-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Power supply sleeving question (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/52735-power-supply-sleeving-question.html)
Chomie March 25, 2012 10:01 PM
Hello,
I am looking into possibly sleeving a power supply (Corsair HX1050) and just have a couple of questions:
1) Best place to get individual (1/8th I believe?) sleeving in CANADA
--> I know DazMode sells the Darkside sleeving is this my best bet?
2) Is sleeving just the PSU cables enough length or should I get extensions? If so, where is the best place to buy PSU extensions in CANADA with BLACK connectors?
3) Approximately how many feet of sleeving and heat shrink would I need?
I'm going with the R.O.G color concept like this:
http://cdn.overclock.net/1/1a/600x45...21cc_rog2.jpeg
Thanks guys,
Chomie.
lowfat March 25, 2012 10:12 PM
You want 1/16". Dazmode is the best you'll get in Canada. You'll need 70-100 feet normally.
supaflyx3 March 25, 2012 10:14 PM
I'll be getting some darkside sleeving stuff tomorrow, I'll let you know how it is.
Chomie March 25, 2012 10:17 PM
That'd be great! Are extension cables necessary? Or are the cables provided with PSU's usually long enough?
supaflyx3 March 25, 2012 10:47 PM
Depends on the case you'll be using.
Father Fuzzy March 26, 2012 09:02 AM
I picked up my sleeving from daz and am happy with it
extensions shouldn't be needed ..of course they wont match your rog theme
order a few xtra ft...sucks when u need to re-order for 5 ft...I know that routine
Chomie March 26, 2012 10:29 AM
I'll be using the Coolermaster HafX case, Where would be the best place to get extensions in Canada if I ever need them?
lowfat March 26, 2012 10:43 AM
Dazmode. :biggrin:
Pabz0r545 March 26, 2012 10:54 AM
I got my extension cables from NCIX. You should avoid extensions and just re sleeve your psu cables if possible. extensions only give you a bunch more cable to manage and it can cause a bit of a headache if all of your cables are extended with extension.
Chomie March 26, 2012 12:24 PM
Dazmode it is! Thanks
