<~----> Really badly need help! - Computer Fan Failure): - Page 2 - Hardware Canucks
Old May 10, 2012, 05:33 AM
Unhappy
Originally Posted by supaflyx3 View Post
sounds like you killed the fan header, have you tried other ones? Either way i would RMA the board.
Yeah I have bought a new fan if that is what you mean? It didn't work on my computer and I know its not the fan that is faulty because they both work on my other computer. What do you mean RMA the board?
Old May 10, 2012, 05:45 AM
Infact, if this helps forget everything that I have said.
I think it is just the socket thing for my fan becasue everything else works perfectly, the computer boots up, all the sockets work, USB ports, my other fans are fine and running smoothly so does that mean it is just the socket park so I could buy a new one and re solder it or something?
I'm not too keen on going out looking for a new motherboard because I really don't have the money at the moment since I've just bought a bunch of things for my computer. If there is anyone who knows of any way, please help me!
I'm willing to try anything that I can to fix this and get my back fan working.
If it helps, I could post up an image of my motherbaord incase there is anywhere else I am able to put my fan? :( !
Old May 10, 2012, 05:48 AM
sswilson's Avatar
More than likely it wouldn't be the socket, but instead would be the circuitry for the fan header which isn't user repairable. You'd have to return it to the manufacturer for replacement if it's still under warranty, and if they didn't question you on how you damaged the motherboard. (this isn't a part failure, you did it yourself).
Bottom line, from what you've described, it's not user repairable.
Old May 10, 2012, 07:34 AM
Tim_H's Avatar
I'll second what sswilson said. It's not something that's going to be user replaceable. you should return it to the manufacturer (RMA). Information on sending it should be available on their web site.
Old May 10, 2012, 04:42 PM
I can't take it back or anything because I bought it about a year ago from a friends dad..
He had the computer for roughly 2 years and doesn't have the manual or any information on it..
So from what you's have just told me, I'm screwed!
Old May 10, 2012, 04:44 PM
sswilson's Avatar
It sounds like everything else on the motherboard works fine... just don't use that particular fan header, and if you need more then use an adapter to plug the fan directly into a PSU molex connector.
Old May 10, 2012, 04:47 PM
supaflyx3's Avatar
As sswilson said, you can use a molex adapter, or even a y connector that allows you to run 2 fans off 1 header.
Old May 12, 2012, 03:37 AM
Thanks guys!
I'm going to go and order myself an adapter now!
Thank god I signed up for this forum or I would be buying myself a new computer:D!
  #19 (permalink)
Old May 12, 2012, 04:05 AM
Okay, so if I order this adapter, it looks like it has one main part which connects into the board then 3 other adapter bits.. Do they let my plug multiple things into it? Because there are 3 would that be 3 fans? o__O Little confused here!
BitFenix Alchemy Molex to 3pin x3 Fan adaptor 12V 20cm - Green [BFA-MSC-M33F12VGK-RP]
  #20 (permalink)
Old May 12, 2012, 09:09 AM
sswilson's Avatar
No part of that plugs into the motherboard, the larger plug goes to your power supply, and then up to three fans connect to the smaller plugs. It'll be perfect for what you need so long as you like green..... :)
Tags
burnt , fail , fan , smoke , spinning
Networking Help Badly Needed ChuckleBrother Networking 21 March 31, 2010 03:11 PM
Need advice badly!! fearm3now New Builds 8 December 4, 2009 09:09 PM
[FS] I need money badly sale WD 1TB Black/Seagate 1TB 7200.12/HD4830 $80each shipped b1lk1 Buy/Sell & Trade 14 June 13, 2009 11:19 AM
Advice on mobo needed badly 999Virus999 CPU's and Motherboards 8 January 11, 2008 10:23 PM
