I decided to order one of these Test bench type cases and put it together today. This post is more about the case than the components used for the build.
I had read some reviews and posts concerning the difficulty in assembly of this case but I did not have trouble putting it together.
I decided not to install the 2nd CD tray and the 2.5" tray for the time being.
Here is the first pic assembled ...
After assembly it occurred to me that if I turn the top handle upside down, I can install another motherboard on top. Check this out ...
I plan to install a 2nd motherboard tray for a Mini-itx mobo powered by a PICO power supply in the near future ... thats all folks
