Old September 27, 2011, 01:14 AM
Default Project Sulaco
Hello All
So, im new here this will be my first of hopefully many project logs,
in the first few posts ile outline the project and whati hope to end up with
Including my inspiration, how im going to get the job done (were talking a low enough budget to make a victorian family cringe)
And hopefully gather some interest for tips, help and some much needed support
I have a background in design and a lot of plastic scratch building from an addiction to 40k in my youth. As i lack a lot of the serious tools i will be coming up with some interesting ways round common problems
By the end of this i shall be hence forth known as "Dremel Boy" or if the cutting wheel slips "The 9 finger Noob"
So watch this space for what could be either an epic tryumph or epic fail... but hell either way should be interesting
First up some of the sources or inspiration, I suspect most can have a good guess from the project name
The good Old USS Sulaco, Marine carrier ship from Aliens
The Atmosphere processors may best reflect the feel, its heavy industry with big lines and chunky details
The case i am going to build on to is the NZXT Tempest EVO
Chunky Styling is allready a feature so it should be a superb platform to build on to
So were going with chunky industrial lines and a plated metal look to it, fan grills currently in design phase (OMG there huge) pics soon
SO why choose an NZXT Tempest evo?
Well lets look at its attributes
For a midtower this is huge.. and that's with a capital HU!
Steel Chassis, sire its not light but it sure as hell can take punishment and support some seriously heavy gear
And of course every ones concern.... cooling... although it has none of the trappings of 20mm fans it sports plenty in the 120mm to 140mm range. for me (A die hard air cooler)
it is perfect, but also sports 5 water-cooling grommets
Did i mention the case was big???
And on a final note... the case is big lol
Side on
Large tinted window and 120m fan with filter. A slight departure from most windows as it is mounted outside the case sitting proud of the side panel, it really helps to keel the case symetrical whilst also gaining a slight amount of extra clearance for the larger aircoolers out there
Inside
Well we are back to "ITS HUGE" no more bleeding fingers from case edges for me, i can in stall my rig in this and use it as a spare room for guests, its clutter free and the HDD racks are tool less and can be removed completly for GFX card space or for controlers to be hidden away behind the front support
Recessed ports prevent them getting kicked or knocked... we all know the pain of hearing a crunch leaning over our pc and viewing the horror of a USB plus pointing 45deg out of the port, well break your ports no longer... and the area infrobt makes a handy dandy place to keep memory cards (well for me anyway)
It has great strong lines and a sharp clean shape, its huge panels leave plenty of space to mod in to/ on to/ over or through, its such a huge case with so many possabilities offered my its strong frame and sheer size that it was a huge headache picking a theme to use
I have been an NZXT fan for years, right back to the LEXA, and we are talking pre blackline edition
So without further boring you all to death (condolences to those who died of bordom reading)
Project Sulaco............
Old September 27, 2011, 01:37 AM
To compliment my fans for this build (ENRMAX Apolish Vegas blue) I wil be making my own custom grill/intakes
First mock up of the front grills, all hand made form plasticard, sorry no work pics for these at this stage in the build i had not picked up a decent camera
Ahh plasticard my new BFF
All constructed in .5mm plasticard, slightly smaller then you would expect for a 120mm intake
Old September 27, 2011, 01:39 AM
Some test fitting of some early stage additions, second of the mk1 custom intakes and some fleshing out of the panel layout
Intakes made from hand cast polyester resin in a Silicone RTV mould made form the plasticard master, all other components 3mm plasticard
Finishes intake fresh out of the mould, at this stage they are very brittle, and need to cure for several days, maybe even a month to be on the safe side
Twin mk1 intakes and cutouts for Silverstone media panel, and blue ray drive, layed out to test fitting and space on the panel
And yes i know the intake flanges are not perfectly symetrical.... i have a cunning plan for that later
NOTE, allways use a canister filter mask when working with polyester resin... i did not, took 3 days before i stopped seeing double
Had some spare time today between work and fending the kids of with a dremel os have doen the prelimiary design of the side panel for Project Sulaco. Very Industrial with big intakes, think of it as a cross between an indulstrial cooling system and an escape/airlock
Prelim sketch (no laughing it was quick lol)
First stage, wire frames and checking the size works for styling
[CENTRE]
[/CENTRE]
Materials :
Renders of the window (not true colour)
Still a lot more design to do before i can start some serious fabrication
Here is a few more shots of some elements that are driving the design
Sulaco inner airlock[/B]
Exterior airolock of the Nostromo
Why have a note on the OUTSIDE of the airlock warning against explosive bolts... if you are outside to be reading that then the bolts are the least of your worries
I am hoping to incorporate some of these details in to the finished design, perhaps not to clean and clinical as in the Sulaco's inner airlock but cretainly with the same sturdy build
Awaiting supplies for casting and some materials so on with the bezel....
