<~----> Case Mod Case Mod Project: "Tribute to SERENITY firefly series" Mad Reader Mod pays $1500! - Page 5 - Hardware Canucks
  #41 (permalink)
Old November 16, 2011, 09:00 AM
Mnpctech's Avatar
.... still work in progress. I'm learning new tricks as I move along as well. I will fine tune the weathered and distressed effects, so they're not a stark contrast to everything else atm. It's a process of creating first, then breaking it down. I'm focusing on 1 element, let that process cure, then go back to earlier stages...like the Switch holes for example, I'm still working on making them look worn and smooth, not scratched up. I'll post progress photo of those next. :)
I added just a dab to the fan controller box on the right panel...
  #42 (permalink)
Old November 16, 2011, 02:06 PM
Mnpctech's Avatar
by request, ...the Dinosaurs
  #43 (permalink)
Old November 16, 2011, 03:14 PM
lowfat's Avatar
Turning out pretty snazzy.
  #44 (permalink)
Old November 17, 2011, 08:27 AM
Mnpctech's Avatar
Thanks for watching and commenting! Next step is fine tuning the weathered and distressed effects with an Airbrush
  #45 (permalink)
Old November 18, 2011, 06:44 AM
Mnpctech's Avatar
Last night I went over my initial weathered and distressed paint effects with an Airbrush. Anything that contrasted a lot, I muted with Matte Black, like the fan blades, copper tubing, decals, shiny toggle switches on the fan controller and screw heads. I also airbrushed the edges of Silver Aluminum paint, which I used to created the chipped and scratched paint beneath.
  #46 (permalink)
Old November 18, 2011, 07:11 AM
amazing build..
  #47 (permalink)
Old November 18, 2011, 02:57 PM
Mnpctech's Avatar
Thank you!
Ok, this is that weird cut-out Before...
  #48 (permalink)
Old November 19, 2011, 06:03 AM
Mnpctech's Avatar
In the firefly verse, "Shiny" is slang for "cool" "great", "neat", "wonderful", etc.
Nathan Fillion
"SHINY" plate design for 5.25 Optical bay cover will be milled from 3/16" thick Copper, and lit from behind
  #49 (permalink)
Old November 19, 2011, 04:53 PM
Mnpctech's Avatar
Going over areas of the right side panel with airbrush, using Flat Black, over saturated with Thinner.. to weather or "mute" some of coloring in the decals, wiring, and smaller copper tubing
  #50 (permalink)
Old November 19, 2011, 05:29 PM
Birk's Avatar
Originally Posted by Mnpctech View Post
I didn't have a lot of time today to experiment with my tube bending idea. Here are the 120mm Aerocool fans I painted last night with Rustoleum's Metallic Copper, #1937830. The multi fan blade design fits the antique copper. This paint looks surprisingly realistic, and doesn't smudge like the fake Chrome effect paint. I'm going to airbrush the edges of fan frame and blade hub, to give it aged look, hopefully Thursday night.
When painting the fans did you need to take them apart or protect the open side of the hub? I was thinking of doing this but didn't know how well the hub would take it.
Awesome PIXAR Tribute PC, "Lightening McMod" Mnpctech Off Topic 12 October 23, 2012 09:06 AM
Cool Tribute to "Dawn of War” Mnpctech Off Topic 2 May 17, 2011 10:23 AM
"Wii 2" Codenamed: "Project Cafe" BFighter Gaming 5 April 24, 2011 10:16 AM
"Unreal Tournament Tribute" Case Mod Mnpctech Case Mods, Worklog & Gallery 55 January 4, 2011 10:52 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
