-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   first time mod raven 03 [help needed] (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/51873-first-time-mod-raven-03-help-needed.html)
severity February 23, 2012 01:42 AM
So i got my raven to day and theres a few thing's that already bug me, The 180MM fans theres a gap between the two and it looks really stupid, I was going to put 3x 120MM fans to replace them but that look's even stupider as they're just sitting in the center, So I think I'm gonna stick with the less annoying 180MM fans. Also wtf is with how the power supply goes really?
for the sleeving I think i want to do something very similar to this
http://img835.imageshack.us/img835/637/24pin.jpg
and as for the tubing I think I want to go with something like this
http://www.kustompcs.co.uk/acatalog/2316.jpg
What I am in need of is non LED black / orange fans does anyone know if these exist, If i can't find them I think i might change the colour scheme to black / green
I would also like to some how get the hard drive cage from a raven02 in the 03
http://benchmarkreviews.com/images/r...rive_Caddy.jpg
supaflyx3 February 23, 2012 01:48 AM
Can't speak for the fans, but for sleeving you'll need a paperclip for removing pins, a heatgun or butane torch for the shrink wrap, heatgun is the better option, and scissors for the heatshrink and sleeving.
Silent_Avenger February 23, 2012 02:33 AM
Only orange/black fans you'll probably be able to find are made by Cougar.
Linky: Newegg.ca - COUGAR CF-V12HP Vortex Hydro-Dynamic-Bearing (Fluid) 300,000 Hours 12CM Silent Cooling Fan with Pulse Width Modulation
severity February 23, 2012 02:36 AM
Deciding on what res to get leaning more towards the dual bay
FrozenQ Liquid Fusion Dual Bay Reservoir - UV Green Helix [FQ-FDB Green] - $109.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
Might change the scheme to black / green, I don't really know what I want yet
FrozenQ Fusion Reservoir Rev.6 UV Green - 250mm FrozenQ Fusion Reservoir Rev.6 UV Green - 250mm [FQ-F250GRN] - $99.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
jibz February 23, 2012 04:59 AM
I'd pass on the frozenQ stuff, a few other forum members and myself have faulty products and no support/communication from them. If you get a bad product you're out $100.
severity February 23, 2012 09:11 AM
what would you recommend? I've never done water cooling before
Adzsask February 23, 2012 09:30 AM
Black/orange fans :)
Newegg.ca - COUGAR CF-V12H Vortex Hydro-Dynamic-Bearing (Fluid) 300,000 Hours 12CM Silent Cooling Fan
^2nd link is PWM, and 400 RPM higher speeds.
severity February 23, 2012 11:23 AM
Thanks for the links for the fans, Didn't know cougar had fans too bad they're ugly i was looking for more like the typhoons but with orange instead of white, I have no idea what colour scheme i want at all.
jibz February 23, 2012 11:37 AM
Some painter's tape and a can of Krylon Fusion plastic spray paint and you can turn any fan any color.
severity February 23, 2012 11:55 AM
Yeah I was thinking of painting some typhoons, how ever I'm not sure if i want to do the water cooling right away because I plan to replace the parts in my sig with ivy bridge once it comes out.