First things first, test fitting
However soon a problem arises, IE the flanges on the surrounds are not symetrical, a minor disaster but not the end of the world. i have a cunning plan.....
First up, covering up that nasty gap between the 2 intakes with a fresh sheet of plasticard, set i place with 2 part epoxy
Then i needed to begin forming it to the original lines of the intakes, without some better tools then i have its time to make use of the sturdy kraft knife and some precision files, making lots and lots of incise cuts to edge my war closer to the main form, the feathering this creates also makees the final cut off much easier
3 Hours later
Old September 27, 2011, 01:42 AM
Next up, giving it that deep set duct that i so wanted to look lik an air con or ventilation unit
For this I had to use several strips and glue then end to end to get the length strip i needed, left to dry for 48hours, a huge amount of time to dry poly ut as the glued join measured 20mm X 0.5mm it needed to be solid
Once the epoxy on the reverse has set i can go ahead and poly the join between the edge of the duct and the top sheet, i have allowed some extra material to remove later, I am sure all of us would rather need to remove more rather then find we had not removed enough
WOW hot day, wish i was outside but needs must, i simply haft to get these flanges fixed. The flanges on the corners were not exactly symetrical so i had the idea to raise the whole section and build a fake box on top of them to the exact shape i wanted, once drawn up and measured the gluing was easy, BUT they are only attached by there ends until i can get the side pieces put together
[CENTER]
Small update today... well for this morning, may be more later
[CENTER]Attached the flange sides, the beauty of this is you dont need to havean exact shape, you use the join to guide your cut
Finished with all flange sides added ready for first coat, as i am using plasticard for the main construction i am using a VERY thick application of satin PlastiKote clear over a matt black, not for the final finish but to provide me with a hard shell to work on top of
[/CENTER
Whilst i wait for my joints to dry ive taken some spare time to make the replacement NZXT logo and AMD logo
AMD logo done, a lot less tricky then i expected
NZXT logo almost sorted, most of the letters turned out fine although i am on the 16th letter X
All letters finished with a little plinth to place on
DONE yay!!!!
And yes those letters are 13mm high
Time to start working on the mould for the window surround, i willl be using a master blank to provide the shape for the finished surround, and will be casting the mould from silicone RTV
or a lubricated alu box (setting resin can get up to 80C and will melt plastic)
Final produce till be cast in Polyester resin
Render of the Bezel i wil be making, caution will be the key here as the polyester resin can be brittle in the cross section i will be working in
BIG update today
With a huge influx of materials and some glorious free time ive managed to start on the blank to be made in to a mould for my resin window bezel, main blank fabrication is from 3mm plasticard, and wil be all hand cut and filed to prep for moulding, all joints will be made with polycement, it is quick cheap and effective for this material
Once marked out i can start to score the lines to create a guide path for the scalpel
All lines nice and deeply scored, the depth of each cut is now approx 2.5mm deep, the component can be snapped free after this point
And behold the first piece of the mould blank, the most critical piece as this wil govern the placement of the rest of the structure and any reinforcing needed
Cutting out the "rails" that i will split to make the sides and reinforcing butresses
First few sides and supports added, due to the pressure of 24hours immersed in a very dense liquid such as Silicone this needs to be very strong to prevent warping f the flat surfaces
Construction continues
And now finialy, my new camera, say god bye to dodgy phone camera pics
MY new Fuji all singing all dancing camera.. if this was any smarter it wold be a professor as Cambridge
New Arrivals
Hmmm i wonder what they could be, i shall use my jedi powers to detect the cargo... I predict the one on the right are fuel rods and the one on the left is a very angry Chinhilla
Damn i was wrong....
