-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Really badly need help! - Computer Fan Failure): (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/54105-really-badly-need-help-computer-fan-failure.html)
xbournex May 12, 2012 06:33 PM
To connect to the motherboard, you would need these:
BitFenix Alchemy 3pin x3 Fan adaptor extension 60cm - Green [BFA-MSC-3F33F60GK-RP]
But if you're running high RPM fans, then I would suggest the Molex to 3pin rather than 3pin to 3 pin. Motherboards don't provide that much power to high RPM fans.
