Old February 23, 2012, 03:16 PM
Luciel's Avatar
Default Tutorial Project: Nš2
Hello,
The aim of this tutorial project is to put togueter a series of smaller tutorials/how to on individual things.
Customizing a fan controller, painting a drive, and so on an so forth. All of these mini-tutorials will be posted as seperate threads.
This thread will be the main one focusing more on the whole build.
These are an initiative of the main sponsor, Lamptron.
Other sponsors that have helped out with this project are:
Thank you all, specially Chris @ Lamptron and Teseo @ Benchmark Hardware for their never ending support.
Right, so letīs start!
We will be using a very basic case, the entry level "Isis" by B-Move:
And we strip it down:
Edit (note by Burnout21 over @ Bit Tech):
A good idea is de-rivetting the top side, that way we can trully get all the panels off which will make for a better finish. I didnīt on this particular case as all areas where easily accesible, but this isnīt normally what happens with most cases)
Edit (note by nagyizom over @ Bit Tech): Another good idea is to remove those ugly fan grills at the back and replace them with our own. Obviously this a matter of your own personal taste, itīs easy enough to do and wonīt cause you any major troubles). This may or may not give you better noise reduction and airflow (depending on the specific case of course).
The first change Iīm going to do is prepare the side for a window. If you feel you want a normal square window, thereīs nothing wrong with that, go ahead, you can aply the same steps as I will be doing. Personally, I like something different, so Iīm going to be doing a series of triangular shapes.
Thereīs many ways of doing this, but Iīm going to explain the way I do it. I tape out the area to cut, in order to use the tape as a guideline, you can use drawn lines if you like, personally I preffer this way as with a normal line I end up not being able to see it due to the sparks that come when cutting.
Edit (note by nagyizom over @ Bit Tech): If youīve never used a dremel, you will provably find it easier using a jigsaw, it should also give you a nice straight line. Personally I find tape for guiding and a steady dremel hand is good enough, again, itīs your choice.
Ok remember to ALWAYS use safety gogles when working with any kind of power tool. I use a dremel for this kind of modification, but really any kind of rotatory tool will do as long as itīs the right size.
Edit (note by DeathPrincess over @ [H]ard Forum): Thank you very much for reminding me of this!! I forgot about mentioning it. For this specific job I use the dremel discs line number 420 (Heavy Duty Cut Off wheel), you can get 20 of these for about 7-8€ in your local hardware store.
First section cut off:
And the rest...
Now, it still needs to be cleaned up for smooth edges but I felt like testing it on the rest of the case to get an idea of the look:
Yeah, I quite like that.
Edit (note by RustyTool over @ KustomPCs): RustyTool has a decent point here. Notice how part of the triangle windows are right on top of the bays. Depending on the case and on your intentions for interior design, you may or may not choose to do these as all you can see through them are the bays. On a personal note. If youīre using older cases, make sure that you have enough space between the window and the chasis to fit the plexy.
More soon : )
Old February 24, 2012, 03:14 PM
Luciel's Avatar
The front is awfully plain in this case, which really is to be expected on a low end case. I do like the start button though so Iīll leave that as it is. I wonīt worry about the bays since they will be filled. But I do feel like adding some detail to it, following the rest.
Remember to set your dremel to low speed when cutting plastic, as high speed will just melt it and make a right mess of things.
The bad thing, in my oppinion about most simple cases is that the right side tends to be awfully plain and thereīs not that much you can do with aside from a nice paintjob, which wonīt be seen much in most cases since the window side is the one facing you in most cases.
Lucky then that this case has a modern chasis design and has the opening under the board, so hey, why not make a window?
I tend to use number 420 on the dremel line of discs (Heavy Duty Cut-Off Disc). And for this thin metal sheeting, itīs like slicing through butter with a hot knive. Regardless, remember not to push the dremel or youīll burn through discs.
Right so letīs see it all put togueter with all cuts cleaned up (I donīt remember the specfic term in english, but itīs a sanding wheel for the dremel, thatīs the way to go, personally I use the same cutting disc on itīs side to cut off all remnants and shave it down, and then I blunt the edges to prevent cutting).
The problem with the front mini-window is that, right behind it thereīs a pseudo dual-fan mount, which makes the window look ugly and a bit pointless, so letīs cut it.
And now...
...much better!
Ok, now weīve got to sand down everything thatīs got paint in it, so in this case, all panels, as you can see the interior is bare in this case. Once done, clean it all up. I personally use distilled water, but you can use alcohol or any kind of non-corrosive cleaning product. Now wait for it to dry, specially if youīve used any kind of chemical to clean it (iīd stay away from that option, just in case).
Now that itīs prepped, itīs painting time. Remember to always use a breather, this stuff is nasty in your lungs! Not to mention a well ventilated place, but not outside as you will get crap on your fresh paint, and you donīt want that.
A couple of notes about paint types. Iīve had quite a few discussions about this in several forums with all sorts of people. Some use x product and works fine for them, others say donīt use x product because of x reason.