And....
Yes the sweets did come with it, weird
Lets take a closer look...
Silicone RTV (Liquid silicone component)
Catalyst component
For this brand the mix is 1/10 catalyst to silicone, most have a ratio of 1/5 for the "salmon" catalysts. This is a clear catalyst mix better suited to exposure to Polyester resin
Class is shore A (20), i very resiliant silicone mix with high thermal resistance and strength, not as elastic as some classes its tearing ratio is 400% elongation
And now the cathodes....
Whats in the box
4 UV CCFLs
2 twin inverters
On/off rocker switches and cable bundle (ugly and will be replaced and sleeved)
Assorted sticky bits
UUUUU purdy (chair not included)
Old September 27, 2011, 01:45 AM
Finishing the mould, had a good bit of time to work today so ive finished the blank and set up the mould walls to retain the Silicone RTV
My two best friends polycement and a scalpel
Blank finished with all the reinforcing in place, and poly is set
Lets break out the sander.... MORE POWER!!!!
After some brief but interesting sanding where my pet Staffordshire Bull terier tried to eat the mouse sander i finialy got the edges nice and crisp and the bottom level all ready to glue to the sheet that will form the base of my mould
Crisp, clean.... and erm.... dusty
Brushed off the dust and debris and glued the blank to the mould floor
Lots of spare plasticard cut in to strips to form the mould wall
Mould all done all ready for the RTV to go in
Time to mould
Everything you need to make the mould
Pictured above, all the things you need to finish one single part mould
  • Spatula
  • Silicone RTV
  • Catalyst
  • Blank
  • Mould box
  • Mixing vessel.... (my wife's fave cake tin)
  • Rice
As this is not a regular shape mould it is hard to work out the volume do you dont over or under mix a quantity of silicone
Fill your mould with rice until you have the blank covered to a depth that you feel you want for mould
Pour off the spare rice and empty the mould in to your mixing vessel, then mark the level the rice comes to as your "max fill" level
Although you may think that another approach would be to weight the rice for maximum accuracy but DONT, Silicone RTV is far more dense that rice and you will not get the same volume
Place your mixing vessel on some weighing scales and make sure you zero the reading... pour in the Silicone to the fill line.... make a note of the weight
As this is a 1-10 mix catalyst you need 1/10 (BY WEIGHT) so from the note you made on the scales work out a tenth and pour in the catalyst until you reach that weight
NOTE - The catalyst that comes with this brand of RTV is clear, i have tinted it with silicone dye for photographic use and to better illustrate a good mixture
And now we are ready to pour, do it slowly and try to avoid moving the pour stream around to much in the early stage as you will trap air bubbles
Pouring done, let it settle and check after an hour to see if the surface if free of bubbles, if it is not pop them, remember this will become the bottom of the finished mould and must be perfectly flat
Time to demould
One of the good ways to see if your silicone is ready to remove from the mould is to look at the surface it will lok tight and will have lost most of the shine it had as a liquid
Another popular but less scientific method would be "prod it a bit"
As with most materials set with a catalyst the thicker areas set first so to be 100% sure that it has set pull away one side of the mould to release the seal if its to soft push the side back and wait another 3 hours
Start taking the sides off our mold, NEVER try to take it out like a jelly mould, the suction from the material will more then likely destroy your blank and mould block before it becomes free
Starting at one edge peel the mould off the blank, this way you break the suction as you go
TADAAAAAA!!!!!!!!!!!!!!
Little bit of flashing around the mould edges, very easy to trim off
Old September 27, 2011, 01:47 AM
All 4 parts cast, time to get the mouse sander out
Here we see the mouse sander in its natural habitat, about to pounce on this basking bezel piece
10 mins and a lot of swearing later (sanded my finger)
30mins more and even more swearing (to annoy the neighbours)
Ready to do the fine sanding ready to box up doe painting later
Its door fabrication time, that means HERE COMES THE DREMEL yay!!!!
