-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Haf X XSPC RX360 Rad Question (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/53301-haf-x-xspc-rx360-rad-question.html)
Chomie April 12, 2012 02:43 PM
Hey Guys,
My rads came in today and I mounted my RX360 into my Cooler Master Haf X Case, only issue is is that the mounting screws push the rad way far into my drive bays which wasn't my game plan...
I want to mod the rad and case such that the rad is pushed as far back against the case (Where the hose inlet plugs are) and where the motherboard back panel is.
Only issue is is that I don'e have my motherboard yet and not sure if it will interfere so I hope you can give some insight.
From the back fan on the radiator to the back hole on the case is exactly 2inches
Mother Board: Asus Rampage IV Formula
Case: Cooler Master Haf X
Radiator: XSPC RX360
http://img827.imageshack.us/img827/4750/img0028wr.jpg
http://img193.imageshack.us/img193/1050/img0029ee.jpg
http://img546.imageshack.us/img546/8175/img0030qj.jpg
Bungwirez April 12, 2012 02:53 PM
drive bays are a sometimes sacrifice with the Rads in the HAF cases.
here's my 932 with a 360 in the roof and TFC 55mm shroud fans
http://i249.photobucket.com/albums/g...1/P1020223.jpg
lots of room to maneuver... but you'll need to drill holes to fit.
Chomie April 12, 2012 03:02 PM
Sorry I must've not been clear. It's not the drive bay I care about it's that the rad plugs (where the fittings screw in) don't line up with my pump here are some more pics:
http://img703.imageshack.us/img703/541/img0031xx.jpg
http://img837.imageshack.us/img837/6907/img0032id.jpg
http://img703.imageshack.us/img703/2087/img0033oj.jpg
In your picture would the be enough room to push it back in the direction of the arrow?
http://img15.imageshack.us/img15/9393/image1weo.jpg
Bungwirez April 12, 2012 03:11 PM
DERP. sorry, can't see your pics d/t work websense blockages. home time 1945EST. I owe you a beer
Bungwirez April 12, 2012 05:37 PM
I measure that distance to the back is 50mm.
and there's all kinds of space to fit it.
problem is at the front there is a 90mm overhang into the drive bay.
could still be tight ...
and ah, thanks for pointing this situation out.
looks like I might have a similar situation to work out this month.
hopeful we can work it out.
JD April 12, 2012 06:37 PM
It should be doable with two triple rotary 90 degree fittings from Bitspower, a set on the radiator and a set on the reservoir, with a small piece of tubing between. Might want to opt for 3/8" since it'll be a tight bend.
Chomie April 12, 2012 07:20 PM
Thanks JD, any insight if I am able to move the radiator against the back of the case? I wish I had to motherboard so I can see where it lines up....
JD April 13, 2012 05:01 PM
Honestly, I can't say for certain. I would pay close attention though to that EPS12V connector in the top left corner of 99% of motherboards though. You want to make sure there's ample room to get that connected without hassle.
I know with my Cosmos II the radiator hung down just to be in-line with the edge of the motherboard and it was too tight to get anything plugged in.
Are you mounting the fans internally like that? If so, it doesn't appear a motherboard is going to fit at all. If the fans cannot fit on top, outside of the steel frame of the case, then I'd say you'll have to drill new mounting holes or make a bracket to hold the radiator close to the windowed side and move it as far back as you wanted.
Chomie April 15, 2012 11:00 AM
If you look at the top of the case picture the rad is centered so there is an air space behind it for the motherboard. And yes the plan is to mount them internally there isn't enough room to put them above . I ordered my motherboard yesterday so I will throw a update when I find out what happens!
C0llateralDamag3 April 23, 2012 09:52 AM
I had a bit of an issue with my RX360, I mounted internally and was able to get the 12v power cable on the board, but it was damn tight. I also removed the 2nd fan in order for my memory to fit, a bit of a nightmare all together but I got it in and is running fine.
hind sight, I would have opted for the RS360 -
