Old October 22, 2011, 02:02 PM
Shadowmeph's Avatar
Good work, I wish I had a place to build a test bench for my folder build which is in progress .
I am curious is the lower tray more for stability or to hold other things. I have actually never seen a test bench before :-}
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old October 22, 2011, 02:22 PM
CoolHandL's Avatar
The Bottom is for Hard drives, PSU, top is for motherboard
And my work shop is a folding table in my spare bedroom beside my office desk ha ha
sort of like this:
NCIX.com - Buy Highspeed PC Large Top Deck Tech Station FAST-ACCESS E-ATX Computer Case Black - HighSpeed PC - TD-Tech_StationLRG-BLACK - in Canada
Old October 22, 2011, 02:33 PM
NI3 NI3 is offline
What is that aluminum tube called? Or what section would it be in at home depot?
Old October 22, 2011, 02:45 PM
CoolHandL's Avatar
NI3 - near the hardware aisle like where the screws and nuts and bolts are. I used square tubing, 90* Angles and flat pieces.
Old November 2, 2011, 01:54 PM
CoolHandL's Avatar
Small Update, I received my first piece of Hardware today, A Corsair AX850 PSU (Thanks to Mike over at silentpcreview.com | Everything about Silent / Quiet Computers for the Great Price) , pretty sweet unit, Nice having an option to use 2 or 4 Sata Power cables.
The Bench is getting close to completion I have the Well Nuts on order (to make the mother board Stand Offs) Hard Drive / SSD Holder on its way from UNDesigns. Just Need some more Hardware
Sponsors:
archer-plastics.com
(UN)Designs Brackets*|*Custom Water Cooling Brackets
Old November 6, 2011, 11:44 AM
jcmaz's Avatar
Looking good :D
On another note, how much does a sheet plexiglass cost?
-Plato
Old November 30, 2011, 09:49 AM
CoolHandL's Avatar
Both pieces cut and polished(he did something else I cant remember though) were $20CDN Total, it’s 1/4" thick 14”x16” x 2,
I bought my Pieces here: archerplastics.com I think $20 bones all in was a great deal, hence the sponsor mention for him.
For a comparison I looked at a few retailers that sell it:
MNPC
1/8" thick cast acrylic. 24" x 12" Acrylic Sheet, $19.99USD Smoked
Clear & Colored Computer Case Windows
Performance PCS
A.C. Ryan Acrylic Panel™ 1/8” thick – 18.89”x18.89” Smoked 19.95USD
A.C. Ryan AcrylPanel™ 3mm - 480x480mm Black [ACR-AP3411] : Performance-PCs.com, ... sleeve it and they will come
Old January 10, 2012, 07:57 AM
i wonder if it's easier to buy the bench top vs. making it?
-joe
  #19 (permalink)
Old January 10, 2012, 09:29 AM
CoolHandL's Avatar
-joe
way easier, but a bit more expensive, and lower quality of products (particle board vs plexiglass) and no feeling of self accomplishment ha ha.
** Update, i now have the well nuts to make the motherboard standoffs, just need to order motherboard so i can get hole spacing right.
Skywalker - Q6600(GO)+P5Q Pro turbo+HD5870+HX750
Hansolo - X4 925+M4A785-M+HD6850+OCZ500W
Chewbacca - Q6600(GO)+P5G41-M+OCZ500W
DEATHSTARMini - Zotac N330 mini ITX
  #20 (permalink)
Old January 10, 2012, 10:15 AM
I was always under the impression people don't use plexi because of static?
-joe
Tags
custom case , folding , tech bench
New Old Folder.. mchutch HardwareCanucks F@H Team 7 February 27, 2011 08:01 PM
Low Consumption Folder OR Part time POWER Folder ilya New Builds 3 May 16, 2010 03:33 PM
New Folder here, CPU PPD question RLP06 HardwareCanucks F@H Team 7 May 16, 2010 07:00 AM
just came fro mdentist.....this folder is done for _dangtx_ Off Topic 48 November 7, 2009 04:47 PM
Folder down redwagon HardwareCanucks F@H Team 2 October 2, 2009 12:35 PM
