  #111 (permalink)
Old April 29, 2012, 02:16 PM
sswilson's Avatar
Cool. Good to see that it works with some motherboards, but it's definitely on a case-by-case basis. (Didn't work with my sabertooth because of clearance over the chipset heatsink(s) ).
Not sure if I'll hear back from them, but I've got some feelers out with TT to see if I can buy one of the top panels for modding. I've already got a black metal mesh wastepaper bin picked out at the dollar(+) store..... ;)
  #112 (permalink)
Old April 29, 2012, 06:32 PM
nasrott's Avatar
Good luck with it SS
  #113 (permalink)
Old April 29, 2012, 07:18 PM
sswilson's Avatar
If worse comes for worse, I can always remove the top panel, add two fans up top, and then the mod will be filling in the open holes around the 2X 120mm fans mounted up top.
Tags
amd x6 1090t , barb , coolstream rad , fesser , fitting , level , nvidia 560ti , sabertooth 990fx , supreme hf , thermaltake , water cooling , xfx power supply , xt 240
Thermaltake Level 10 GT Case Review Mnpctech Off Topic 10 March 19, 2011 05:30 AM
Thermaltake Level 10 and Megahalem Closed Note New Builds 12 August 8, 2010 12:10 PM
Thermaltake SwordM VD500LBNA Aluminum Extrusion w/Water Cooling System Full Tower Cas Gonzo Water Cooling 24 October 19, 2009 03:29 PM
Thermaltake Level 10 Signal2Noise Cases 2 September 29, 2009 10:15 AM
Thermaltake Level 10 chassis Mark Press Releases & Tech News 18 September 28, 2009 01:51 PM
