  #21 (permalink)
Old November 6, 2011, 01:27 PM
Mnpctech's Avatar
found out this morning on facebook, the SKULL image, (2nd from top) states "RISK" in Arabic ....OK, I can use that one, but I need to somebody who can read Kanji! No clue what any of that says and I don't wanna insult anyone! .....I presume the show designer already thought of this...haha
Here is an outstanding deal, LCD Temp Meter with thermo sensor and Molex, $7.88 Shipped, on Ebay. and It works great, and I didn;t have to wait 6 months for it to arrive from China. It only took 1.5 weeks
Ebay Link,
5V Digital Thermometer Temperature Meter Gauge Dual LCD | eBay
Here it is, mounted on the top Power panel for this build (more pics to come), but would be easy to mount in 3.5 bay face plate.
  #22 (permalink)
Old November 7, 2011, 05:42 AM
Mnpctech's Avatar
The paint effect on this gun is pretty close to what I'm striving for on exterior....Except the case edges will expose steel.
I went over the edges of Corsair's factory "grey" finish on the panels and top cover with an orbital sander, then painted everything Flat Black, after that cures, I'll go over the surface with red Scotch brite pad, and some of the edges with 80 grit sandpaper.
for Wrinkled Metal effect, to be painted later
  #23 (permalink)
Old November 7, 2011, 12:54 PM
Mnpctech's Avatar
I just received these Firefly Coach Works name & serial plates off Ebay, here.. They're made with Black gloss and brushed aluminum vinyl.. perhaps one on back of the chassis
  #24 (permalink)
Old November 7, 2011, 04:20 PM
Galcobar's Avatar
Second language in the Firefly universe was Mandarin Chinese, but you're saying the writing was Japanese?.
  #25 (permalink)
Old November 7, 2011, 04:29 PM
Mnpctech's Avatar
Yes, I was told it's katakana, but they could be wrong...
After paint has cured, carry handle area is scuffed to show high usage over time.., the top portion of the handle is plastic, so dabbed Aluminum Silver paint along edge, then lightly scuffed it with scotch brite pad, to create illusion of exposed steel beneath the paint...
  #26 (permalink)
Old November 7, 2011, 08:15 PM
Bohrman's Avatar
I wouldn't be surprised if it's katakana as the script often looks cool and gets used in media a lot (matrix digital rain for example). Katakana is based of Chinese characters..... works in the end?
Haha what can't you find on ebay
  #27 (permalink)
Old November 8, 2011, 04:22 PM
Mnpctech's Avatar
Thanks! btw: I have to be careful with those types of effects, like "failing & poorly repaired" exterior elements need to remain intact, esp when the case travels or being handled by "Union" Movers at Trade Shows....lol
Worked on the bezel and Mini Toggle Fan Controller faceplate today, now showing a bit of usage.... (wire bristle brush...hehe)
dabbed Aluminum Silver paint around the I/O openings, then lightly scuffed it with scotch brite pad, to create illusion of exposed steel beneath the paint...
  #28 (permalink)
Old November 9, 2011, 08:53 AM
Mnpctech's Avatar
I'm going to try printing the graphics from the Serenity PDF on adhesive printer paper.. I've pasted different sizes, I won't be using all of these, just wanted a variation for experimentation. The clarity and sharpness isn't detrimental, since the surface and edges will be weathered with airbrush, then cleared with matte clear...
  #29 (permalink)
Old November 9, 2011, 10:34 AM
great_big_abyss's Avatar
That looks absolutely fantastic. I'm a HUGE firefly fan myself. Can't wait to see the finished result.
  #30 (permalink)
Old November 11, 2011, 04:17 PM
Mnpctech's Avatar
Thank you! progress work on top panel... the tape over the switch will be cherry on top, when everything is assembled ;)
Awesome PIXAR Tribute PC, "Lightening McMod" Mnpctech Off Topic 12 October 23, 2012 09:06 AM
Cool Tribute to "Dawn of War” Mnpctech Off Topic 2 May 17, 2011 10:23 AM
"Wii 2" Codenamed: "Project Cafe" BFighter Gaming 5 April 24, 2011 10:16 AM
"Unreal Tournament Tribute" Case Mod Mnpctech Case Mods, Worklog & Gallery 55 January 4, 2011 11:52 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
