Old April 9, 2012, 09:36 AM
Goofy Goober's Avatar
Originally Posted by PerryC View Post
Very nice looking set up. What are your temperatures like?
thank you
cpu 30° C in idle 50-55° C full
gpu1-gpu2 29-27° C idle 39-37° C full
Originally Posted by KaptCrunch View Post
nice build but the rez pics are showing bubbles in rez
these bubbles still present today ? and video shows something and the rez tub not to clearly for the reflections. is it clear or camera glare
the bubbles are gone, i've take the photos when i've just finish to fill the loop, so there were some bubbles and air in.
for the video i think it's camera glare
My watercooled rig: GUREN KNIGHTMARE
Old April 9, 2012, 08:40 PM
Astaroth's Avatar
Very nice build you got there. I'm not a big fan of external radiator setups either, but you sure pulled it off.
Your video is very static in that it's just one plain continuous shot. But at least you picked good tunes. You must see In Flames play live if you haven't already
Old May 4, 2012, 06:27 PM
Does it run on Jet, or Ethanol Fuel. Real Pro Workmanship.
Old May 10, 2012, 06:39 PM
wow that's a lot of rad capacity! does the extra 240 on top make much of a difference to your temps? i imagine the 360 on the inside and the rear external rad would be enough :\
nevertheless, very sexy rig, mate! :D
Old June 21, 2012, 07:51 AM
thank you guys! :)
yes the additional radiator help to control the water temp. under full load.
Meanwhile i've made some minor modification :
- switched from the RX240 to te RX480 on the top of the case
- added some Koolance VL3N quick disconnects on the external radiators, they are now full modular
- replaced the fittings under the GPUs and the ball valve with a Bitspower one.
- now i'm using Mayhems Pastel fluid.
i've also replaced my old power supply (noisy under load, tagan bz900) with a Seasonic 1000 Platinum
some photos
Old June 21, 2012, 12:37 PM
really
Old June 21, 2012, 12:54 PM
norfolk's Avatar
WOW really nice build,I wish I had the bucks to do a W/C setup.
Old June 21, 2012, 11:00 PM
Father Fuzzy's Avatar
Nice monster you got there!
Great Job
  #19 (permalink)
Old June 22, 2012, 10:51 AM
Originally Posted by blaze_125 View Post
really
Great Job
thank you so much!
here's two short videos of the "lights effect", put on the sunglasses
GUREN KNIGHTMARE HAF X - start up - YouTube
Crucial Ballistix Tactical Tracer - YouTube
New build, need help when it comes to watercooling Marwan5418 Water Cooling 25 November 25, 2011 12:02 PM
First Watercooling Build Musabi New Builds 47 March 22, 2010 07:15 AM
Watercooling build Help homer98 New Builds 25 March 9, 2010 09:45 AM
Watercooling Mock-up for build Overclocker~4.1 Water Cooling 19 January 12, 2010 08:54 PM
New watercooling build is complete. Dazmode Case Mods, Worklog & Gallery 19 December 29, 2009 01:11 AM
