-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Lapping my E6600 (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/4971-lapping-my-e6600.html)
CanadaRox March 8, 2008 11:14 PM
Lapping my E6600
Since I will be putting my CPU under some DI next week, I figured I might as well lap it. So I went to Canadian Tire and got some sandpaper. Grits: 220, 400, 600, 1500. I had planned to get 220, 400, 800, 1000 but that's the closest the Pickering store carried. So I was off. So here are some pictures of the lapping process:
Unlapped IHS:
http://i34.photobucket.com/albums/d1...676800x600.jpg
http://i34.photobucket.com/albums/d1...678800x600.jpg
http://i34.photobucket.com/albums/d1...679800x600.jpg
These shots are about 2/3 way through 220 grit. You can see how concave the IHS was.
http://i34.photobucket.com/albums/d1...685800x600.jpg
http://i34.photobucket.com/albums/d1...688800x600.jpg
Next comes 400 grit. Top of the IHS is now all copper :biggrin:
http://i34.photobucket.com/albums/d1...690800x600.jpg
http://i34.photobucket.com/albums/d1...691800x600.jpg
I forgot to take pictures after 600, but it looked pretty much the same as 400. But here are the final results.
http://i34.photobucket.com/albums/d1...693800x600.jpg
http://i34.photobucket.com/albums/d1...697800x600.jpg
http://i34.photobucket.com/albums/d1...694800x600.jpg
The second last picture looks extreme rough, but it is actually quite smooth.
Unfortunately I'm only running my CPU @ 3GHz (9*333) so the change in temperature isn't as much as it would have actually been had I been running my usual 3.7GHz. But here are the results:
Before lapping:
Idle: 35C
Load: 43C
After lapping
Idle: 32C
Load 41C
Also, I didn't reapply the thermal paste (I'll be putting this under DI on Wednesday, so I didn't feel like wasting any). I just left the paste on the waterblock, and I checked after it was mounted, and it spread decently. I would expect at least another degree or two with properly applied paste. I will also have to take the o-ring out of my D-Tek Fuzion to get rid of the slightly convex base. That might give another degree or two as well.
In the end, I'm glad I did it even if the results weren't anything to write home about, even if its just to say that I have lapped my processor. :biggrin:
sswilson March 8, 2008 11:24 PM
A 2c difference is nothing to sneeze at considering some folks will shell out extra money for a cooler/WB/or fan that only provides that much of a benefit.
All these folks here lapping their procs have got me itching to do it too!!! :)
1Tanker March 8, 2008 11:34 PM
I agree with sswilson.. cheap improvement in temps. Good job.:thumb:
MacJunky March 9, 2008 01:00 AM
You are not the only one. I think I might just have to head down to the local PC shop for some new thermal compound myself so I can lap my E1200 and HSF.
*shakes fist at HWC members who have lapped their CPUs recently* Bastards infected me!.
Cptn Vortex March 9, 2008 03:54 AM
Hell, I lapped my Maximus southbridge cooler. Does that make me weird?
CasheKicker March 9, 2008 05:24 AM
SSWilson
I can even offer you the cheapest method possible. :haha: I already have lots of sand paper at the house. I could bring you some in to work... :thumb:
Imagine FREE temperature improvement....Now how can you refuse that? :bananafunky:
:canadianwave:
frosty March 9, 2008 07:12 AM
so the smoother the better or the shinnyer (if thats a word) the better.... I used to polish wheel covers at work when I worked in the Polish Room...... this stuff is redally avaliable to me without cost..... but is it just a matter of being smooth and flat? Guess I could give it a chrome polish finish.... exactly like a mirror......
sswilson March 9, 2008 07:15 AM
Flat is a lot more important than shiny when it comes to lapping.
1Tanker March 9, 2008 01:17 PM
Yeah... i never "polish" when i lap..i just go for flat and smooth.:biggrin: Noboby sees how shiny it is with the HS/F on anyway.:bleh:
Eldonko March 9, 2008 01:26 PM
GJ man. FYI you can get finer paper at autoparts stores, up to 2000 grit.
