<~----> Case Mod Case Mod Project: "Tribute to SERENITY firefly series" Mad Reader Mod pays $1500! - Page 4 - Hardware Canucks
  #31 (permalink)
Old November 11, 2011, 05:44 PM
PerryC's Avatar
This looks some sweet. So I don't crap your thread, PM on its way.
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
  #32 (permalink)
Old November 12, 2011, 04:26 AM
Mnpctech's Avatar
PM sent....I'll sum it up here, for anyone else wondering
for anyone else considering these Avery brand "Clear Sticker" Printer sheets ...You can buy from Amazon or "some" Office Supply Stores.
Positives:
1. Int doesn't smudge. I used Inkjet Printer
2. Works good on acrylic or plexi windows
Negatives
1. Dull Color Matte Finish
2. Doesn't stick well to painted surfaces. (I had to use 3M Super 77 adhesive spray)
3. Anything colored White in your design, translates to Clear "see thru" instead, once it's printed.
4. Cost. 10 sheets for $13.99
For this project, which has distressed and weathered theme, they worked great. I could see using them for a custom window design, if youre OK with dull coloring...Otherwise I wouldn't suggest them for anything else.
[/quote]
  #33 (permalink)
Old November 13, 2011, 05:24 AM
Mnpctech's Avatar
I figured painting a portion of right panel Orange metallic, would compliment the Copper tubing... I also implement CORSAIR 400 into the label for the box. I'm still working on the paint effects around the edges.
I will be using "sophisticated finishes" Metallic surfacer as base coat before applying their Instant Rust solution to edges of the panels
  #34 (permalink)
Old November 14, 2011, 06:05 AM
Mnpctech's Avatar
The 240 "Serenity" in Kanji grill for the top panel, will be cnc milled from 1/4" Copper.. I may try "Flame Coloring" it like this photo...with Oxygen acetylene torch
  #35 (permalink)
Old November 14, 2011, 09:33 AM
Hannes's Avatar
Looks really nice Bill!
Project Echo | Fractal-Design Array Rev2 | i5 750 | DFI LANPARTY MI P55-T36 | 2x2GB A-Data | Fractal SFF 300w MDPC-X sleeved orange and black | HD5870 | Kingston V-Series 64GB SSD | 2TB HDD | EK Supreme HF | EK-DCP 4.0 | EK Multioption 250 RES | EK-CoolStream-RAD XT 240 | EK-CoolStream-RAD XT 120 | EK-PSC Fitting 12mm - G1/4 Black | 5870 fullcover block |
  #36 (permalink)
Old November 14, 2011, 02:48 PM
Mnpctech's Avatar
Thank you Hannes! ....and of course, you've gotta have "BLUE SUN" implemented too! This Fan Grill design is by Roboduck! and will be milled from 3/16" aluminum. This will mount on the rear exhaust for the 400R chassis.
  #37 (permalink)
Old November 15, 2011, 07:07 AM
Mnpctech's Avatar
Here is progress on right panel. Yesterday, I created the effect of peeling and scratched paint. I dabbed the edges on the side panel with PlastiKote's #207 Aluminum "Engine Enamel" Silver paint. Sprayed onto paper sheet, then dabbed onto paint brush... Steps to follow include Painting along the edge of the Silver painted chips and scratches, to create illusion of layered paint. ...like this image More weathering and graphic references from firefly will be implemented this week. I'll also be using Sophisticated Finishe's Rust effect products for adding a rust to areas of the exterior.
  #38 (permalink)
Old November 15, 2011, 12:33 PM
Mnpctech's Avatar
It's still a work in progress and needs a lot of more realistic refinements :) I'll be using Sophisticated Finishes surface effect products to add some rust to areas of the exterior. I used this on the District-9 PC.
District 9 PC exterior....
  #39 (permalink)
Old November 15, 2011, 03:23 PM
Looking forward to the completion of this project! Loved the Firefly series!!
  #40 (permalink)
Old November 16, 2011, 04:50 AM
Mnpctech's Avatar
Me too! and Thank you for watching and commenting! I dabbed the steel screws, panel and modders mesh with Sophisticated Finishes surface effect products to add a rust effect. It only requires 2 steps, Apply their Iron Metallic Surfacer first, then Rust Antiquing Solution. The sooner you apply the Rust, the more Orange looking it will be.
Awesome PIXAR Tribute PC, "Lightening McMod" Mnpctech Off Topic 12 October 23, 2012 09:06 AM
Cool Tribute to "Dawn of War” Mnpctech Off Topic 2 May 17, 2011 10:23 AM
"Wii 2" Codenamed: "Project Cafe" BFighter Gaming 5 April 24, 2011 10:16 AM
"Unreal Tournament Tribute" Case Mod Mnpctech Case Mods, Worklog & Gallery 55 January 4, 2011 10:52 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
