Old November 2, 2011, 12:29 PM
Soultribunal's Avatar
Originally Posted by lastsplash View Post
Not exactly. I can tell you that I'm drawing 780W from the wall when they are both under full load, (at least according to my battery backup's display) but that includes a monitor and a router as well.
Wow, you're running it right to the wire on that for power consumption.
not my comfort zone but if it works why not.
ST
www.realhardwarereviews.com
Old November 2, 2011, 04:06 PM
bvsbutthd101's Avatar
That's cool, estimated number is good enough. Thanks
Old November 2, 2011, 04:44 PM
That build is so clean and tidy.
Old November 2, 2011, 06:48 PM
mattlef's Avatar
Great work on the loop, but even better photography.
Great job!
CC-HotSpot Host
YouTube Instagram Twitter
Old December 20, 2011, 07:17 PM
lastsplash's Avatar
Thanks for the compliments!
I added a 240 rad and a drain and fill port, plan is to take some photo's in the next few days. (if life doesn't get in the way!)
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
I may add a rad or a second loop botat29 Water Cooling 6 April 3, 2011 07:36 PM
Do I have everything I need for WC loop? ADay2Long Water Cooling 15 August 6, 2010 09:34 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