Personally, I use acrylic paint, which is water based, itīs dries very quickly, so you donīt have to wait hours between coats, and itīs good for sanding down between coats to get an extra smooth finish. I stay away from sinthetic and plastic paints, for several reasons which I wonīt go in to but regardless, if you want to take my advice, go for acrylic paints, be it in spray can or compressor & gun.
Right, down to it. First a coat of primer:
And now a base color as the effect I will be using (pearl) is almost transparent, so it needs a base color first, in this case, white.
And thatīs it for today, more tomorrow.
As a small spoiler, no, the case wonīt be all white, itīs simply easier doing it all in white and then painting on top as needed.
Old February 24, 2012, 04:19 PM
Pabz0r545's Avatar
I look forward to seeing your creation unfold Luciel.
Old February 24, 2012, 04:36 PM
Luciel's Avatar
Thank you Pabz, being a tutorial project, it wonīt be anything extravagant, but Iīm really happy I get to use the color scheme I have planned for it, fell in love with it a couple of months ago at the store where I get my suplies from : )
Old February 24, 2012, 04:52 PM
Chubs's Avatar
Do you have any problems with the acrylic bonding to the smooth plastic?
Or are you prepping it with a 1000grit and adhesion promoter prior to painting?
Gaming Rig
Fractal Design Arc Midi, OCZ ZX-850, ASUS P8P67 Evo Rev 3.0, Core i5-2500k, Coolermaster V6GT, 4X4G Corsair Vengeance DDR3-1600, Patriot Wildfire 120G SSD, 3X WD Caviar Black 1TB, ASUS DVD, Windows 7 Home Premium
Old February 25, 2012, 12:29 AM
Luciel's Avatar
Hi Chubbs, not really. I used 800 grit very softly on the plastic the acrylic primerīs fine for both plastic and metal, granted it is more likely to drip on plastic but itīs a question of moving fast through the areas so as not to create dripping (from a good 10-15cm)
Old February 25, 2012, 09:58 AM
Luciel's Avatar
Edited the main post to add comments from several members of several forums, thanks for participating guys, I welcome more suggestive comments of the kind in order to add them further to the steps on this tutorial so that newcomers can use it, containing imput from more experience modders in order to create a decent first project.
Right so, update:
I sanded down with very fine grit and very gently the first coat of base white, this, while not entirely neccesary will give you a smoother finish on the next coat and it will make the next coat hold on tighter which in turn makes it that much resistant to scratches.
Once done, I aplied the second coat of base white:
I let that to dry for about 15-20 minutes (again this only aplies to acrylic paint due to itīs quick drying properties) and sanded it down again. I then proceeded to aply the third coat, this time, of pearl white effect. Itīs an almost transparent coat, like lacquer if you will, but itīs not lacquer and can be aplied to any color (of the same kind of paint). This will give a glossy pearl finish (which, while the photos donīt do it justice, itīs very different to just using glossy white which I used in the AIO AL project).
While itīs drying time is the same, I will now leave it over night to cure as I will be using tape on top of it for the next stage of color.
PS: The case next to it, is another exactly the same model case Iīm preparing for a client, but that can go in another mini thread.
Old February 26, 2012, 12:59 PM
Luciel's Avatar
Now that the paint has cured, itīs safe for us to use tape on it, again go ahead and sand it down if itīs not smooth. I first used decal tape to mark lines (the blue tape) and then extra thick masking tape as filler (the yellow tape).
Letīs aply the first coat, of the second color. As with the white, Iīve gone with a pearl effect blue.
15-20 minutes later, I aplied the second and final coat of the blue. Notice how the light reflects on the pearl efect, making it look like thereīs 2 tones.
I let that cure for 4 hours before remove the tape. Now itīs safe for us to remove it (gently please!). Iīve taken several pictures with and without flash, on different possitions to try and show you the pearl effect, though the pictures really donīt do it justice.
And thatīs it for today really. Thereīs not much more to do on the case other than mounting the windows. In the next few days Iīll be posting the mini tutorials on each component and then finish it all in this thread mounting it all in the case.
Thanks for reading/watching!
Old February 26, 2012, 07:18 PM
Nice job on the white case, that's gonna be my next case color for sure.
I can't paint because of my impatience....I now send my parts for powder coating he he.
Old February 26, 2012, 07:22 PM
Silent_Avenger's Avatar
Nice work I see a little bit of paint bleed though in one of you pics.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Case Mod Tutorial Project: OS-LB Colyn - Paint & Light Modding Luciel Case Mods, Worklog & Gallery 7 December 17, 2011 09:13 AM
Bios Tutorial Video IXKraKenIX Suggestions & Feedback 9 July 16, 2011 04:10 AM
EK Supreme LT Waterblock installation tutorial Dazmode Water Cooling 3 September 25, 2009 05:37 AM
[WTB] Used working X58 mobo for watercooling tutorial Dazmode Buy/Sell & Trade 11 August 30, 2009 08:19 PM
