
The base diameter is 1- 3/4" with height of 1" to elevate the case for improved airflow beneath it.
For internal lighting, I've chosen installed Orange signal lights.
I added one of the factory cable grommet to the top, for all of the wires from Toggle Switch and CPU Load Tachometer. You can swivel and aim these Signal lights in whatever direction you like...
The signals I found are universal fit for Honda, Yamaha, Suzuki, Kawasaki, or Quad ATV. Here is the Reseller link on Ebay
Old June 7, 2012, 07:13 AM
great_big_abyss's Avatar
Noooooo...the backorder means even longer till I see more progress.
Oh well, joy in anticipation, right? Looking great so far.
Old June 7, 2012, 03:46 PM
NSdeadly1's Avatar
I just drooled a little Really liking that color
Old June 7, 2012, 04:33 PM
Mnpctech's Avatar
Thanks guys! It will be cool
Velocity style cooling fans installed.
Signal lights aimed on the cooling fans.
The Tachometer shell is ready for circuit board...
Old June 8, 2012, 07:43 AM
Mnpctech's Avatar
Progress on the top panel
Progress on the top panel. The carry handle is reflective of the diy welded crash bars on the Derby cars
Top carry handle was fabricated & welded from 3/4" steel tubing
2x 140mm black anodized fan / radiator grill with 15mm spacing, the inserts can be manually rotated.
I've added aluminum Diamond plate for base of the CPU Load Tachometer.
Tachometer is temporarily mounted in it's base for now.....I should have the circuit board from Twizted for it early next week.
Old June 8, 2012, 10:15 AM
Man this looks great, I too am a gearhead and enjoy modded cars as much as modded pc's, so this makes for a great combo.
Did you try turning it off and on again?
Old June 10, 2012, 07:14 PM
Mnpctech's Avatar
Awesome to hear Wedge! is your name inspired by Mopar's Max Wedge engine?
Modified the factory bezel of the Tachometer by opening the center, so I can mount the new circuit board (pcb) in the Tach body with the 4 screw holes... The factory pcb had screws in the center...
  #19 (permalink)
Old June 11, 2012, 02:41 PM
Mnpctech's Avatar
Next step is Hot Roddin the Tachometer gauge face with fire, with Brad Galvin behind the IWATA airbrush....
  #20 (permalink)
Old June 11, 2012, 02:48 PM
ZZLEE's Avatar
don't touch this :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Completed Project: APASF ("A Post-Apocalyptic Steampunk Future") (Final Pictures 29-03-2013) Luciel Case Mods, Worklog & Gallery 69 April 29, 2013 07:59 PM
Case Mod Case Mod Project: "Tribute to SERENITY firefly series" Mad Reader Mod pays $1500! Mnpctech Case Mods, Worklog & Gallery 90 December 5, 2012 06:02 AM
"BF3.3" Level 10 GT Case Mod is "Locked and Loaded" Mnpctech Cases 2 July 12, 2012 12:18 PM
"Wii 2" Codenamed: "Project Cafe" BFighter Gaming 5 April 24, 2011 10:16 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