First up, lets get this side taken apart
Tabs off, lets pop the window out
I will be using 1.5inch cutting discs from MNPCtech
Measuring up the new window bezel and making sure my cut lines are marked well inside the cut.... CUTTING YAY
Deburring
Well that took ages lol, but the results are exactly what i need
Next up, filling the acrylic for the window and starting the cut for the top mounting panel
Unfortunately i couldnt get any shots of cutting the acrylic out as the dust was getting in my camera, co lets ump to filing and sanding the cut edge
I will be using a rough sanding pad for this as i have a lot of material to remove
Whoops
Ahh there fixed, ther was never a huge chunk taken out of the edge... was there *swings hypnotists watch*
In the next post... i start work on the top panel
Busy week, children, fabrication, deliveries, the list goes on....
Finialy an update and i am delighted to say it is a sponsor
[CENTER][/C
Old September 27, 2011, 01:49 AM
SUPPLY DROP
A few weeks ago i was delighted to hear that NZXT had been kind enough to sponsor my project, for me this is fantastic, although sponsorship is a day to day affair for the more established in the modding community but for the new guy sponsorship is a big risk as they cannot be 100% sure there not being conned or that the project will not fizzle out to nothing. So once again its a HUGE thank you to NZXT
SUPPLIES
After mugging my deliveryman and fighting my way in to the packing box (cudos on the secure packing)
Lets see now we have.......
The HALE90 (850watt)
Sentry LXE
Blue LED lighting kits
Unboxing the PSU, what's in the box... well ok a PSU... i ment what else
Nice to see a total lack of the typical polystyrene in favour for the non crumbely packing.
Everything in perfect condition
The PSU its self, NZXT have gone for white on the HALE90 series, with the recessed grill and 140mm fan the looks are pretty striking, and of course it IS modular
Plenty of modular cables provided, all have good quality connectors, and with the all black sheathing have a nice uniform look. and all kept safe in a little carry case
The main loom has plenty of connectors all sleeved in black braid
On to the Sentry LXE fan control
Again we have the same foam packing to keep it all safe, no part of the LXEs main unit was touching the box it was suspended in the foam for max protection, so many times have i seen components resting on cardboard after removing the cover package
Main unit is very rugged 5mm alu face plate
sadly i could not get a shot of the screen (camera flare central)
Main PCI, Connectors a plenty here with power, 5 3pin PWM fan connectors and 5 temp probe connectors
They have even included EXTRA temp probes just incase
Also included, screws for pci mount, 8 pin pci plate to control lead, pads to affix the probes and a back up battery
Last up the Blue LED strings, nice little blister pack, in the case of components like these i often see way to much in the way of packaging
In the box we have pci plate, power lead and the string its self, the one pictured is the BLUE 100CM edition, 200CM is available
On the rear plate we have a slider for 3 brightness selections and ofcourse the On/Off switch
Once again a massive THANKYOU to NZXT for the sponsorship
Old September 27, 2011, 01:50 AM
BUSY BUSY BUSY, finialy has a chance to get a good run up putting the side pane together and making sure it all fits before final sending and painting
Electrical tape, the modders friend
This was a nightmare to get all the components in place to drill through what was technicialy a sandwich of cast polyester, steel and acrylic
More drilling.. jeez......
Making sure the holes line up for bolting
This could have been a lot easier and faster but with limited resources one hast to think out of the box
Test fitting the bezel
The gaps are intentional, i will be covering them with brushes alu to add a little accent
Tapping the holes for the fan/grill assembly
MNPCtech 120mm overkill grills, Bill Owen over at MNPCtech is making 2 140mm versions of these for me for the top
MORE DRILLING
MORE, MORE DRILLING.......
UUUU thats rough
Most of the forming done, dremel+lap sanding wheel+awesome
Main door fab finished, plenty of adjusting to come but thats the BIG fab done
The fans are perfectly central trust me..... CURSE YOU CAMERA ANGLE
NOTE the 2 triangles outside the bezel are intentional, not sure if there going to remain tiny windows or to cut them through in to blow off vents
And no way in hell am i removing the protective film untill im done
So much still to do, but its gunna be great fun
Old September 27, 2011, 04:59 AM
Arinoth's Avatar
Wow this is one amazing build. Looking forward to seeing the final product.
Old September 27, 2011, 05:30 AM
stoanee's Avatar
heatware
Project: i7³ Lpfan4ever Case Mods, Worklog & Gallery 31 October 6, 2009 09:47 PM
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 06:53 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
